Hi Claire, yes in Oz, and no - just using the standard met.no forecast sensor that is installed by default by HASS.
I’m having the same issue. The main weather shows fine but none of the forecast. Hope that API gets updated soon.
I have this resolved now, the idea - smile slowly - first ensure your sensor is working. Note I changed the template to update each minute as seen below, will return this to hour later. So I can see changes, I commented out # forecast, and set the state, temperature, temperature_unit to a string.
#NSPANEL MOD for weather
- trigger:
- platform: time_pattern
minutes: /1
- service: weather.get_forecasts
type: daily
entity_id: weather.bom # change to your weather entity
response_variable: daily
- name: Weather Forecast Daily
unique_id: weather_forecast_daily
state: "{{states('weather.bom')}}" # change to your weather entity in this line
attributes:
temperature: "{{state_attr('weather.bom', 'temperature')}}" # change to your weather entity
temperature_unit: "{{state_attr('weather.bom', 'temperature_unit')}}" # change to your weather entity
forecast: "{{ daily['weather.bom'].forecast }}" # change to your weather entity
When I could see the Entity in Dev Tools >> States as ‘sensor.weather_forecast_daily’ I then enabled states and Reloaded All YAML, when this showed correctly I enabled temperature and so on.
If you go to his Github ([BUG] HA 2024.4 - cannot display forecast properly · Issue #1209 · joBr99/nspanel-lovelace-ui · GitHub) you will see what the sensor should look like.
Then add the sensor to the panel and the world should be beautiful.
key: ssKey
statusIcon1:
entity: switch.study_nsp_switch1
altFont: True
icon:
"on": mdi:menu-up-outline
"off": "text:"
statusIcon2:
entity: switch.study_nsp_switch2
altFont: True
icon:
"off": "text:"
entities:
- entity: weather.bom
- entity: sensor.weather_forecast_daily
type: 0
type: 1
type: 2
type: 3
- entity: sensor.study_nsp_temperature
icon: mdi:home-thermometer-outline
alternativeLayout: false
defaultCard: navigate.studyKey
theme: !include /homeassistant/appdaemon/apps/nsp_theme.yaml
OK - got it working on my end … and totally my fault …
I forgot to do the required directory change and update of Appdaemon stuff …
Once I did the below … all returned to normal
follow instructions in here
Thanks for the confidence to keep troubleshooting. My issue was also my fault. I already had a template entry in my config file and had double entries. Somehow I missed the error in studio code the first time around. DOH.
there is now available 12VDC backplate for NSPanel: Smartavan 12VDC backplate for Sonoff NSPanel
anyone here can help me out please ?
when adding this line: app_dir: /homeassistant/appdaemon/apps
to the appdaemon.yaml my nspanel stops working.
yes the nspanel files are in this folder but it doesn’t work.
Getting all kind of weird appdaemon errors like:
2024-04-21 18:52:15.802634 WARNING nspanel-1: Unexpected error running initialize() for nspanel-1
2024-04-21 18:52:15.803151 WARNING nspanel-1: ------------------------------------------------------------
2024-04-21 18:52:15.808501 WARNING nspanel-1: Traceback (most recent call last):
File “/usr/lib/python3.11/site-packages/appdaemon/app_management.py”, line 162, in initialize_app
await utils.run_in_executor(self, init)
File “/usr/lib/python3.11/site-packages/appdaemon/utils.py”, line 304, in run_in_executor
response = future.result()
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/homeassistant/appdaemon/apps/nspanel-lovelace-ui/nspanel-lovelace-ui.py”, line 18, in initialize
apis.ha_api = self.get_plugin_api(“HASS”)
File “/usr/lib/python3.11/site-packages/appdaemon/utils.py”, line 231, in inner_sync_wrapper
f = run_coroutine_threadsafe(self, coro(self, *args, **kwargs))
File “/usr/lib/python3.11/site-packages/appdaemon/utils.py”, line 313, in run_coroutine_threadsafe
result = future.result(self.AD.internal_function_timeout)
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 456, in result
return self.__get_result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 401, in __get_result
raise self._exception
File “/usr/lib/python3.11/site-packages/appdaemon/adbase.py”, line 115, in get_plugin_api
return await self.AD.plugins.get_plugin_api(
File “/usr/lib/python3.11/site-packages/appdaemon/plugin_management.py”, line 404, in get_plugin_api
mod = import(module_name, globals(), locals(), [module_name], 0)
File “/homeassistant/appdaemon/apps/omnikdatalogger/omnik/plugin_localproxy/hassapi.py”, line 6, in
class HASSAPI(LocalProxyPlugin):
File “/homeassistant/appdaemon/apps/omnikdatalogger/omnik/plugin_localproxy/init.py”, line 7, in init
cls.register(cls) # Called when a plugin class is imported
Hello Everyone,
I am a self confessed noob at templates and I know I have the wrong syntax below.
But can someone help me with the right coding to display the sunrise time on the screen. The string works in the developer tools.
- type: cardEntities
title: Weather
entities:
- entity: sensor.sun_next_rising
value: {{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom ('%H:%M %p') }}
