Can the Sonoff RFBridge send and receive 433mhz or only send?
This question is off-topic. The answer is here (both). If wish to discuss its capabilities, please start a separate thread. Thank you for your cooperation.
Thank you and my apologies.
I have a Sonoff Bridge 433 MHz (Tasmota / Portisch) running via MQTT on the HA. I want to use it to switch my shutters. If I set option RfRaw 166 I get the following code:
tele / tasmota_C3B1F5 / RESULT = {âTimeâ: â2020-11-02T09: 15: 30â, âRfRawâ: {âDataâ: âAAA606012CFF86713355â}}
How can I send that now? If I copy it into the command line, nothing happens.
If I set the RfRaw 177 option, I unfortunately donât receive anything âŚ
I have already received several other codes with the RfRaw 177 option and have also converted them, so they can be switched with Home Assistant without any problems.
I hope you can help meâŚ
Which one of the two strategies that I have presented are you using to receive the data from tele/tasmota_C3B1F5/RESULT
I go to the console in the Tasmota software and set the option RfRaw 166, then I send the commands up / down / stop with my old house control and receive the above-mentioned data.
Now I would like to integrate this data into HA.
I currently have the following command:
cover:
- platform: "mqtt"
command_topic: "cmnd/tasmota_C3B1F5/Backlog"
payload_open: "RfRaw AAA420F80110033001232355; RfRaw 0"
payload_close: "RfRaw AAA606012CFF86711155; RfRaw 0"
payload_stop: "RfRaw AAA606012CFF86715555; RfRaw 0"
But unfortunately it doesnât work !!!
This entire topic is about the two strategies I presented to receive data (see the first post). It is not a general topic for configuration problems with Tasmota software. Please create a separate topic to discuss it. Thank you.
This is great, thanks for sharing! I also added a IR tx/rx to my bridge and trying to make the second strategy to work when receiving both types of payload, RfReceived.Data and IrReceived.Data. But I am struggling to do this⌠is there a way to use a OR condition in the service data field of the automation so I could pass the data from both payload types to the script?
If you mean the payload can contain RfReceived.Data
or IrReceived.Data
then try this:
- alias: 'rfbridge_demultiplexer'
- platform: mqtt
topic: tele/RF_Bridge/RESULT
- service: python_script.rfbridge_demux
data_template:
payload: >
{{ trigger.payload_json.IrReceived.Data
if trigger.payload_json.IrReceived is defined
else trigger.payload_json.RfReceived.Data }}
Thank you so much, this is exactly what I was looking for!
Off topic, sorry.
Your question is about how to interpret battery levels and is not what this topic is all about. Please create a separate topic. Thank you.
Hi Taras.
I can hardly believe that Iâve been using this since May 19, without issue. Such an excellent contribution to HA.
Are we any nearer to understanding the issue with 0.117? Iâm itching to upgrade but the demux is too valuable to me to risk it breaking.
Iâm on 0.117.6, and the demux still works flawless ?
Glad to hear it.
I have no idea why some users are experiencing unusual behavior with python 3.9. Given that Home Assistant is not yet using version 3.9, I have not invested much time in investigating the issue.
What I have done is explore how to incorporate the recent automation enhancements to eliminate the need for a python_script. In other words, the goal is to create a single ârfbridge_demultiplexerâ automation that operates without the use of the python_script integration.
Based on a few tests, I believe this achieves the goal:
mode: parallel
variables:
data: { '2C8D0A':['sensor1','ON','true'],
'2C8D0E':['sensor1','OFF','true'],
'E5D30E':['sensor2','ON','false'],
'30D8A0':['sensor3','ON','false'] }
- platform: mqtt
condition: '{{ trigger.payload_json is defined }}'
- choose:
- conditions: '{{ trigger.payload_json.RfReceived.Data in data.keys() }}'
sequence:
- service: mqtt.publish
topic: 'home/{{ data[trigger.payload_json.RfReceived.Data][0] }}'
payload: '{{ data[trigger.payload_json.RfReceived.Data][1] }}'
qos: 0
retain: '{{ data[trigger.payload_json.RfReceived.Data][2] }}'
default:
topic: 'home/unknown'
payload: '{{ trigger.payload_json.RfReceived.Data }}'
qos: 0
retain: false
- service: persistent_notification.create
title: '<rfbridge_demux> Unknown RF code: {{ trigger.payload_json.RfReceived.Data }}'
message: '{{ now().timestamp()|timestamp_local() }}'
It was successfully tested with 0.117.5 with the default setting (true
) for the legacy_templates
option.
If at least two other people confirm it works for them, I will amend this threadâs first post and recommend using this automation (and deprecate the references to use a python_script).
EDIT 1
Added a Template Condition to reject received payloads that are not in JSON format.
EDIT 2
Inspired by Sagâs post below, added mode: queued
EDIT 3
Changed to mode: parallel
based on Sagâs post below.
Hi Taras,
Thanks indeed for your work. We really appreciate it.
Some of us use Espurna firmware on our RF Bridges. It works flawlessly. In spite Espurna can publish JSON messages, integration with Home Assistant is done using âMQTT platformâ, not âMQTT-JSON platformâ. Each message is sent to itâs own topic.
Your python script is working great with Espurna using a light ârfbridge_demultiplexerâ automation adaptation. Ie:
- id: '1586546570081'
alias: RF Topic MQTT desmultiplexaciĂłn
description: Distribuye MQTT recibidos de Espurna RF Bridge en varios topics
- platform: mqtt
topic: home/Sonoff-RF-Bridge-1/rfin
- platform: mqtt
topic: home/Sonoff-RF-Bridge-2/rfin
condition: []
- data_template:
payload: '{{ trigger.payload[-6:] }}'
mode: queued
max: 10
What do you think would be our best adaptation to your new script?
I believe you should change the condition
so that it ensures the length of the payload is greater than a minimum amount (otherwise the slice [-6:]
may fail).
Other than that, I think wherever you see trigger.payload_json.RfReceived.Data
used in the automation, it should be replaced by trigger.payload[-6:]
BTW, your usage of mode: queued
is a good precaution so Iâve added it to my example (above).
Do you mean something like that?
condition: â{{ trigger.payload | string | length > 5 }}â
Edit:
IMHO this automation system is less responsive than python script. I tried quite a lot and when some sensors are activated in a short space of time, only first or two first really do. I changed queued mode to parallel and achieved better results.
If someone use Espurna software on RF bridge (not JSON), maybe my working automation could be useful:
- platform: mqtt
- platform: mqtt
condition:
- condition: template
value_template: '{{ trigger.payload | string | length > 5 }}'
- choose:
- conditions:
value_template: '{{ trigger.payload[-6:] in data.keys() }}'
sequence:
topic: home/{{ data[trigger.payload[-6:]][0] }}
payload: '{{ data[trigger.payload[-6:]][1] }}'
qos: 0
retain: '{{ data[trigger.payload[-6:]][2] }}'
default:
topic: home/unknown
payload: '{{ trigger.payload }}'
qos: 0
retain: false
title: '<rfbridge_demux> Unknown RF code: {{ trigger.payload }}'
variables:
- Puerta_entrada
- 'ON'
- 'true'
123456:
- Puerta_entrada
- 'OFF'
- 'true'
987654:
- Batt_Puerta_entrada
- 'ON'
- 'true'
456789:
- PIR_hacia_entrada
- 'ON'
- 'false'
285683:
- PIR_hacia_cocina
- 'ON'
- 'false'
194628:
- PIR_pasillo
- 'ON'
- 'false'
394555:
- Detector_humo_cocina
- 'ON'
- 'false'
297634:
- Detector_humo_salon
- 'ON'
- 'false'
671299:
- Detector_humo_despacho
- 'ON'
- 'false'
999988:
- Detector_humo_dormitorio
- 'ON'
- 'false'
mode: parallel
max: 10
If just one more person confirms the new demultiplexer automation works, Iâll proceed to update the first post.
