The important issue is, i have 3 RF bridge, and i have 4 binary sensor activated by 4 key of a RF remote and i configured each key that go on or off with the same key/code, but if i receved the code with 2 RF bridge i can see the binary sensor go on and immediately go off because i receive the same MQTT message 2 times.
Not important issue is too many MQTT traffic, i have 7 PIR that send the code 4 times, and i can see many mqtt message.
EDITED:
this the configuration of the bynary sensor:
Good luck fixing it because thereās little available to make the job easy. At a minimum, you will need to use Strategy #2 (a heavily modified version of Strategy #2).
You will have to store the received payload (such as in an input_text). If the next one is a duplicate of the previous one then you ignore it. Because you have three bridges, all potentially reporting activity from the same remote-control, you may also need to track the topic (in order to identify the bridge).
If you have set your automationās mode to parallel then you may want to consider changing that (for example, to queued). Imagine two instances of the same automation (executing in parallel) trying to store the same payload to the same input_text at the same time (nothing good can come of it).
Iāve been trying a somewhat different approach, when the demux event is trigged I fire the python script and set an input_text with the code.
The condition to fire the demux automation should be that the code about to be handled is not the code in the input_text.
Itās still work in progress, but maybe you can help me with it too, as we are working on the same issue.
somehow I got an issue with testing trigger.payload_json.RfReceived.Data vs the state of lastcode so for now I have put in (hardcoded) the code my device is emitting.
And I made a new automation that changes the input_text (lastcode) to 000000 after 1 second.
See my previous post. It describes precisely what you are attempting to do (store payload in input_text) and also cautions against using mode: parallel (which your automation is using).
The automationās condition needs to compare the received payload to the input_textās value and execute the action only if the two values are different. While the payload is being stored in the input_text, you donāt want a parallel instance doing the same thing.
Iāve been thinking about this, and I think itās not the problem that it incorrectly detects it as a scientific notation (and yes it does), but that is incorrectly doesnāt detect that itās a hexadecimal value. Thatās why it also detects incorrectly that a hexadecimal value without letters is a decimal value.
I think my solotion of forcing a string is more consistent (for now), that way you can handle the value for what it is and not a string if itās hex with letters, and a number when itās hex without.
Yes, you are right, I didnāt read your post before I put mine in though, with my āIāve been trying a somewhat different approachā I didnāt mean to your suggestion but opposed to my previous approach.
Sorry, I should have read your post before posting something myself.
Because 8E52 is exactly scientific notation and only maybe hexadecimal.
You know itās hexadecimal because you know the source of the data produces hex numbers. The code processing it doesnāt know that and so it uses the ābest fitā for the stringās format (scientific notation).
Arguably, there should be some way to indicate to Home Assistant the valueās preferred type as opposed to it inferring the type based on its appearance. Anyway, for now, the technique you are using, prepending a non-numeric string to prevent the result from being interpreted as numeric, is the best recourse.
Yes, Iāve had some issues, but queued seems to fix that, thanks.
I also had the same translation issue again when detecting against the code, thatās why it was not working when I tested against the received code and I had to hardcode it to get a correct value.
Iām still testing, but as far as I see now I only get 1 MQTT transmission every time, this is my setup:
You probably only need to prepend a single character to prevent the string from being converted to an integer. It would simply need to be a non-hex character, any letter above F or perhaps a non-alphabetic character like # or punctuation like !.
Yes, I thought about that too, but I donāt know what that will do in other interpretations, in HTML # means HEX, and in Delphi/Pascal $ means HEX and ! often means NOT.
Iām not at all sure about python or yaml interpretations so I think ācodeā is not a reserved word/character and it describes the value pretty well.
@123 I think it takes too long to set the value, Iāve split up the automation into 2: 1 checking code 2 and 2 checking code 1, it works sometimes (I only see a code 1 one of the viarables) but sometimes I see the code in both the variables.
The triggers on the bridges are almost simultatious so it could happen that automation 1 is setting the code in the variable just after automation 2 is reading it to check.
I donāt know much about python in combination with home assistant, but would it be possible to check the input_text in the python code just before sending the MQTT message?
I think Iām going to make it easy on myself as I only have 1 sensor with this issue.
Iāll make 2 automations with 2 python scripts and I add the code for that sensor only in the python script of the RFbridge closest tot the sensor.
I hope you donāt mind but I will be asking the moderators to move your post to its own thread. This topic is for the discussion of what was presented in the first post and not every possible variation of how to receive data from a Sonoff RF Bridge. Thank you for your understanding.
BTW, what you presented looks good and merits its own topic as opposed to being the 336th post of this very long thread.
I too am āplaguedā by this. I have 2 Sonoff Bridges with same topic (as I have more than 30 sensors and using just one - did not seem to work ok - as it did not pick up all sensors), and used your method in order not to convert to str . And however, I still receive in logs the following:
Logger: homeassistant.components.python_script.rfbridge_demux.py
Source: rfbridge_demux.py:41
Integration: Python Scripts (documentation, issues)
First occurred: 10:25:49 AM (9 occurrences)
Last logged: 10:26:23 AM
<rfbridge_demux> Received unknown RF command: codeAD6B06
where the py script is:
d = {
'codeAD6B06':['livingroom_presence','ON','false'],
p = data.get('payload')
#p = str(data.get('payload'))
if p is not None:
if p in d.keys():
service_data = {'topic':'home/{}'.format(d[p][0]), 'payload':'{}'.format(d[p][1]), 'qos':0, 'retain':'{}'.format(d[p][2])}
else:
service_data = {'topic':'home/unknown', 'payload':'{}'.format(p), 'qos':0, 'retain':'false'}
logger.warning('<rfbridge_demux> Received unknown RF command: {}'.format(p))
hass.services.call('mqtt', 'publish', service_data, False)
you have your automation on mode: single that means only 1 instance of the automation can fire at the time, and your 2 bridges will fire almost simultatious, that will give the āalready Runningā error.
Maybe not a problem for you, you could change it to queued then it will wait for the first one to finish and then goes on with the 2nd.
In your example you fill the database ādā with the code, but you end that with a ā,ā now a 2nd line is expected but not there, I think you removed the other codes for this post and forgot to remove the ā,ā if not, that may be your problem.
Iāve stepped off from using 1 demuxer, I made 2 demuxers, and 2 topics for the bridges both handle all the codes except the one I only want once (toggle switch) that I just handle with the closest bridge.
They do both translate to the same MQTT topic in the end, in your case āhome/livingroom_presenceā
