Hello, this code will not report the current state after a restart home assistant.
Then youâre the first to experience that problem in the three years this code has been available.
Having used this for close on 3 years, other than problems of my own making, this has been rock solid.
Are you sure this isnât an MQTT problem?
I have around 10 binary sensors which are RF Switches. I mostly use them to turn on lights and a couple of scenes. After the change in home assistant these sensors now show unknown state and my automations do not work any more. I donât have any idea about python and scripts. i would appreciate your help top implement strategy 2 if possible. thank you in advance
All of the instructions for implementing strategy 2 are documented in the first post. Which part is unclear to you?
the false and true options is the confusing part for me. When do you use true and when false. Please note that all my binary sensors have no off code. They are single code rf buttons. Thank yoy for replying
Refer to the link posted by ashscott.
Thank you I will look it up
I feel very stupid. I canât make it work. I really need some help if you can.
I followed these instruction
- Add
python_script:
to yourconfiguration.yaml
file. - Create the following sub-directory:
config/python_scripts
- Restart Home Assistant.
Create a new file in config/python_scripts
called rfbridge_demux.py
with the following contents:
and put 4 of my sensors in this file like this
d = { '05C2D4':['blindb1','off','true'],
'0A89A8':['blindb2','off','true'],
'0A89A1':['blindb3','off','true'],
'0A89A4':['blindb4','off','true']
p = str(data.get('payload'))
if p is not None:
if p in d.keys():
service_data = {'topic':'home/{}'.format(d[p][0]), 'payload':'{}'.format(d[p][1]), 'qos':0, 'retain':'{}'.format(d[p][2])}
else:
service_data = {'topic':'home/unknown', 'payload':'{}'.format(p), 'qos':0, 'retain':'false'}
logger.warning('<rfbridge_demux> Received unknown RF command: {}'.format(p))
hass.services.call('mqtt', 'publish', service_data, False)
Then I created the bnary sensors as following
- platform: mqtt
name: 'Blind Button 1'
state_topic: 'home/blindb1'
device_class: door
- platform: mqtt
name: 'Blind Button 2'
state_topic: 'home/blindb2'
off_delay: 2
device_class: door
- platform: mqtt
name: 'Blind Button 3'
state_topic: 'home/blindb3'
off_delay: 2
device_class: door
- platform: mqtt
name: 'Blind Button 4'
state_topic: 'home/blindb4'
off_delay: 2
device_class: door
And finally created the automation
- alias: 'rfbridge_demultiplexer'
- platform: mqtt
topic: tele/RF_Bridge/RESULT
- service: python_script.rfbridge_demux
data_template:
payload: '{{trigger.payload_json.RfReceived.Data}}'
I need all sensors to show state âoffâ on home assistant start
Can you spot any mistake?
Thank you in advance
Newer version of HA does not check the state of a toggle sensor (sensor that sends only 1 signal code) and at boot it will be status âunknownâ. Move the switch and signal is sent and the status is known. Lets say on.
So at boot of HA send desired status as I explained in the other thread ashscott also mentioned: Report as âgoodâ instead of âunknownâ for MQTT binary sensor
Set off_delay for the sensor so that the new âonâ signal is a change for the sensor.
Hope this helps.
Yes, it appears that you didnât apply the advice suggested in ashscottâs link.
The challenge you are facing is not exclusive to the information presented in this topic (itâs affects all MQTT Binary Sensor entities, regardless if you use strategy 1, strategy 2, or neither strategy). Thatâs why you were referred to review the other topic.
However, if you donât want read the other topic, I suggest you add the following automation. The moment off_delay
sets a binary_sensorâs state to off
, it will trigger the automation and publish OFF
to the binary_sensorâs MQTT topic (as a retained message). On startup, Home Assistant will receive this value therefore the binary_sensor will not be unknown
alias: Publish off
mode: queued
- platform: state
entity_id:
- binary_sensor.blind_button_1
- binary_sensor.blind_button_2
- binary_sensor.blind_button_3
- binary_sensor.blind_button_4
to: 'off'
- service: mqtt.publish
topic: 'home/blindb{{ trigger.to_state.object_id[-1:] }}'
payload: 'OFF'
retain: true
In addition, I donât think this is correct:
When the RF code is received, it represents when the binary_sensor is on
and not when itâs off
. Change it to this:
d = { '05C2D4':['blindb1','on','true'],
'0A89A8':['blindb2','on','true'],
'0A89A1':['blindb3','on','true'],
'0A89A4':['blindb4','on','true']
Good morning, Thank you very much. I will review the suggested link again. Maybe I didnât understand the reason of suggestion. Sorry for that
thank you for the reply.
Unfortunately I canât get it working. I deleted everything and followd instructions very carefully (for strategy 2). when I press the button on my remote RF Bridge receives the code but all my binary sensors remain to unknown in the developer States , and do not change to anything else. Any help is appreciated.
Please post all relevant code you have. Creation of sensors, python script, automations, scripts.
Maybe I can help.
My advice is to frist make it work for 1 sensor and then add more by copy and small changes.
Is what you are using now the same as what you posted earlier?
If itâs not, indicate what is different.
Hello, thank you for offering to help.
I finally managed to get the sensors to work.
Thank you again
And what was the solution?
