Sonoff SNZB-03 motion sensor
Even if I put them in a paper box they still trigger. And the ZP01 in the same room does not trigger at all.
ZP01
afbeelding
This is the way to fix them
(still have to solder mine)
That sounds defective to me. There may be other glitches such as connection problems and if you want you should try mmWave presence sensors, they are relatively more reliable than Zigbee but will need a board (like ESP8266). Alternatively you can go for something fancy like Human Sensor 2A For Home Assistant By SCREEK (wifi,24G mmWave,LD2450,esp32c3) | eBay which has open source published on github repo that you can customize.
I have plenty of motions sensors, it’s just the Sonoff SNZB-03 s that I have problems with. One is still in its box, the two others are not really used any more, I put another brand next to them.
My Tradfri, Vallhorn, Aqara and ZP01 motion sensors all work reliable.
If I need more, it will be Vallhorn in the future. Cheaper then Sonoff, and rechargeable batteries
Hello gang - I’m late here. Just bought two SNZB-03P motion detectors. The first one paired no problem. Seems the occupancy sensor works fine but not motion? Motion is stuck in detected. Anything I can do?
It’s been more than 6 minutes without a change. What is the normal time it would stay in detected?
Thanks!
