Ill have to give this a go… do you have the node red config
I’ll do a full project write up with pictures and code on my github this week.
Be interested to know what you are using for that.
Cheers. I don’t see a fuse though?
Have a look at the data sheet in the link I posted it is built into the circuit.
Yeah I wasn’t sure if they are saying it is built in or needed to be added. The wording “Recommended fuse: slow blow type” led me to believe it might need to be added.
Yeah well spotted I didn’t read hard enough it does infer you need a slow blow type fuse, rather than continuing to hijack this thread I will start a new one with my install details in there.
Hello guys, I have an ifan02 and a Sonoff T1 1gang, both tasmotized.
I’d want to setup my T1 so that when I press the button one time, the fan light comes up and when I long press it, the fan cycles from 0 to high speed and so on.
How should I have to change the automation from this post to achieve that?
The T1 relay is not physically linked to ifan; I just wanna use MQTT to change the light status.
The same as the post author made with the ceiling…but for the light too
Sorry, I’m a newbie of this awesome world…
Thanks!!
