that is right, 6.4.1 is the firmware version. Will try. Just added
mqtt:
discovery: true
discovery_prefix: homeassistant
in the configuration.yaml and the MQTT broker ip address with that of the R Pi running hassio, just restarting
Tasmota console?? In the Hassio front end or is this in the TasmoAdmin gui?
never mind, got it!
like my friend Columbo, one more thing if you don’t mind. My project is to hard wire hack a device that has encrypted wifi using the electric imp card. It is a Budweiser goal light. I plan to take the speaker wire electric signals and use that automation to flash my lights at the same time. I currently use info from the NHL api for this, but it is a delay of 15-30 seconds, a lifetime really. Can you point me to where I can find any other settings I need to change on the D1 and what pinouts I would use. I will power the D1 for now with the usb cable but might add a battery shield or try stealing power from the 4 D batteries in the goal light. I have researched alot, but as I mentioned before, a bit burned out from info overload. If not, cool, thanks for your time and help.
set up the mqtt broker via the hass.io UI Configuration -> Integrations -> Set up a new Integration -> MQTT (and ensure there is no manual mqtt configuration left in the configuration.yaml file);
all Tasmota devices have their Full & Group topics altered from the default format via the following console commands FullTopic %topic%/%prefix%/ & GroupTopic %topic%/%prefix%/; and
all Tasmota devices have MQTT discovery enabled via the console command SetOption19 1.
If all this is done, then, following a hass.io restart, auto discovered Tasmota device HA entities will be found under: Configuration -> Integrations -> Configured -> MQTT section of the HA UI.
After much trial and error I finally adhered strictly to the above and presto all my Tasmota devices were discovered with bulk HA entities created.
Note it appears that with Tasmota v6.5.0 firmware a significant increase in the amount of sensor entities appear to have be being generated.
I’ve setup the mosquito broker using the default configuration. Put the following entry into my configuration.yaml.
broker: core-mosquitto. I’ve installed mqttfx and am able to connect to the broker, and publish messages. The mosquito log seems to inicate that devices are connecting to the broker (other than an occasional socket error-but then reconnects)
(from the mosquito log)
1558247865: New client connected from x.x.x.xx as sonoff_fan (c1, k10, u’myuserl’).
1558247910: Client sonoff_fan has exceeded timeout, disconnecting.
1558247910: Socket error on client sonoff_fan, disconnecting.
1558247910: New connection from x.x.x.xx on port 1883.
[INFO] found myuser on Home Assistant
1558247912: New client connected from x.x.x.xx as sonoff_fan (c1, k10, u’myuser’)
in the console of the devices i’ve turned on option19
I do get these errors in the HA log from time to time.
2019-05-17 04:24:25 ERROR (MainThread) [homeassistant.components.hassio] Integration not found: broker 2019-05-17 04:26:36 ERROR (MainThread) [homeassistant.components.hassio] Integration not found: broker 2019-05-17 04:27:31 WARNING (Thread-11) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 1 s 2019-05-17 04:27:31 WARNING (Thread-9) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 1 s 2019-05-17 04:27:32 WARNING (Thread-11) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 2 s 2019-05-17 04:27:32 WARNING (Thread-9) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 2 s 2019-05-17 04:27:37 WARNING (Thread-11) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 4 s 2019-05-17 04:27:37 WARNING (Thread-9) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 4 s 2019-05-17 05:13:58 WARNING (Thread-11) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 1 s 2019-05-17 05:13:58 WARNING (Thread-9) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 1 s 2019-05-17 05:13:59 WARNING (Thread-11) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 2 s 2019-05-17 05:13:59 WARNING (Thread-9) [homeassistant.components.mqtt] Disconnected from MQTT (1). Trying to reconnect in 2 s.
and under the hassio tab system option I get a bunch of this
19-05-19 06:47:49 INFO (MainThread) [hassio.auth] Auth request from core_mosquitto for myuser
19-05-19 06:47:50 INFO (MainThread) [hassio.auth] Success login from myuser
oh and i’ve reflashed bunch of times so starting with a fresh install. previously, i’ve had the devices emulate wemo and they have all shown as entities.
