You could go back to 6.3.0 with 2.3.0 core. I have been using 6.4.1.x with core 2.5.0 because there’s some new features and for some inexplicable reason I get a lot of problems when I try to use 2.3.0. I’m currently on 6.4.1.18… as I said the last 6 or so 6.4.1.x’s caused boot loops as well… I think when the next real release comes out I’m going to try 2.3.0 again - the pre-compiled binary… I wish I had never seen 6.4.1 as it rolled out core 2.4.2 which is an utter piece of shit in my use anyway. The beta’s of 2.5.0 were horrible as well. I still get dropouts with the released 2.5.0 but nothing that has been an issue… guess I’ve been lucky the dropouts haven’t coincided with a trigger eh?
When I first started having problems I did raise an issue but they seems more concerned with immediately closing issues over there, or saying it’s not Tasmota and just flat out denying there is any problem unfortunately.
If you can, go 6.3.0 with core 2.3.0 - I had zero dropouts with that release.
You will need to flash the minimal first and then the one-off one… You shouldn’t have any problem with the normal one once it has minimal on it it will stop the boot loop.
So tried as suggested and loaded a device on 6.3.0 but not being discovered by HA…
SetOption19 1 and sonoffs/cmnd/state.
Also running latest version of HA.
Any suggestions??
have you checked the devices in home assistant? There were changes to the topics in 6.4.x and you might need to revert back to pre 6.4.x topics… You should still see them in HA though in devices.
I reflashed one of my S22’s with 6.3.0 yesterday and it was working fine with discovery. I switched to discovery as soon as the Mosquitto broker was upgraded to v3 (now V4). It was working fine with discovery and 6.3.0
I picked a 6.3.x point release which has given me stability but some strange behaviour…
My automations are firing the tasmotas on and off fine but the switches in the ha GUI don’t work. Turn on but not off… any ideas what could be going on there?
