ors_86
(Orestis)
21
Yes, i restart HA everytime after changes to the config file.
manufacturer: SONOFF
model: TH16
sw_version: PSA-BHA-GL v3.5.0
local: online
rssi: -71
unit_of_measurement: °C
friendly_name: Dining Room Radiator Temperature
device_class: temperature
After change mode: from cloud to local temperatures does not appear:
Tamsy
(Tamsy)
22
Your configuration looks OK to me. Under Attributes I am missing temperature, humidity etc. though.
Are you running AlexxIT/ SonoffLAN and the eWelink Integration in parallel? If so remove the eWelink Integration.
ors_86
(Orestis)
23
I only use AlexxIT/ SonoffLAN - not eWelink integration.
What i should check for temperature, humidity etc under Attributes?
Tamsy
(Tamsy)
24
Try the following in your configuration.yaml:
sonoff:
username: [email protected]
password: ****
mode: local
reload: always # update device list every time HA starts
force_update: [currentTemperature, currentHumidity, voltage_00]
scan_interval: '00:00:30' # (optional) default 5 minutes
sensors: [currentTemperature, currentHumidity, voltage_00, rssi]
devices:
100114ad74:
device_class: switch
devicekey: your-devicekey
sensors: [currentTemperature, currentHumidity, rssi]
ors_86
(Orestis)
25
Tested - Issue persists
Seems that the issue i am facing has to do with that bug.
–UPDATE –
After that fix refresh interval is more offen but its not the same for all sensors.
bwillyb
(Bwillyb)
27
Any exemple of automatism?
I have set auto
If sensor below 16 degrees turn on switch sonoff.
It runs but just one time
How to set recorsively?
Ryukenden
(Kevin)
28
dont you need to set a turn off value too?
like if above 23 turn off, else the switch will be on forever?
