Yea, the few only lasted a day or so. I will have more soon - sign up for an email when they come. Iām waiting on a pcb order that took longer than usual. The parts are in transit now should hopefully arrive later this week.
Yes - Iāve been doing this via US Postal Service āinternational first class parcelā delivery is 1-3+ weeks. Prices range ~$14-19 depending on destination.
Iāve seen some packages make it to destination in 4-5 days (London, UK) others sit waiting for a flight in the New Jersey/New York area for a week or more. Or seem to drop off tracking as they pass on to other postal systems.
Good to know this USB Zigbee 3.0 dongle is now available, but I expect some important disadvantages:
The antenna / radio design is probably not delivering a satisfying Zigbee RF coverage within a medium sized house. This may cause connectivity loss to sensors or the need for 1 or more Zigbee repeaters in the house.
These issues have been described earlier in this thread.
Also, this USB dongle usually needs to be plugged into your computer running your HA software. This is not ideal if you want to install your Zigbee transceiver at a centrally located place in your house, connected hardwired to a LAN.
Yes, but it should not be the intention to install (mains powered) zigbee devices in a network solely for the Zigbee repeater function and improve Zigbee coverage around the house.
I would expect from a decent Zigbee coordinator at least a decent antenna design (incl gains) and Zigbee RF range around it. And preferably with a UTP/LAN connection.
This inexpensive ITead Zigbee 3.0 USB dongle is very cheap for what you get, but clearly has its limitations in practical use for a mid-sized or larger house / outdoor coverage.
Zigbee is designed to take advantage of network mesh function to extend range + coverage.
This is by design as a solution to the fact that Zigbee devices are low-power and operate at 2.4GHz so their signal penetration through walls is bad. Creating a network mesh with Zigbee routers is how you are supposed to extend range and coverage, at least if talking about low-powered Zigbee devices for home automation.
As a general rule, you want to have a backbone with a few good/stable always-on devices acting as Zigbee Router spread around your house that makes up the core of your Zigbee network mesh.
As an example; IKEA even bundled a Zigbee signal repeater with its battery operated window blinds.
Yes everyone buying a Zigbee coordinator device should try understand that each implementation will be different, and a great quality fully positional external antenna on a Zigbee dongle can compensate for a lot so everyone should keep that too in mind when comparing implementations with onboard circuit-board antenna versus SMA-connector or IPEX/uFL + a high-quality external antenna as well as several choices of USB-to-Serial/UART chips when it comes to USB adapters.
Antenna design and quality can and normally do make a night and day difference, however they can not compensate for an underpowered radio, but fact is that the EFR32MG21 ITead use is not underpowered.
EFR32MG21 is newer (released later) and on paper the EFR32MG21A020F1024IM32 is more powerful plus have slighly more onboard resouces than the CC2652P, but I think that in practice for average users in a real-world scenario the MCU raw specification of Silicon Labs EFR32MG21 and Texas Instruments CC2652P on a data-sheet comparison will not be as important as antenna quality and antenna positioning.
I really donāt think it will be limiting in the real-world as the chip it uses should offer much better radio performance than other USB adapters, but of course it would be a better product with external antenna.
You should compare it to the popular ConBee II cannot support more then five Zigbee 3.0 child devices.
Again, best practice with any Zigbee mesh network is still to always have a mains operated device acting as a Zigbee router installed in each and every room that has a battery operated Zigbee device.
Make you a deal; I wonāt praise it more based on its specs if you promise to not doom it in advance.
OK, I appreciate the additional comments above and think it all makes sense.
Question: this $7 ITEAD Zigbee 3.0 Dongle (with EFR32MG21 MCU), does it has a possibility for soldering a connector to the print board to screw an external (high performance) antenna to it?
Of course you can, soldering SMA or IPEX/uFL connector used to be a common practice before such USB sticks models were available. Google CC2531 + antenna hack or antenna mod or modification:
If I remember correctly; Mat from NotEnoughTech did some real-world range testing on the Sonoff ZBBridge getting results that he was very impressed by, and it only has this type a basic FPC antenna:
