The apology was for suggesting the alternative meaning for ‘pull request’.
Documentation pulls are a lot easier than code pulls.
Great! working fine for me … many thankx …
Hi All,
If you are using MAC or Linux please see this:
I ran into this topic wanting to upgrade the firmware, and made it easier for myself for the next time
If you run into anything let me know.
@belastingvormulier Thank you for your script! It worked very well. On my mac it made some problems at first, probably again because of the m1, but on my debian (proxmox) server it worked without problems. (At least after i looked what the requirements were and installed them
Using this on Arch, after hitting y to proceed I get:
# Get device ready for flashing:
This is a debug log
This is an info log
This is critical
An error occurred
/dev/ttyUSB0 - Sonoff Zigbee 3.0 USB Dongle Plus
选择串口(输入串口序号即可):
Hit enter after this, and supplied the dongle’s address (that same /dev/ttyUSB0) and hit enter again:
# Please supply the serial port again:
/dev/ttyUSB0
# Flashing the device:
sonoff
Opening port /dev/ttyUSB0, baud 500000
Reading data from CC1352P2_CC2652P_launchpad_coordinator_20220219.hex
Firmware file: Intel Hex
Connecting to target...
CC1350 PG2.0 (7x7mm): 352KB Flash, 20KB SRAM, CCFG.BL_CONFIG at 0x00057FD8
Primary IEEE Address: 00:12:4B:00:24:C1:73:A4
Performing mass erase
Erasing all main bank flash sectors
Erase done
Writing 360448 bytes starting at address 0x00000000
Write 104 bytes at 0x00057F988
Write done
Verifying by comparing CRC32 calculations.
Verified (match: 0xddfc152d)
# Cleaning up env, Till next time!
…and everything seems to have worked on three dongles, just a little confusing on the output. Thanks regardless!
Hi There,
Glad It worked, The output is indeed MEH at best… But the reason is that I wanted to keep things as “Original” as possible ( I do not have evil intentions, but you never know
) now you can easily verify the sources and stuff!
Hey all, I’m trying to use the script above but I’m getting a timeout. The dongle shows up as /dev/tty/ACM0 also but neither port seems to work. I have the E variant of the dongle.
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220811144022-if00
sonoff
Opening port /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220811144022-if00, baud 500000
ERROR: Timeout waiting for ACK/NACK after 'Synch (0x55 0x55)'
I didn’t actually use /dev/serial or /dev/tty/ for mine. The script scanned the ports and displayed the exact text I needed to type in. In my case it was
/dev/ttyUSB1
note there’s no / inbetween tty and USB, and USB needed to be in caps to match the output the script gave me
Mine mapped to /dev/ttyACM0 but that didn’t work for the script. It’s working fine in Zigbee2MQTT but I can’t get the firmware update. I suppose I can probably leave it as is for now.
I have taken the bash script from @jerrm (see above, May 12th) as base and enhanced it including several checks for ease of use. In the meanwhile from when he created that script, the router and the dev firmare has been removed from z2m. This caused the original script to fail.
With the new changes incorporated, steps are now modular and can easily be commented for testing, You can also quickly identfy the USB port used, repsectively the script denies flashing if no Sonoff stick is connected. I also took care that the pip dependencies are handled by the bash script (and are then only checked by the python flasher) so you are in better control of these.
I can state that flashing my Sonoff using the new script was a no brainer. For all who are interested, you can download it at: firmware_sonoff.sh (dont forget to make it executable
If there will be once a new firmware, adapting the script is quite easy as you - as far I have understood the upgrade process - only need to fix the downloaded firmware filename.
A big step above my notes in script form.
Try this to pull down the current versions without needing to edit urls.
Consider it untested pseudo code. I did a quick check on the snippets, but not in context of the whole script.
download_firmware () {
# https://github.com/Koenkk/Z-Stack-firmware
cd $basepath/$tmp
git clone https://github.com/Koenkk/Z-Stack-firmware.git
if [ $1 == "dev" ]; then
git -C Z-Stack-firmware checkout develop
fi
for f in Z-Stack-firmware/$2/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_$2_*.zip
do
unzip $f
done
flash_firmware () {
# for more options see: https://github.com/JelmerT/cc2538-bsl#cc26xx-and-cc13xx
python $basepath/$tmp/cc2538-bsl.py -evw -p \
/dev/ttyUSB$3 \
--bootloader-sonoff-usb \
$basepath/$tmp/*.hex
I had the same issue. I’ve read in a different post that the serial channel might be used by other applications.
I’ve stopped home assistant
ha homeassistant stop
<<do patching here>>
ha homeassistant start
Be sure to check you have the updated script. This flag should be in the flash_firmware() function
Same issue here, works fine in Z2M, but I cannot update firmware.
Z2M is not running, I’ve tried it with designating port:
sudo python3 cc2538-bsl.py -ewv -p /dev/ttyUSB0 --bootloader-sonoff-usb ./CC1352P2_CC2652P_launchpad_coordinator_20221226.hex
and without designating port:
sudo python3 cc2538-bsl.py -ewv --bootloader-sonoff-usb ./CC1352P2_CC2652P_launchpad_coordinator_20221226.hex
Also tried doing both with jusy ‘python’ vs ‘python3’ and get ACK/NACK error, also tried it on two widnows machines, same timeout errors.
I have the Sonoff Dongle Plus-E
/dev/ttyUSB0 designates a port in linux, under Windows it will be something like COM3, however you have to make sure you have the drivers installed. This video helped me:
Flashing Sonoff Zigbee Dongle Plus in Windows (Python Method) - YouTube
Caveat: I have the -P version of the dongle, but I don’t think that matters
“P” vs “E” makes all the difference. Different chips, different firmware, different methods, different tools.
cc2538-bsl is a tool for the TI chip in the ZBDongle-P.
See @Hedda’s ZBDongle-E post for links to tools and firmware for the SI Labs based ZBDongle-E.
I was able to update the sonoff firmware with this program, very quick and simple
It was the only one I could try in every possible way, this is the only one that really worked…
Anybody wrote a detailed article how I can do this with HA running on a RPI4 installed using the provided HA Image ?
Or is there even a HACS integration which flashes the device?!
Sorry, you cannot update the firmware of the stick while plugged in to a PI with HA running.
Hello, I have read this thread and there is still one question that was not explicitly asked and answered. Please could you confirm wheather the Zigbee dongle will work the same way after flashing without need to re-pairing all zigbee devices?
My setup is Sonoff Zigbee 3.0 USB stick P + Zigbe2MQTT (Docker) + HA (Docker)
Thank you for your advise
