Hey guys - just to make sure I got this all right: Currently nobody has a working TTS solution with Sonos while using DuckDNS and Let’s Encrypt?
For me it also failed a couple of weeks ago (probably after an update to Sonos?) - I don’t have any error in the HA but the “connection lost” error in the Sonos App.
I did consider switching to Remote UI via NC, but didn’t want to rely on a cloud service for that (even though it would be more secure as it wouldn’t need an open port…). Doing it just for TTS also appears a bit much, but alas…
Thanks for the feedback! I used this opportunity to activate remote access via Nabu Casa, removed the DuckDNS add-on, deactivated SSL and removed the port forwarding. Took some digging through the logs to clean up atferwards, but appears to be working fine.
Just to add to the data. Same problem. I’m an HAOS install running on Raspberry Pi 4 hardware. Sonos worked correctly for over a year up until I upgraded from 2021.9.3 to 2021.10.0. I use DuckDNS/Let’s Encrypt and a pfSense firewall with a loopback configured for the https address. I can control the SONOS devices (volume, playlists, radio, etc), but cannot TTS or play MP3’s stored on my HA device.
After researching this for a while, I think the problem is being caused by two factors that occurred within a few weeks of each other. First, the Let’s Encrypt root certificate server changed from DST Root CA X3 to ISRG Root X1. Subsequently, Sonos seems to have locked down their devices to only accept SSL requests from a certain pool of certificate authorities, DST Root CA X3 being one of them, but ISRG Root X1 not making the cut.
Personally, I don’t think this gets fixed until Sonos relaxes their SSL certificate standard a bit. They won’t even accept SSL’s from Sectigo, which is one of the largest SSL providers on the planet. We should all lodge a complaint in the Sonos TS forums. https://en.community.sonos.com/
@mdok No, after configuring nginx DuckDNS addon is still enabled and using the same hostname. Only had to remove the following lines from config and add the trusted proxy as mentioned above.
I’m not sure mdok. I would be interested if those who are working with Nginx are using the Let’s Encrypt SSL or are using something else. I haven’t been able to deduce that from the postings above.
It has been a couple of weeks, but I’ll try my very best:
Activate external access using Nabu casa cloud and test if everything works [I use my mobile phone].
Deactivate DuckDNS add-on and remove everything connected to it from config.yaml. Scan all YAML files for references to your duckdns.org domain and reconfigure.
Set internal URL to local IP / DNS name without SSL in Settings, leave external URL open.
Restart and test with new URLs (internal IP:8123 without https)
Reconfigure companion app
Watch log for SSL errors - it should point you to where you might have to reconfigure stuff.
I had tons of SSL errors until I reconfigured all companion apps and everything that tries to access HA via https. Took some time and digging around, but since then everything is fine.
As far as performance goes, accessing lots of data in the local network (graph over many data points etc) seems to be a bit faster, external access is roughly the same performance. So far very good reliability of NC cloud.
That’s the beauty: The connection to NC Cloud is being initiated by HA from inside your network, so no port forwarding and no fixed IP / DynDNS necessary. As long as you trust NC that they don’t spy on your traffic (and you can review the code as it’s open source, see here: Remote UI) it’s actually more secure as your HA instance is not reachable from the internet.
Unfortunately “openssl” can’t be run in the terminal and the parameter “preferred-chain” is not supported by the Duck DNS add-on
21-11-01 11:17:50 WARNING (MainThread) [supervisor.addons.options] Option 'preferred-chain' does not exist in the schema for Duck DNS (core_duckdns)
21-11-01 11:17:50 WARNING (SyncWorker_0) [supervisor.addons.options] Option 'preferred-chain' does not exist in the schema for Duck DNS (core_duckdns)
