So, I tried changing the order of the Media player join/snapshot, to see if that made any difference, but alas no - it still plays only on the master (Kitchen). Below is my complete automation code for:
Join all Sonos speakers to Kitchen (master)
Take snapshot
Increase volume of Kitchen (hopefully on all, as they should now be a group)
Play audio (on Kitchen only - same rationale as above)
Restore snapshot (which should reset all speakers back to their original settings)
If anyone can work out why this isn’t working as planned, I’d be very interested in hearing any suggestions.
- id: '1733089602173'
alias: Front Door Motion New
description: ''
triggers:
- trigger: state
entity_id:
- binary_sensor.front_door_motion_sensor_motion_sensor
to: 'on'
conditions:
- condition: state
entity_id: input_boolean.front_door_motion_detected
state: 'off'
- condition: state
state: closed
entity_id: cover.main_garage
- condition: state
entity_id: input_boolean.sonos_announcements
state: 'on'
- condition: or
conditions:
- condition: state
entity_id: input_boolean.darrell_at_home
state: 'on'
- condition: state
entity_id: input_boolean.barbara_at_home
state: 'on'
actions:
- action: media_player.join
group_members:
- media_player.laundry_room_sonos
- media_player.guest_bedroom_sonos
- media_player.darrells_office_sonos
- media_player.barbaras_office_sonos
- media_player.master_bedroom_sonos
entity_id: media_player.kitchen_sonos_1
- action: sonos.snapshot
with_group: true
- action: media_player.volume_set
volume_level: 0.77
- action: media_player.play_media
media_content_id: /local/sounds/front_door_motion.mp3
media_content_type: music
announce: true
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- action: sonos.restore
with_group: true
mode: single
I have the same issue, but didn’t get to investigate it that much as you yet. However, what I read somewhere is this:
announce: true means the current playback will lower volume, announcement will be played over it, and when it finishes, playback volume is restored. However, it doesn’t respect groups and when played on multiple speakers, it’s out of sync.
announce: false means it plays as normal media. Therefore it stops current playback, plays the announcement, and then stops. The upside is - it respects groups and plays in sync on multiple speakers.
So it looks like we can have either current playback undisturbed (continues playing after announcement), or announcement in sync on all speakers, but not both.
That announce does not respect groups is interesting and worrying, as announce is a valuable option.
One approach I’ve found that ensures that audio is played on all the speakers is to create a helper “media” group, which contains all the speakers and reference that as a single entity. However, this does not guarantee that the speakers are always played synchronized. (They are for about 80-90% of the time.)
Originally, I had:
Take snapshot of one speaker (usually my kitchen Sonos)
Play announcement (with Announce = true)
Restore, again on the same Sonos speaker
This worked fine for a while. Any music was paused, the announcement made (at the same level of the music, as I didn’t attempt to adjust volume), then music resumed after the announcement. The reason I abandoned this was (a) I could only use it the Sonos speakers - I have a mix of both Sonos and Apple HomePods, and I could never get it to work on the HomePods, and (b) sometimes the odd Sonos speaker would go “offline” for some bizarre reason.
I then started using the Chime_TTS integration, again using the helper group of speakers. This is what I have in place today. Again, it works fine, but sometimes has synchronization issues. One advantage is that I can also include HomePods, but generally there’s a 1-2 second delay between audio coming out of the Sonos and the HomePods (apparently due to the AppleTV integration). This integration also allows you to adjust the volume for any announcements and resets it afterwards.
@123, would you be willing to share the script of your own invention where you use the snapshot/restore? Currently, I have my announcements working with speaker groups using join/unjoin using @Nimrod_Dolev’s Chime TTS. Announcements at in sync, but they interrupt any existing playback since I can’t use announce=true due to aforementioned sync issues. I am hoping to make them compatible with pausing/restoring existing playback. Thanks!
The announce feature can be problematic and both the Sonos and HomePod integrations have their issues, but perhaps try using the Chime TTS parameter fade_audio parameter instead of announce.
Thanks for the idea, @Nimrod_Dolev. I did try it, but without preceeding with sonos.snapshot, and following with sonos.restore, the fade_audio being set to true fades out, but does not resume playback afterwards. When I add the snapshot/restore, it does work, but there seems to be a delay beyond just the time it takes to fade out the track.
Taking fade_audio aside for a moment, this seems to be working OK to pause whatever is playing, play the announcement, and then resume whatever was playing.
alias: Announcement test
sequence:
metadata: {}
with_group: true
entity_id: all
- action: chime_tts.say
message: hi there!
tts_platform: microsoft
chime_path: twenty_four
join_players: true
unjoin_players: true
entity_id:
- media_player.sonos_1
- media_player.sonos_2
- media_player.sonos_3
- media_player.sonos_4
- media_player.sonos_5
- media_player.sonos_6
metadata: {}
with_group: true
entity_id: all
mode: single
