I am working on that. I already made a PR for the PSK version, but that was rejected as it was an extra component next to the existing Bravia (PIN version) component.
So I have now made a new version which combines both the PSK and existing PIN connection to one component. It’s available at:
As I want to be sure the current PIN version stays working correctly for people using that version, I am looking for some people to test that part. Currently it’s tested by one user, but some more would be better.
So if there are any other people willing to test that version to see if the PIN connection is still working then that would be great
That new version should be put into custom_components/media_player? Or should I replace bravia component in the HA install? (I’ve got 2015 Android TV model if that matters)
So I’m running the latest version and now have it configured to 3 different Sony TVs. All are running with a different PSK and all seem to be working.
I can also report that ATSC is working, and the channels do show up as a Source and the program info displays correctly.
Is there a way I can manually add channels to the source list? The ATSC channels are in the same “Channels” app as the HD Homerun channels. Even though I’m not seeing them as a source, could I manually add a channel as source?
What is shown as source on the states page (dev tools) when you have selected a HD Homerun channel?
Maybe I can add that source just I did for tv:atsct.
Source isn’t listed when it’s on an HD Homerun channel. It does appear as “tv:atsc” when on one of the antenna channels.
However, the guide displayed on the TV integrates the Antenna (ATSC) and HD Homerun channels into one list. That’s why I was wondering if there was a way to force a channel into the source list to see if it would tune properly.
I just put that into my HA and got this in log:
2018-04-08 00:26:06 ERROR (MainThread) [homeassistant.setup] Error during setup of component media_player
File “/home/hassio/ha36/lib/python3.6/site-packages/homeassistant/setup.py”, line 145, in _async_setup_component
component.setup, hass, processed_config)
AttributeError: module ‘custom_components.media_player’ has no attribute ‘setup’
Yes. Exactly like this.
Edit 1:
Yesterday I updated 0.67.1 (that’s what .HA_VERSION shows) and just now I enabled your component without any problems. When I had probs with this earlier I just renamed custom_components to c_components and commented out relevant entries in configuration. Now I reversed all this and… it just works… Can’t say I understand… Must be something in the platform…
Anyway I’m testing this now
Edit 2:
Is it supposed to re-use bravia.conf created with HA media_player.bravia? I’m using PIN mode with Bravia Android TV 2015 (currently running Android 7.0). Your component cant distinguish between tv beeing on or off but that’s all it can. Can’t turn it of or on, can’t change volume can’t even see what’s playing. PIN is correct cause media_player.bravia works correctly at the same time
Can this component be used to extract the status of the App? I have a Sony Bravia Android TV, the default component only shows the input on HA. If I’m using any streaming service, it only shows ‘App’
I want an automation based on the status of the TV when streaming (idle, playing, paused etc)
Is this possible using this custom component?
This is working great for me, thank you so much!
Is it possible to now pass commands through home assistant via ifttt to select sources or channels etc?
It would also be great if we can set volume by percentage like in this video?
Hello, I just setup sony bravia tv with pre-shared key. I used default config setting from the github. However, I would like to be able to change the app like netflix and spotify. How do I put in the config or any other setting need. Please kindly advice.
- platform: braviatv_psk
host: !secret sony_ip
psk: sony
mac: !secret sony_mac
amp: False
android: True
sourcefilter:
- ' HD'
- HDMI
The media player in ha frontend show correctly, I can turn on/off. In Source show hdmi1-4. I would like to be able to change to netflix and other apps from ha frontend as well.
