Maybe i’ve overlooked it, but is there an option to select Netflix as a source?
Take a closer look at this page, it has a ton of information about commands.
Same issue here, any ideas?
Yes, the same as the answer given to the first question:
This component is for use with a TV, not a BluRay-Player.
Oh apologies, I was meant to say ‘similar’ my bad, also didn’t look at his code properly, and assumed it was the same error as mine. I don’t own a Blue-Ray player, but an Android TV.
I think the issue had resolved itself for now.
@gerard33 is it possible to implement the rest-api-call in pySonyBraviaPSK
and media_player.braviatv_psk
? I found out that the ircc-calls are somewhat unreliable with newer android-devices. So power off should be implemented similar to the power on behaviour.
edit: here are my PR for pySonyBraviaPSK and the custom-component
@Gagandeep90, would you mind sharing the yaml for your card? It would certainly save me alot of time.
Sure. I am using the mini media player for it.
artwork: full-cover
entity: media_player.xxxxx
power_color: true
shortcuts:
buttons:
- icon: 'mdi:netflix'
type: tvshow
- icon: 'mdi:arrow-up-bold'
type: tvshow
- icon: 'mdi:youtube'
type: tvshow
- icon: 'mdi:arrow-left-bold'
type: tvshow
- icon: 'mdi:circle'
type: tvshow
- icon: 'mdi:arrow-right-bold'
type: tvshow
- icon: 'mdi:keyboard-return'
type: tvshow
- icon: 'mdi:arrow-down-bold'
type: tvshow
- icon: 'mdi:home-circle'
type: tvshow
- icon: 'mdi:play-circle-outline'
type: tvshow
- icon: 'mdi:pause-circle-outline'
type: tvshow
- icon: 'mdi:stop-circle-outline'
type: tvshow
columns: 3
type: 'custom:mini-media-player'
volume: true
volume_stateless: true
Why the youtube button is not working for me ? Any help
Same problem, the Youtube button doesn’t work for me.
Florent
Hi Paul I have a similar generation TV to yours
Did you ever get anything working ?
The TV Sideview app still works, but it would be nice to integrate control with HA !
I gave up after a couple of days of hacking things … mainly because the TV is downstairs and I was upstairs writing code and it was a pain to test.
I could try again and use a laptop … no promises though.
That’d be awesome !
There’s also something funky going on with the Sony networking. I have my TV on an IoT VLAN. Even when I allow interVLAN routing, the TV SideView app can’t find the TV (even when given the IP address).
Put the phone and TV on the same VLAN and no problem.
I can’t work out what’s being blocked, as I’m able to access all my other IoT devices from my Trusted network. Not sure if it just can’t handle the different subnetting…
Release 0.3.5 is available on HACS which adds the following features:
The service
braviatv_psk.bravia_command
is added to Home Assistant to sendcommands
to your TV likeChannelUp
,Return
orUp
. This can be used to create a virtual remote or for your automations. More info here. Thanks @rchl -
For Android TVs the service
braviatv_psk.bravia_open_app
is added to openapps
on your TV likeKodi
orYoutube
. The apps must be opened via using theuri
of that app. More info here. Thanks @rchl -
It’s now possible to show the HDMI labels you have set on the TV. This means instead of e.g.
HDMI2
you can showSky Q
here. Thanks @RogerSelwyn -
Home Assistant >= 0.110 is supported by renaming
MediaPlayerDevice
in the code toMediaPlayerEntity
. This is backwards compatible so HA versions < 0.110 are also supported. Thanks @mories76
How to Power on Tv in automation all comands work in tv 9005 power by remote is on, media_player.turn_on work but braviatv_psk.bravia_command don’t wake up
could you share the code?
thanks
@Gagandeep90 already shared his code,a few posts under the picture.
Thanks its working
Can you tell me how can i add A button for Kodi,Spotify and IPTV ?
I have tried this
curl -H “Content-Type: application/json” -H “X-Auth-PSK: sony” -X POST -d ‘{“id”: 1, “method”: “getApplicationList”, “version”: “1.0”, “params”: [""]}’ http://192.168.1.143/sony/appControl
to get app list but it gives no list only this
curl: (6) Could not resolve host: 1,
curl: (6) Could not resolve host: method
curl: (6) Could not resolve host: getApplicationList,
curl: (6) Could not resolve host: version
curl: (6) Could not resolve host: 1.0,
curl: (6) Could not resolve host: params
curl: (3) [globbing] bad range specification in column 2
JSON Format Error
i have found this to open kodi and spotify but i don’t know how to put it on the remote.
curl -H “Content-Type: application/json” -H “X-Auth-PSK: sony” -X POST http://192.168.1.143/DIAL/apps/com.sony.dtv.org.xbmc.kodi.org.xbmc.kodi.Splash
curl -H “Content-Type: application/json” -H “X-Auth-PSK: sony” -X POST http://192.168.1.143/DIAL/apps/com.sony.dtv.com.spotify.tv.android.com.spotify.tv.android.SpotifyTVActivity
can someone help?
Hi Gagan,
would you mind to post the lovelace code for this mini-media-player card to save me some research & work?
