How to install vlc should be added to the documentation.
It would be great if you can help update and improve the documentation for the vlc component. In the upper right corner of any documentation page, you will find “Edit this page on GitHub”. Follow the link and submit your suggested change. Demonstrated here: https://youtu.be/dRfk9JAlPJk?t=1h16m17s
@Douz its possible to Add language Portuguese ? pt_PT or pt_BR?
I have change it to this…
tts:
platform: picotts
language: 'en-US'
…and it is still not working. Instead of using VLC, is it possible to use omxplayer which is already working in my system?
if omxplayer is a HA media_player component, yes you could use it
Sorry the library pico tts doesn’t support portuguese… I can’t help with that
ok no problem,thanks anyway,
The command line notification sounds like a good idea. May I know what is the correct command to use with picotts?
tts.pico_tts needs a media_player entity_id where it can send the wav-data.
