Show everything that you have regarding this custom:button-card.
- file in the directory structure
- entry in the resources
- your configuration.yaml file
What do you mean by rss?
Ok so to clarify.
downloaded the js from: Release v4.1.2 · custom-cards/button-card · GitHub
i tried to place it (upload it to the following dir) under:
/www/button-card.js
/www/community/button-card.js
/www/community/lovelace-button/button-card.js
The code that im trying to run is:
type: custom:button-card
entity: sensor.test_sensor
state: "1234"
show_name: true
show_state: true
styles:
card:
- padding: 2px
- background-color: white
icon:
- color: red
- width: 50px
- height: 50px
name:
- color: blue
state:
- color: green
icon: "mdi:home" # PNG check for later! It should work.......... i think
my config file contains:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
extra_module_url:
- /local/card-mod.js
- /local/button-card.js
themes: !include_dir_merge_named themes
# Set Lovelace to YAML mode (this will load ui-lovelace.yaml)
#lovelace:
#mode: yaml
script: !include scripts.yaml
scene: !include scenes.yaml
Everytime after changing and trying new location, i add the rss (resources) in the dashboard where i plan to use them.
And the step by step action im doing is:
upload js file to ANY location (i tried all)
go to dashboard and add the resource to where i plan to use it
restart HA
logout HA
clear cache/cookies from browser
close browser
open browser
login into HA
confirm the resource is still showing on the dashboard
add new card
select manual type
input the yaml code
get error message
Miguel, just do as I wrote before
This is because it cannot find the right file (button-card.js) at the right location, being the file
Do you block anything with an add-on in your browser?
It’s really simple:
Comment/or remove this whole section from your config file:
frontend:
extra_module_url:
This is another example of installing a custom card
Manual
slider-button-card.js
file from the latest-release.slider-button-card.js
file into your config/www
folder./local/slider-button-card.js
→ Set Resource type as JavaScript Module
.custom:slider-button-card
to Lovelace UI as any other card (using either editor or YAML configuration).Hello Nick, easier way to check my steps.
https://youtu.be/H8rHwEVd8oc - HA “murdering” the CPU since update
https://youtu.be/DWOZRh7WPLU - a 7min long video showing all steps
New error generated…
Can you try with a newly created custom button with the bare minimum?
So finally it works!
f… yes!
now i’ve done this before twice! why didnt it work??
Plus the code i wa susing in the first place, is it wrong??
I see no yaml errors
You know that the same input gives the same result so something must have been wrong.
Which code in which first place?
You mean the one from post #25?
this one:
state: "1234"
show_name: true
show_state: true
styles:
card:
- padding: 2px
icon:
- color: red
- width: 50px
- height: 50px
name:
- color: blue
state:
- color: green
No idea, there must be some error but at least you know that the foundation is correct now so you can chase what is wrong in the config of that card.
