Splitting config for template:
What am I missing? My sensors never show up in states!
this is what I did using your expamples.
made a folder templates, in it folder sensors and binary_sensors in those folders I placed yaml files with a sensor for instance, when I make a typo in them or leave out the word sensor: I get an error when i update template entites so ha looks in those files, that works some how
vb:
configuration. yaml
template:
  - sensor: !include_dir_merge_list templates/sensors/
  - binary_sensor: !include_dir_merge_list templates/binary_sensors/
in directory config/templates/sensors - file verbruik.yaml
# template sensor:
-   name: "waterverbruik looptijd"
    unique_id: '8775766800'
    unit_of_measurement: "sec"
    value_template: >
        {% set t = this.state if states('input_boolean.kraan_aan_uit') == 'off' else now().timestamp() - states.input_boolean.kraan_aan_uit.last_changed.timestamp() %}
        {{ t | round(2, 'common') }}
I used names with and without “” that did not matter, problem is HA does not register nor use those sensors I defined ???
het origineel is dit.
    sensors:
        duree_ecoulement_eau_principale:
          friendly_name: Durée d'écoulement de l'eau principale
          value_template: >
            {% set t = this.state if states('input_boolean.eau_principale_on_off') == 'off' else now().timestamp() - states.input_boolean.eau_principale_on_off.last_changed.timestamp() %}
Please
  1. You need to remove the “sensor:” line from the top of the file.
  2. You are mixing up configuration syntax. The new style templates use “state:” instead of “value_template:”.
Check the dics to see the differences.
yes, found that out
 had to use state.
plus I could not use !include_dir_merge_list it would not work had to use – template: !include templates.yaml.
Why I do not know but had to, could not leave out sensor: at the top of the file, it would not work.
TY
I actually found a way to have the flat structure I wanted in the initial post.
configuration.yaml:
templates.yaml:
- binary_sensor: !include template_binary_sensors.yaml
- sensor: !include template_sensors.yaml
# Triggered Sensors
- trigger:
    - platform: etc...
Personally, I find it easiest to break everything into folders and then have files in each folder for what they do.
template: !include_dir_merge_list template
e.g. file
Check my proposal.
It allows to split per functionality, not per particular types.
EDIT: Oh nevermind, you’re not saying as a feature request. My bad, that’s what you’re using
Yes, this config split I have been using for 2 years, very flexible and structural.
hey, i think is what im trying to do, are you abel to post a screenshot of how you set this up??
This is what im trying to achieve?
You can’t nest sub folders and use an include on the sensor folder.
I think I’m missing something here.
ATM I have a few templates working in my main configuration.yaml.
I’m trying to get a duplicate going from within templates.yaml. (Name Changed of course).
It doesn’t seem to be showing up.
I asume no reboot is required as the config check reports any errors when I have templates.yaml wrong.
Mine’s very simple, so my mistake must be basic.
Did try adding - sensor to the top of the file, but that caused an error on the line where - name is.
Can anyone help.
My Configuration.yaml,
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
template:
# Calculate Inverter Power
    sensors:
      net_power:
        value_template:
          "{{ ( states('sensor.sdm220m_3_power') | float | round(1)) -
          ( states('sensor.sdm220m_2_power') | float | round(1))}}"
        unit_of_measurement: "W"
        device_class: power
        #state_class: measurement #Causes Error
        friendly_name: Inverter Net Power
  # Calculate Inverter Production
    sensors:
      net_production:
        value_template:
          "{{ ( states('sensor.sdm220m_3_import_active_energy') | float | round(1)) -
          ( states('sensor.sdm220m_2_import_active_energy') | float | round(1))}}"
        unit_of_measurement: "kWh"
        device_class: energy
        #state_class: total_increasing #Causes Error
        #attributes:
        #  last_reset: "1970-01-01T00:00:00+00:00"
        friendly_name: Inverter Net Production
  # Calculate Inverter Production - Alternate Code
template:
  - sensor:
      - name: "Inverter_Production"
        unique_id: "inverter_net_prod_test"
        state: >
          {{ states ('sensor.sdm220m_3_import_active_energy') | float(2) | round(2)
          - states ('sensor.sdm220m_2_import_active_energy') | float(2) | round(2)}}
        availability: >
          {{ states ('sensor.sdm220m_3_import_active_energy') | float(none) != none and
              states ('sensor.sdm220m_2_import_active_energy') | float(none) != none }}
      - name: "Inverter_Net_Power"
        unique_id: "inverter_net_power"
        unit_of_measurement: 'W'
        device_class: power
        state: >
            {{ states ('sensor.sdm220m_3_power') | float(2) | round(2)
            - states ('sensor.sdm220m_2_power') | float(2) | round(2)}}
        availability: >
            {{ states ('sensor.sdm220m_3_power') | float(none) != none and
                states ('sensor.sdm220m_2_power') | float(none) != none }}
#  - sensor:
      - name: "Spa Temp Req"
        unique_id: "spa_temp_req"
        unit_of_measurement: '°C'
        device_class: temperature
        state: >
            {{ states ('input_number.spa_set_temp') | float(1) | round(1)
            - states ('sensor.gw1100c_v2_2_0_soil_temperature_5') | float(1) | round(1)}}
        availability: >
            {{ states ('input_number.spa_set_temp') | float(none) != none and
                states ('sensor.gw1100c_v2_2_0_soil_temperature_5') | float(none) != none }}
#  - sensor:
      - name: "Spa Temp Rise"
        unique_id: "spa_temp_diff"
        state: >
            {{ states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(1) | round(1)
        availability: >
            {{ states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(none) != none and
The templates.yaml I have created,
- name: "Spa Temp Need"
  unique_id: "spa_temp_need"
  unit_of_measurement: "°C"
  state: >
    - states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(1) | round(1)}}
  availability: >
        states ('sensor.gw1100c_v2_2_0_soil_temperature_6') | float(none) != none }}
template: appears three times in your configuration.yaml file. It should only be there once.
do you mind sharing a screenshot, im not following any of this and if i can see what you have done, it might make more sense??
It is described here
Really like this method, thanks.
I am trying to get filter sensors working and have not succeeded yet.
In my normal sensors.yaml this works:
- platform: filter
  name: "filtered unknown power"
  unique_id: filtered_unknown_power
  entity_id: sensor.unknown_power_usage
  filters:
    - filter: throttle
      window_size: 10
      precision: 0
my package yaml doesn’t like the platform version so I tried this:
the template and the mqtt parts DO work.
but the filter doesn’t it doesn’t have error messages in the editor, but it also doesn’t work.
template:
  - sensor:
      - unique_id: ecogene_discharge_trend
        attributes:
          friendly_name: EcoGene discharge trend
        state: >
          {% set rate = state_attr('binary_sensor.ecogene_trend','gradient') %}
          {{ ([rate, 0] |min)  | abs }}
        availability: >
          {{ state_attr('binary_sensor.ecogene_trend','gradient')|is_number  }}
filter:
    - name: "EcoGene PV current"
      entity_id: sensor.ecogene_pv_current_fast
      filters:
        - filter: time_throttle
          window_size: "00:01"
          precision: 2
mqtt:
    - name: "EcoGene PV current Fast"
      state_topic: "ecogene/N/b827eb5e1860/system/0/Dc/Pv/Current"
      value_template: "{{ value_json.value | float(0) | round(2) }}"
      device_class: current
      unit_of_measurement: "A"
      icon: mdi:solar-panel
After a restart I do get this error message:
Setup failed for filter: No setup or config entry setup function defined.
Thanks for any help.
Probably because you are using a wrong definition for this “filter” sensor.
Try this:
  - platform: filter
Any reason why one should not use packages over this?
I’ve found using a packages folder with individual yaml files per project/function/goal to be immensely easier and treating all my custom yamls like plug-ins.
For example, here’s the one for zigbee2mqtt with a variety of custom stuff (no modifications by me other than collecting it all in one place):
  • input_select
  • input_number
  • input_text
  • input_boolean
  • script
  • timer
  • mqtt
  • automation
All in one yaml file!
# Input select for Zigbee2MQTT debug level
input_select:
  zigbee2mqtt_log_level:
    name: Zigbee2MQTT Log Level
    options:
      - debug
      - info
      - warn
      - error
    initial: info
    icon: mdi:format-list-bulleted
# Input number for joining time remaining (in minutes)
input_number:
  zigbee2mqtt_join_minutes:
    name: "Zigbee2MQTT join minutes"
    initial: 2
    min: 1
    max: 5
    step: 1
    mode: slider
# Input text to input Zigbee2MQTT friendly_name for scripts
input_text:
  zigbee2mqtt_old_name:
    name: Zigbee2MQTT Old Name
    initial: ""
  zigbee2mqtt_new_name:
    name: Zigbee2MQTT New Name
    initial: ""
  zigbee2mqtt_remove:
    initial: ""
# Input boolean to set the force remove flag for devices
input_boolean:
  zigbee2mqtt_force_remove:
    name: Zigbee2MQTT Force Remove
    initial: false
    icon: mdi:alert-remove
# Scripts for renaming & removing devices
script:
  zigbee2mqtt_rename:
    alias: Zigbee2MQTT Rename
    sequence:
      service: mqtt.publish
      data_template:
        topic: zigbee2mqtt/bridge/request/device/rename
        payload_template: >-
            "from": "{{ states.input_text.zigbee2mqtt_old_name.state | string }}",
            "to": "{{ states.input_text.zigbee2mqtt_new_name.state | string }}"
  zigbee2mqtt_remove:
    alias: Zigbee2MQTT Remove
    sequence:
      data_template:
        topic: zigbee2mqtt/bridge/request/device/remove
            "id": "{{ states.input_text.zigbee2mqtt_remove.state | string }}",
            "force": {% if states.input_boolean.zigbee2mqtt_force_remove.state == "off" %}false{% else %}true{% endif %}
# Timer for joining time remaining (254 sec)
timer:
  zigbee_permit_join:
    name: Time remaining
    duration: 254
mqtt:
    # Sensor for monitoring the bridge state
    - name: Zigbee2MQTT Bridge state
      unique_id: zigbee2mqtt_bridge_state_sensor
      state_topic: "zigbee2mqtt/bridge/state"
      value_template: "{{ value_json.state }}"
      icon: mdi:router-wireless
    # Sensor for Showing the Zigbee2MQTT Version
    - name: Zigbee2MQTT Version
      unique_id: zigbee2mqtt_version_sensor
      state_topic: "zigbee2mqtt/bridge/info"
      value_template: "{{ value_json.version }}"
      icon: mdi:zigbee
    # Sensor for Showing the Coordinator Version
    - name: Zigbee2MQTT Coordinator Version
      unique_id: zigbee2mqtt_coordinator_version_sensor
      value_template: "{{ value_json.coordinator.meta.revision }}"
      icon: mdi:chip
    - name: Zigbee2mqtt Networkmap
      unique_id: zigbee2mqtt_networkmap_sensor
      # if you change base_topic of Zigbee2mqtt, change state_topic accordingly
      state_topic: zigbee2mqtt/bridge/networkmap/raw
      value_template: >-
        {{ now().strftime('%Y-%m-%d %H:%M:%S') }}
      # again, if you change base_topic of Zigbee2mqtt, change json_attributes_topic accordingly
      json_attributes_topic: zigbee2mqtt/bridge/networkmap/raw
  # Switch for enabling joining
  switch:
    - name: "Zigbee2MQTT Main join"
      unique_id: zigbee2mqtt_main_join_switch
      value_template: '{{ value_json.permit_join | lower }}'
      command_topic: "zigbee2mqtt/bridge/request/permit_join"
      payload_on: "true"
      payload_off: "false"
automation:
  # Automation for sending MQTT message on input select change
  - alias: Zigbee2MQTT Log Level
    initial_state: 'On'
      platform: state
      entity_id: input_select.zigbee2mqtt_log_level
      - service: mqtt.publish
          payload_template: "{{ states('input_select.zigbee2mqtt_log_level') }}"
          topic: zigbee2mqtt/bridge/request/config/log_level
  # Automation to start timer when enable join is turned on
  - id: zigbee_join_enabled
    alias: Zigbee Join Enabled
      platform: state
      entity_id: switch.zigbee2mqtt_main_join
      to: 'On'
      service: timer.start
      entity_id: timer.zigbee_permit_join
      data_template:
        duration: "{{ '00:0%i:00' % (states('input_number.zigbee2mqtt_join_minutes') | int ) }}"
  # Automation to stop timer when switch turned off and turn off switch when timer finished
  - id: zigbee_join_disabled
    alias: Zigbee Join Disabled
      - platform: event
        event_type: timer.finished
        event_data:
      - platform: state
        to: "off"
      - service: timer.cancel
      - service: switch.turn_off
  - id: "zigbee2mqtt_create_notification_on_successful_interview"
    alias: Zigbee Device Joined Notification
      platform: mqtt
      topic: 'zigbee2mqtt/bridge/event'
    condition:
      condition: template
      value_template: '{{trigger.payload_json.type == "device_interview" and trigger.payload_json.data.status == "successful" and trigger.payload_json.data.supported}}'
      - service: persistent_notification.create
        data_template:
          title: Device joined the Zigbee2MQTT network
          message: "Name: {{trigger.payload_json.data.friendly_name}},
                    Vendor: {{trigger.payload_json.data.definition.vendor}},
                    Model: {{trigger.payload_json.data.definition.model}},
                    Description: {{trigger.payload_json.data.definition.description}}"
Edit:
My configuration.yaml has this line added to it:
homeassistant:
  packages: !include_dir_named packages
Tip: in case you want to “disable” a yaml file, just rename it from example.yaml to example.yml. That’s what I’ve done and it works out quite well.
See above.
If I do that the Editor throws an error:
  • Invalid config for [template]: [trigger] is an invalid option for [template]. Check: template->sensor->24->trigger. (See /config/configuration.yaml, line 42).
  • Invalid config for [template]: [template] is an invalid option for [template]. Check: template->template. (See /config/templates.yaml, line 36).
  • Invalid config for [template]: [icon_template] is an invalid option for [template]. Check: template->sensor->0->icon_template. (See /config/templates.yaml, line 0).
configuration.yaml
templates.yaml:
- trigger:
    - platform: time_pattern
      hours: /1
    - service: weather.get_forecast
        type: hourly
        entity_id: weather.xxx
      response_variable: hourly
    - name: DWD Today Max Temp
      unique_id: dwd_today_max_temp
      icon_template: 'mdi:thermometer-high'
      state: "{{ now().isoformat() }}"
      attributes:
        forecast: "{{ hourly.forecast }}"
Both of the other .yaml files look like this:
- name: "..."
  state:{{...}}
Looks the same to me as your example?
icon, not icon_template
