Spotify Playlist Player
Nice project but in my config there is a problem. Any ideas?
2017-10-31 07:31:25 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1026, in _event_to_service_call
yield from service_handler.func(service_call)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/media_player/__init__.py", line 408, in async_service_handler
yield from getattr(player, method['method'])(**params)
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/media_player/spotify.py", line 241, in select_source
self._player.transfer_playback(self._devices[source],
KeyError: 'Kök'
ok got all working but i used input_number instead of input_slider for the same result
About this shuffle mode does it always play the same 1rst track then start shuffeling at the 2nd one?
or how does this work cause i have:
spotify_music:
 alias: 'Spotify Playlist'
  - service: media_player.volume_set
      entity_id: media_player.spotify
      volume_level: '0.20'
  -  service: media_player.select_source
     data_template:
       source: >
        {% if is_state("input_select.spotify_source", "Timos Echo Dot") %} Timos Echo Dot
  -  service: media_player.play_media
     data_template:
       media_content_type: playlist
       media_content_id: >
        {% if is_state("input_select.spotify_playlist", "Trap/Festival Trap") %} spotify:user:1245722571:playlist:2KalbFVILCxGne9SoUfa5Y
        {% elif is_state("input_select.spotify_playlist", "Future House Mix") %} spotify:user:futureofhouse:playlist:0vfpDUvR2cQgbvM9F4SQNU
        {% elif is_state("input_select.spotify_playlist", "Hardstyle Mix") %} spotify:user:hard-with-style:playlist:0WbkpMEQVm8eiTdiI2WfzH
        {% elif is_state("input_select.spotify_playlist", "EDM Mix") %} spotify:user:spinninrecordsofficial:playlist:4173ENNA5eMzHrz9pipvxI
  -  service: media_player.shuffle_set
       shuffle: true
I updated the code to work in Home Assistant 0.59.2. I implemented the code as a “package” (see code below). I did this before I realized I’d be foiled by not having a premium account to use the API controls though heh. So … it’s untested (I get the same error as switched). Thank you to GigabitGuy!
\\HASSIO\config\configuration.yaml: (relevant excerpts)
homeassistant:
  # Extra code is stored in these package.  Look for more variable names here
  packages:
    pack_1: !include custom_components/spotify_playlist_player.yaml
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.xxxxxxxxxx.org:8123
  base_url: xxxxxxxxxx.duckdns.org
      #base_url needed for Spotify component
  api_password: xxxxxxxxxxxx
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
media_player:
# Spotify media player only displays artwork of currently playing songs.  It leaves the artwork up after Spotify is off.  Also, no controls work (play/pause/stop/forward/back).  Chromecast Audio works for displaying the same artwork and stopping play.
  - platform: spotify
    client_id:  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    client_secret:  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    aliases:
          xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: 'Web Player (Chrome)'
         xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: 'All Home Speakers'
\\HASSIO\config\custom_components\spotify_playlist_player.yaml:
group:
    music_spotify:
      entities:
      - input_select.spotify_playlist
      - input_select.spotify_source
      - script.spotify_music
      - input_number.spotify_volume
#Use this to find aliases for your spotify media_player component (in your configuration.yaml file).  Look at home-assistant.log to find the aliases of your components.  Enter these aliases into that component in configuration.yaml.
# https://home-assistant.io/components/media_player.spotify/
logger:
    default: warning
    logs:
        homeassistant.components.media_player.spotify: info
homeassistant:
  customize:
    script.spotify_music:
      friendly_name: 'Play'
      icon: mdi:play
input_number:
  spotify_volume:
    icon: mdi:volume-high
    min: 0
    max: 1
    step: 0.05
input_select:
  spotify_playlist:
    options:
      - Your Favorite Coffehouse
      - Morning Commute
      - Cinematic Chill-Out
      - FUTURESYNTH
      - From a Smokey Bar
      - Piano in the Background
    initial: Your Favorite Coffehouse
    icon: mdi:spotify
  spotify_source:
    options:
      - All Home Speakers
      - Bedroom Speakers
      - Livingroom Speakers
      - Kitchen Speakers
      - Bathroom Speakers
      - PS4-353
    initial: All Home Speakers
    icon: mdi:speaker-wireless
script:
    spotify_music:
    #alias: Play selected spotify playlist
              volume_level: '0.40'
             data_template:
               source: >
                {% if is_state("input_select.spotify_source", "All Home Speakers") %} All Home Speakers
                {% elif is_state("input_select.spotify_source", "Bedroom Speakers") %} Bedroom Speakers
                {% elif is_state("input_select.spotify_source", "Livingroom Speakers") %} Livingroom Speakers
                {% elif is_state("input_select.spotify_source", "Kitchen Speakers") %} Kitchen Speakers
                {% elif is_state("input_select.spotify_source", "Bathroom Speakers") %} Bathroom Speakers
                {% elif is_state("input_select.spotify_source", "PS4-353") %} PS4-353
             data_template:
               media_content_id: >
                {% if is_state("input_select.spotify_playlist", "Morning Commute") %} spotify:user:spotify:playlist:37i9dQZF1DX2MyUCsl25eb
                {% elif is_state("input_select.spotify_playlist", "Cinematic Chill-Out") %} spotify:user:spotify:playlist:37i9dQZF1DWVFJtzvDHN4L
                {% elif is_state("input_select.spotify_playlist", "FUTURESYNTH") %} spotify:user:12131571557:playlist:2JgjNysZhksrtRjuGbbWns
                {% elif is_state("input_select.spotify_playlist", "From a Smokey Bar") %} spotify:user:spotify:playlist:37i9dQZF1DWTlzJXLRpd4a
                {% elif is_state("input_select.spotify_playlist", "Piano in the Background") %} spotify:user:spotify:playlist:37i9dQZF1DX7K31D69s4M1
                {% elif is_state("input_select.spotify_playlist", "Your Favorite Coffehouse") %} spotify:user:spotify:playlist:37i9dQZF1DX6ziVCJnEm59
automation:
  - alias: 'Set Spotify Volume'
        platform: state
        entity_id: input_number.spotify_volume
        data_template:
          volume_level: '{{  states.input_number.spotify_volume.state  }}'
Great work @Wheezy, I didn’t know about the new package feature, as I have been away from HA a while. I’m having huge issues with automations in general after trying to split it up/being away for a couple of months, maybe this approach can fix my issues as well.
I’m going nuts over this! I’ve must have tried a hundred different combinations of base_urls and redirect URI’s to no avail, I get either an Error 500 or a Invalid redirect URI no matter what I do.
The firewall ports are open, I can access HASS from outside my LAN, so my Duckdns redirect is working. I’ve tried using the local server IP as URI, I’ve tried my Duckdns address, with and without trailing slashes or port numbers. Still I get an error all the time. What am I doing wrong?
configuration.yaml:
http:
  # Uncomment this to add a password (recommended!)
  api_password: xXxXxXxXxXx
  # Uncomment this if you are using SSL or running in Docker etc
  base_url: XxXxXxXxXxX.duckdns.org
media_player:
  - platform: cast
    host: 192.168.1.152 #Kitchen
  - platform: spotify
    client_id: XxXxXxXxXxXXxXxXxXxXxXXxXxXxXxXxX
    client_secret: xXxXxXxXxXxxXxXxXxXxXxxXxXxXxXxXx
Screenshot from 2017-12-16 22-54-27
(Yes, I have saved them)
From the log:
2017-12-16 22:57:47 INFO (Thread-5) [homeassistant.components.media_player.spotify] no token; requesting authorization
The last times I ran the authorization before writing this post, I got an INVALID_CLIENT: Invalid redirect URI in my browser, it doesn’t matter if I use my internal IP:port or my Duckdns address. Neither the HASS log or the journalctl output will give me any more details on whats wrong.
Edit: after changing my base_url to my local IP for the umptieth time it suddenly works.
http:
  base_url: http://192.168.x.xx:8123 #
Spotify whitelist as above.
Now that the authorization is done I just have to get it working too, that seems easier said than done…
With all respect @bonterra, but I don’t think this is the thread to be doing component troubleshooting in, and you might get better help in a dedicated thread. :wink:
Yeah, you’re probably right. Eventually I did get the authorization to succeed though, I added my details to my post above. I’ll give @Wheezy’s package a try once I find some time to sit down.
Easy workaround: Just automatically skip to the next track once shuffle is enabled.
      - service: media_player.media_next_track
Hey Home Assistant Community,
I figured out a way to accomplish casting Spotify Playlists to Chromecast Audio’s through Home Assistant. I use this project in tandem with a writeup on Mopidy and Icecast2, can be found here: https://www.vittoriomonaco.de/home-automation-part-7.html
You can use my adaptation here:
https://github.com/robwolff3/homeassistant-config/blob/master/packages/audiocontrol.yaml
From my testing so far it works pretty well.
dude this is exactly what i need, basically commenting to remember for later so i can adjust mine. I thought that w should ahve ability to set the text and value on input_selects so we don’t have to do anything weird.
Nice @robwolff3, I tried to play with Mopidy earlier on, but newer really got it going - that tutorial was just what I needed… Maybe its time to revisit and update this when I have the time.
Commenting to setup myself soon. Thanks for all the code :slight_smile:
Great trick!
How did you set up your ‘All Home Speakers’ ? I can play only one device with spotify…
In gh, you can create groups of speakers containing chromecast audio and gh devices. Name it and it will show up as a new device that you can cast to.
I have this configuration, the playlist select works fine, but the source not at all. Any hints?
Other thing, do I need the below automation, for?
script:
  spotify_music:
          volume_level: ‘{{ states.input_number.spotify_volume.state }}’
         data_template:
           source: >
            {% if is_state("input_select.spotify_source", "Portable speaker") %} Portable speaker
            {% elif is_state("input_select.spotify_source", "Living room speaker") %} Living room speaker
            {% elif is_state("input_select.spotify_source", "Dining room speaker") %} Dining room speaker
            {% elif is_state("input_select.spotify_source", "Guest room speaker") %} Guest room speaker
            {% elif is_state("input_select.spotify_source", "Master bedroom speaker") %} Master bedroom speaker
            {% elif is_state("input_select.spotify_source", "Irma room speaker") %} Irma room speaker
            {% elif is_state("input_select.spotify_source", "Portable and dining room") %} Portable and dining room
            {% elif is_state("input_select.spotify_source", "All speakers") %} All speakers
            {% elif is_state("input_select.spotify_source", "First floor speakers") %} First floor speakers
            {% elif is_state("input_select.spotify_source", "SHIELD") %} SHIELD
         data_template:
           media_content_id: >
            {% elif is_state("input_select.spotify_playlist", "Romance") %} spotify:user:claudioita:playlist:1xntGadjxisaQNyuqh5Zyn
            {% elif is_state("input_select.spotify_playlist", "Sleeping") %} spotify:user:claudioita:playlist:3obCZpU1YpzZbzTr45B7gM
automation:
 - alias: Set Spotify Source
      - platform: state
        entity_id: input_select.spotify_source
      - condition: template
        value_template: "{{ not is_state_attr('media_player.spotify', 'source', states('input_select.spotify_source')) }}"
        data_template:
          source: "{{ states('input_select.spotify_source') }}"
 - alias: Set Spotify Playlist
      - platform: state
        entity_id: input_select.spotify_playlist
        value_template: "{{ not is_state_attr('media_player.spotify', 'source', states('input_select.spotify_playlist')) }}"
      - service: media_player.media_play
        data_template:
          source: "{{ states('input_select.spotify_playlist') }}"
Shouldn’t all the entity_id’s created by the package have audiocontrol_ infront of them? Isn’t that what a package does?
I’ve just started using packages and I had to make a few amendments to the last one I tried because of this…
Edit: Also, your package has an entity_id “script.playlist_remote” in a group, but doesn’t actually exist in the package.
Edit2: Nevermind, got it all working, found the script elsewhere in your config. THANKS!
Hi, I also could not find that script: script.playlist_remote
Any hint about where to look for?
Thanks in advance.
hi im on the latest hassio 0.63.3 do i have to add that?
how can you put the images of the playlists?
