Hello
I have a problem with the Spotify integration.
I was able to set everything up, can play music from Spotify on my Alexas etc.
However, my playlists are not retrieved/displayed and I get the following info:
Hello
Have you checked the log files for any errors? (Settings > System > Logs)
Logger: homeassistant.components.websocket_api.http.connection
Quelle: components/spotify/util.py:24
Integration: Home Assistant WebSocket API (Dokumentation, Probleme)
Erstmals aufgetreten: 26. März 2024 um 19:55:16 (9 Vorkommnisse)
Zuletzt protokolliert: 19:54:32
[140196148944192] Error handling message: Unknown error (unknown_error) Zuhause from 127.0.0.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36)
[140196523020096] Error handling message: Unknown error (unknown_error) Zuhause from 127.0.0.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36)
[140196225029824] Error handling message: Unknown error (unknown_error) Zuhause from 127.0.0.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36)
[140196414963520] Error handling message: Unknown error (unknown_error) Zuhause from 127.0.0.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36)
[140196055834176] Error handling message: Unknown error (unknown_error) Zuhause from 127.0.0.1 (Mozilla/5.0 (Linux; Android 14; SM-F936B Build/UP1A.231005.007; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/122.0.6261.119 Mobile Safari/537.36 Home Assistant/2024.1.5-12102 (Android 14; SM-F936B))
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 1310, in websocket_browse_media
payload = await player.async_browse_media(media_content_type, media_content_id)
File "/usr/src/homeassistant/homeassistant/components/spotify/media_player.py", line 472, in async_browse_media
return await async_browse_media_internal(
File "/usr/src/homeassistant/homeassistant/components/spotify/browse_media.py", line 225, in async_browse_media_internal
response = await hass.async_add_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/spotify/browse_media.py", line 390, in build_item_response
item_payload(item, can_play_artist=can_play_artist)
File "/usr/src/homeassistant/homeassistant/components/spotify/browse_media.py", line 439, in item_payload
browse_media.thumbnail = fetch_image_url(item)
File "/usr/src/homeassistant/homeassistant/components/spotify/util.py", line 24, in fetch_image_url
return item.get(key, [])[0].get("url")
TypeError: 'NoneType' object is not subscriptable
I use the “normal” Spotify integration of Home Assistant.
Can this integration retrieve the playlist natively, without further settings?
I read something about Spotcast, do I need that?
AFAIK, it should pull back playlists in the media browser (when launcher from a media player card). I’m not sure what’s up with the error messages. I’m assuming you setup your developer account successfully?
I use a Spotify premium subscription and I can see all my playlists, so I’m not sure what’s going on there.
@Psicrow925 @code-in-progress
FYI - I created a SpotifyPlus integration that has built-in media browser support, provides near real-time UI updates (using smart polling), a ton of custom services (including playlist retrieval), and much more. Check out the links below for more information.
As for your problem … based on the logs you provided, it appears that one or more of your playlists are missing a cover image; the fetch_image_url
method is failing because it assumes there is an item at the zero index position, and there is not (proven by the TypeError: 'NoneType' object is not subscriptable
exception).
Hope it helps!
Thank you very much for your answers and for supporting me with this problem.
Thanks for the hint with the covers, this could be the solution.
I have created some playlists, but no songs in them yet and therefore no cover picture.
I will test this right away.
I’ll have a look at your Spotify Plus integration, thanks for the tip.
@Psicrow925
Glad I could help.
FYI … I just verified that was the issue. I created an empty playlist with no cover image, and the built-in Spotify integration returned the “Unknown Error” dialog and the TypeError: 'NoneType' object is not subscriptable
log message.
I wanted to make sure my SpotifyPlus integration could handle it (and it did).
The missing covers were the problem.
Many thanks for your help
