FYI - just released a new version of the SpotifyPlus Card Dashboard
[ 1.0.18 ] - 2024/12/11
- This release requires the SpotifyPlus Integration v1.0.69+ release; please make sure you update the SpotifyPlus integration prior to updating this SpotifyPlus Card release.
- Added
playerVolumeControlsHideLevels
config option that hides volume level numbers and percentages in the volume controls area of the Player section form. Volume slider control is not affected by this setting. - Added
albumFavBrowserItemsLimit
config option that specifies the maximum number of items to be returned by the Album Favorites media browser. - Added
artistFavBrowserItemsLimit
config option that specifies the maximum number of items to be returned by the Artist Favorites media browser. - Added
audiobookFavBrowserItemsLimit
config option that specifies the maximum number of items to be returned by the Audiobook Favorites media browser. - Added
episodeFavBrowserItemsLimit
config option that specifies the maximum number of items to be returned by the Episode Favorites media browser. - Added
playlistFavBrowserItemsLimit
config option that specifies the maximum number of items to be returned by the Playlist Favorites media browser. - Added
showFavBrowserItemsLimit
config option that specifies the maximum number of items to be returned by the Show Favorites media browser. - Added
trackFavBrowserItemsLimit
config option that specifies the maximum number of items to be returned by the Track Favorites media browser. - Added “Copy X Preset JSON to Clipboard” action for all section detail displays that contain a “Copy X Preset Info to Clipboard” action. This will create a user-preset JSON format configuration entry for the selected media and copy it to the clipboard; the entry can then be pasted into the
userPresets.json
file, which will create a user preset for the media item. - Added theme variable
--spc-card-footer-background-color
to set card footer area background color; default value for the player section is vibrant color (based on cover art colors); default value for all other sections is card background color. - Added theme variable
--spc-card-footer-background-image
to set card footer area background image; default value for the player section is a gradient, which provides good contrast; default value for all other sections is card background color. - Added theme variable
--spc-card-footer-color
to set card footer icon foreground color; default value isinherit
, which is card foreground color value. - Adjusted scrollbar colors to more closely match selected theme.
