Hi @all, I could use some help with this.
I’m running HA core on Proxmox (LXC) and also have a RPi with 7" touchscreen that I use as a dashboard (running Raspbian desktop).
I would like to be able to switch the touchscreen on/off from HA when nobody is home & overnight.
From the HA shell I can achieve this with:
ssh rpi 'echo 1 | tee /sys/class/backlight/rpi_backlight/bl_power'
and
ssh rpi 'echo 0 | tee /sys/class/backlight/rpi_backlight/bl_power'
I have created this switch:
- platform: command_line
switches:
rpi_screen:
command_off: "ssh rpi echo 1 | tee /sys/class/backlight/rpi_backlight/bl_power"
command_on: "ssh rpi echo 0 | tee /sys/class/backlight/rpi_backlight/bl_power"
But this doesn’t work.
Don’t know if this is of any importance: in HA I’m logged with my own name, the command on the shell is as root.
Any idea what might be wrong?
Thanks for looking at this.
