Im probably the one missing something…apologies. I was just hoping there as a way of changing the default port so that -p was not required. I thought I was doing this in the config of the add-on but it does not appear to translate through the the CLI of the docker container. I suppose I was wanting to do the same as what we can do in linux by simply editing the ssh config file and changing default port number.
No there isn’t. Unless you do somthing on your network or router to make port 22 point to the other port on your HA IP address.
I think you are confusing things. You are setting a port that will respond to SSH commands on your HA server. But when you are using the SSH command you are not using it internally, so the terminal has no idea what port to use, and the default is 22.
Hugely useful!
A small update that the OP (@CentralCommand) might want to include in the original post, if they are still around. ssh supports a command line option to specify the configuration file location, which can make the SSH command lines used in other shell commands so much simpler, avoiding repetition and possibilities for errors, and reducing work required to make changes.
For example, I created /config/.ssh/config containing:
Host router
User root
Hostname 192.168.1.1
Port 2222
Host *
UserKnownHostsFile /config/.ssh/known_hosts
UpdateHostKeys yes
IdentityFile /config/.ssh/id_rsa
Now my shell_command automation looks like:
shell_command:
update_certificate: ssh -F /config/.ssh/config root@core-ssh "scp -F /config/.ssh/config -O router:/etc/acme/mydomain/fullchain.cer /ssl/"
Background: I have letsencrypt with a wildcard domain set up on my router where it gets renewed periodically. I want to copy this certificate from the router using SSH into a place where the nginx addon can use it.
This shell command firstly ssh’s into the core-ssh addon’s container because homeassistant’s container doesn’t have write permissions to /ssl/ to update the certificate. Then it uses the same configuration file (and associated id_rsa) to ssh to my router to copy the letsencrypt certificate into the /ssl directory, where it can be used by the nginx addon.
This is a mega thread so somebody may have already mentioned however I was stuck on this for quite a while:
If you are running Home Assistant in docker after moving id_rsa file withing /config folder do not forget to cmod it so HA docker user can read it.
I’m running HA in a docker is there any way to get a shell working like how the addon works but without the addon
This seems to add sensors but not an interactive shell
Would like something like this
i’m trying to connect passwordless from HA ssh terminal addon to a Synology NAS, i followed this thread guide + this guide but it still asks for password. Is there anything else i can do?
> ssh -v -p 65022 [email protected] -i /config/.ssh/id_rsa -o UserKnownHostsFile=/config/.ssh/known_hosts -o StrictHostKeyChecking=no
OpenSSH_9.3p2, OpenSSL 3.1.4 24 Oct 2023
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Connecting to 192.168.1.211 [192.168.1.211] port 65022.
debug1: Connection established.
debug1: identity file /config/.ssh/id_rsa type 0
debug1: identity file /config/.ssh/id_rsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_9.3
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2
debug1: compat_banner: match: OpenSSH_8.2 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 192.168.1.211:65022 as 'userxxx'
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ssh-ed25519
debug1: kex: server->client cipher: [email protected] MAC: <implicit> compression: none
debug1: kex: client->server cipher: [email protected] MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-ed25519 SHA256:1hEBHLWpXrcJ+SPs0D4llWDuAuRGgFtGOQIjdzUMzTI
debug1: Host '[192.168.1.211]:65022' is known and matches the ED25519 host key.
debug1: Found key in /config/.ssh/known_hosts:2
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /config/.ssh/id_rsa RSA SHA256:ajJiAl+IyU2Ucq5iNe9BBy/mvvir2Hoe7caj09QlIoc explicit
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,[email protected],ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,[email protected]>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering public key: /config/.ssh/id_rsa RSA SHA256:ajJiAl+IyU2Ucq5iNe9BBy/mvvir2Hoe7caj09QlIoc explicit
debug1: Next authentication method: password
[email protected]'s password:
Permission denied, please try again.
Authenticated to 192.168.1.211 ([192.168.1.211]:65022) using "password".
debug1: channel 0: new session [client-session] (inactive timeout: 0)
debug1: Requesting [email protected]
debug1: Entering interactive session.
debug1: pledge: network
debug1: client_input_global_request: rtype [email protected] want_reply 0
debug1: Remote: Ignored authorized keys: bad ACL permission for file /volume1/homes/userxxx
debug1: pledge: fork
Synology strongly advises you not to run commands as the root user, who has
the highest privileges on the system. Doing so may cause major damages
to the system. Please note that if you choose to proceed, all consequences are
at your own risk.
Nevermind, it was a permission problem:
chown -R <user> /volume1/homes/<user>
chmod 750 /volume1/homes/<user>
chmod 700 /volume1/homes/<user>/.ssh
chmod 600 /volume1/homes/<user>/.ssh/authorized_keys
1st I’d like to thank you for this article. It helped me a lot until I got stuck here:
I can execute commands like touch as shell_command. But as soon as I try to run SSH I’m getting the error bash: ssh: command not found. I use the Home Assistant OS and the same happens inside the bash shell launched with docker exec -it homeassistant bash. The Advanced SSH & Web Terminal is installed and active. Its save modus is disabled.
Can someone please help me?
Thank you for putting this together. I think I was able to piece together the various nuances to account for the non-default directories, etc. which seemed to be spread throughout this post, the referenced article, and some ChatGPT. In an attempt to consolidate what (I think) worked for me to get this going, here is a summary of the commands:
Establish passwordless SSH connection between Home Assistant (HA) and a Remote Host ([email protected] in this example…change as necessary).
Starting at the ~ command line in the Advanced SSH & Web Terminal Add-on UI…
Create the SSH key pair and place it in a folder that will not be affected by HA restarts and updates
mkdir /config/.ssh
ssh-keygen -t rsa -f ~/config/.ssh/id_rsa
<ENTER>
<ENTER> -
Copy the public key to the remote host with the -i switch to point to the non-default key directory (this switch is required from here on…every.time.you.do.anything.with.ssh.using.this.key.pair)
ssh-copy-id -i /config/.ssh/id_rsa [email protected]
<password for user 'pi'> -
Confirm the ssh and key permissions on the remote host
ssh [email protected] "chmod 700 ~/.ssh && chmod 600 ~/.ssh/authorized_keys"
Test
First directly
ssh -i /config/.ssh/id_rsa [email protected]… -
…then from the Home Assistant docker container to emulate how HA will actually send shell commands
exit
…and finally do this wth the -o switch to move the known_hosts file to the same subdirectory created earlier so that it’s not affected by HA restarts and updates either
ssh -i /config/.ssh/id_rsa -o UserKnownHostsFile=/config/.ssh/known_hosts [email protected]
yes
From here out, you should be able to configure a shell command like mentioned here, reload your yaml configuration, and call the shell command as an Action. When you do create that shell command, it will need to look like this…
ssh -i /config/.ssh/id_rsa [email protected] <your command(s)>
I understand why it’s good to set a non-default location for the private key on the client (i.e. storing it in /config/.ssh instead), because this directory is not wiped by updates. Makes sense.
However, it seems like everyone in this thread (unless I missed something) is still storing the public key on the remote host in ~/.ssh (for example, using ssh-copy-id updates the authorized_keys file in /root/.ssh).
When using Home Assistant OS and trying to SSH into the host, don’t we also need to set a non-default location for the public key on the host? Or are the contents of the /root/.ssh directory on the Home Assistant OS host preserved during updates, and so doesn’t need to be changed to something non-default?
Correct. Not wiped on the OS.
OMG, Thank You @RoganDawes for this, by creating a /config/.ssh/config file my ssh commands went from this crazy-long syntax
ssh -o UserKnownHostsFile=/config/.ssh/known_hosts -p 2222 [email protected] -i /config/.ssh/id_ed25519 "<execution command here>"
to
ssh -F /config/.ssh/config dopey "<execution command here>"
Here are the contents of my /config/.ssh/config
Host dopey
HostName 192.168.30.25
Port 2222
User home_assistant
Host *
IdentityFile /config/.ssh/id_ed25519
You can add as many hosts to the config file as necessary.
SO MUCH CLEANER !
One question, do I need to perform after this step again an
exit
before I have perform the final step?
I don’t think so. The first exit got you back to the HA container.
Is strange, I’m getting in test from Home assistant docker container ssh’ing into pi a request to confirm the connection. This should not happen… whats going wrong …
Once confimed it works … but only until restart of the Raspberry …
or maybe some updates … did not figured out yet, what corrupts it again
➜ ~ ssh -i /config/.ssh/id_rsa [email protected]
Linux raspberrypi 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Feb 9 07:09:25 2025
pi@raspberrypi:~ $ exit
Abgemeldet
Connection to 192.168.178.xx closed.
➜ ~ docker exec -it homeassistant bash
homeassistant:/config# ssh -i /config/.ssh/id_rsa [email protected]
The authenticity of host '192.168.178.xx (192.168.178.xx)' can't be established.
ED25519 key fingerprint is SHA256:GCb......................................................
This key is not known by any other names.
Are you sure you want to continue connecting (yes/no/[fingerprint])?
[Self SOLVED] > see details bellow if you got the same problem …
I’m trying this, , log with putty using Passwordless key works great, but when trying from HA bash i got a problem and the host request a password
homeassistant:/config# ssh [email protected] -i /share/.ssh/rsa-key-HA_sensorCommandKey_2025-04-19_private_openSSH
[email protected]: Permission denied (publickey,password).
File and folder permission verified, dans putty login work perfectly
i’ve also try to update the private key to modern format but it’s not changing anything
Thanks by advance for help because after a couple of hours i don’t understant what appends
[SOLUTION]
Like i’m trying to access to the host, i was not using the default port 22, i’m using the port 22222 , so the solution was only to add the port to the connection … (Enabling SSH access to the host)
# ssh [email protected] -i /share/.ssh/rsa-key-HA_sensorCommandKey_2025-04-19_private_openSSH -p 22222
and it works great !
Hi, I have fully functional solution for shell_command and using ssh with sshpass. I’m using the Advanced SSH Add-on and the authorized_keys was not an option an old NAS where the embedded linux was very limited. So, here is the link for my guide in an another post but the same topic: Power on / off NAS by using WOL and SSHPASS - #18 by zollak
thank you kindly for this work, it safed my bacon today!
Is this solution also working under HAOS?
