Yeah I have done some tinkering. This should now work:
blueprint:
name: Start music on Alexa when a tag is scanned
description:
When a tag is scanned, start the associated music on the selected Alexa media player.
You can also run commands with the "universal function"
domain: automation
input:
tag_id:
description:
The tag ID of your NFC trigger. Can be found under Settings --> NFC Tags
and then click on the NFC Tag you want to choose.
alexa_entity_id:
description: The entity ID of the alexa player to use
selector:
entity:
domain: media_player
song_name:
description: The name of the song to play. The source is specified below.
Make sure to select only one source. If its known that a source must be formatted right
then its specified in the source you can select.
source_amazon:
description: Music is from Amazon Music. The Song name can be the songname
default: false
selector:
boolean:
source_spotify:
description:
Music is from Spotify. Song name must be songname (e.g. Still Alive),
songname and interpret (e.g. Still alive from Red ),
"playlist" and playlist name (e.g. Playlist Oldies)
or the name of a featured playlist from Spotify (e.g. Missed Hits).
selector:
boolean:
source_apple:
description: Music is from Apple Music.
default: false
selector:
boolean:
source_deezer:
description: Music is from Deezer.
default: false
selector:
boolean:
source_tunein:
description: Music is from TuneIn.
default: false
selector:
boolean:
source_custom:
description:
You can put a command in the songname which you would say to your Alexa device e.g.
"Play my playlist Oldies on Spotify" (leave out your trigger word from your device).
Requires Alexa Media Player version 3.4.0 or newer.
default: false
selector:
boolean:
message:
default: []
name: Input of Song input from the UI
description: Input text where the Song comes from
selector:
entity:
domain: input_text
default: []
name: Target of the notification (Input Select)
description: The alexa device where the notification should be played. Must be in a input select. Options can be the Friendly Name, Serial Number, entity_id, or Home Assistant Group.
selector:
entity:
domain: input_select
variables:
is_spotify: !input "source_spotify"
is_amazon: !input "source_amazon"
is_apple: !input "source_apple"
is_deezer: !input "source_deezer"
is_tunein: !input "source_tunein"
is_costum: !input "source_custom"
alexa_entity_id: !input alexa_entity_id
message: !input message
target_for_message: !input target
song: !input song_name
- platform: tag
tag_id: !input tag_id
- platform: event
event_type: state_changed
event_data:
entity_id: !input message
- service: media_player.play_media
data_template:
entity_id: >
{% if trigger.platform == "event" %}
{{states.media_player| selectattr("attributes.friendly_name","equalto", states(target_for_message)) |map(attribute="entity_id") |first}}
{% else%}
{{alexa_entity_id}}
{% endif%}
media_content_id: >
{{states(message)}}
{% else%}
{{song}}
{%endif%}
media_content_type: >
{% if is_amazon %}
AMAZON_MUSIC
{% elif is_spotify %}
SPOTIFY
{% elif is_apple %}
APPLE_MUSIC
{% elif is_deezer %}
DEEZER
{% elif is_tunein %}
TUNEIN
{% elif is_costum%}
custom
{% endif%}
