šŸ”¹ state-switch - conditional card on steroids
I am trying to hide some cards from users, enable it only on admin user. Seems that the user type isn’t working as expected. Just to be sure, is the user name is the ā€œusernameā€ or any other id generated?
Thx
entity: user goes by the username, yes.
entity: group selects by admin and not admin, i.e. user.
My username is ā€œeyalā€. The user is ā€œEyalā€. I found out the user is working and not username
@thomasloven
I am confused :slight_smile: what is the right one, user (Eyal) or username (eyal)?. I can work with user, no problem, the only thing is that the use can have spaces e.g., ā€˜John John’
Use the one that works.
yaml keys can have spaces too, and if that wouldn’t work, quote it
states:
  "Thomas LovƩn":
  "John John":
@thomasloven - Is there a way of not showing a card based on the state/user/etc? I can see there is the type markdown, but is there a way of it just being blank?
Hi All,
I do something wrong but don’t know what:
No card type found
Here input_select:
system_state_switch:
  name: "Select Technical overview:"
  options:
    - External IP
    - Device Trackers
    - Home Assistant Update
Here code in Lovelace:
  - type: module
    url: /community_plugin/lovelace-state-switch/state-switch.js
cards:
  - type: entities
    entities:
      - input_select.system_state_switch
  - type: 'custom:state-switch'
    entity: input_select.system_state_switch
    states:
      "External IP":
        type: glance
        title: Lights
        entities:
          - light.dressoir_all
      "Device Trackers":
        type: glance
        title: Lights
        entities:
          - light.livingroom_all
      "Home Assistant Update":
        type: glance
        title: Lights
        entities:
          - light.kitchen_all
In the log file I see this line:
2020-01-30 09:56:56 ERROR (MainThread) [frontend.js.latest.202001082] https://192.168.100.24:8123/community_plugin/custom-header/custom-header.js:145:62852 TypeError: undefined is not an object (evaluating 't.tabs[F().current_view].dispatchEvent')
Can someone help me with this :slight_smile:
At the and of the cards added this:
type: vertical-stack
problems solved
Feature Request or is it possible to show some cards and not others on the template.
"{% for state in states.sensor if state.state|int < 8 %} {{ state.entity_id.split('.')[1]}}, {% endfor %}"
I got this string to work ,but only if it returns only one name. If it returns two names it displays no cards.
I’m having a strange problem with this card I’ve never had before. It says it’s not installed:
However, I installed it the same way I did all my other working cards, by using HACS, verified HACS had installed it in my www folder, and then putting it in my lovelace.yaml in the same way as all my working cards, see below:
resources:
  - url: /community_plugin/vertical-stack-in-card/vertical-stack-in-card.js
    type: js
  - url: /community_plugin/button-card/button-card.js
    type: module
  - url: /community_plugin/lovelace-card-tools/card-tools.js
    type: module
  - url: /community_plugin/mini-media-player/mini-media-player-bundle.js
    type: module
  - url: /community_plugin/lovelace-layout-card/layout-card.js
    type: module
  - url: /community_plugin/calendar-card/calendar-card.js
    type: js
  - url: /community_plugin/mini-graph-card/mini-graph-card-bundle.js
    type: module
  - url: /community_plugin/lovelace-slider-entity-row/slider-entity-row.js
    type: module
  - url: /community_plugin/secondaryinfo-entity-row/secondaryinfo-entity-row.js
    type: js
  - url: /community_plugin/simple-thermostat/simple-thermostat.js
    type: module
  - url: /community_plugin/air-visual-card/air-visual-card.js
    type: js
  - url: /community_plugin/custom-header/custom-header.js
    type: module
  - url: /community_plugin/lovelace-weather-card-chart/weather-card-chart.js
    type: module
  - url: /community_plugin/lovelace-card-mod/card-mod.js
    type: module
  - url: /community_plugin/lovelace-home-feed-card/lovelace-home-feed-card.js
    type: js
  - url: /community_plugin/search-card/search-card.js
    type: module
  - url: /local/state-switch.js
    type: module
here is my lovelace entry to instantiate the card:
 - type: custom:state-switch
    entity: template
    template: "{% if is_state('input_select.sean_location_dropdown', 'Home')} home {% else %} away {% endif %}"
    states:
      home:
        cards:
        - type: picture-glance
          aspect_ratio: 16x9
          entities: []
          camera_image: camera.front_stream
          camera_view: live
        - type: horizontal-stack
          cards:
            aspect_ratio: 9x16
            entities: []
            camera_image: camera.left_stream
            camera_view: live
            aspect_ratio: 9x16
            entities: []
            camera_image: camera.right_stream
            camera_view: live
          aspect_ratio: 16x9
          entities: []
          camera_image: camera.back_stream
          camera_view: live
      away:
        cards:
          aspect_ratio: 16x9
          entities: []
          cards:
            aspect_ratio: 9x16
            entities: []
            aspect_ratio: 9x16
            entities: []
          aspect_ratio: 16x9
          entities: []
I can’t for the life of me figure out why this card doesn’t work when all my others do… Is it possibly just not compatible with .105.5?
Oh duh, it’s just the folder is wrong for HACS. The right one seems to be
  - url: /community_plugin/lovelace-state-switch/state-switch.js
    type: module
Card still isn’t working but I think I have some other syntax errors in there.
There’s a troubleshooting guide in the install instructions linked from the readme.
Working now, thanks!
found anything on this? Thanks
hi, thanks for great card.
I am trying to use this in long vertical stack. by using three buttons would like to scroll down the page at a specific place! at the same time in the default would like to leave all cards visible. short of like anchors.
is this possible to achieve?
hi,
question, i am reverting my conditional cards to state-switch cards…
but the variables doesnt work anymore like i wanted :frowning:
this worked before:
- name: "Calendar: [[[return ${states[ā€˜sensor.calendar_fabio_vanessa’].state}]]]"
now i need to remove the ā€˜Calendar:’ word,
so its like
- name: "[[[return ${states[ā€˜sensor.calendar_fabio_vanessa’].state}]]]"
how can i define a fixed word before that state
it worked before on conditional card
thxn a lot
    entity: template
    template: "{% if not is_state('sensor.calendar_fabio_vanessa', 'off') %} on  {% endif %}"
    states:
      "on":
        cards:
          - !include ../includes/blank-card.yaml
          - type: custom:decluttering-card
            template: notification
            variables:
              - card_color: rgba(0, 221, 255, 0.5)
              - icon: calendar
              - name: "[[[return `${states['sensor.calendar_fabio_vanessa'].state}`]]]"
Also another question:
I have some buttons I want to display…
Before with conditional cards, when I didn’t want to show (hide a button) the next button would be on the exact same space…
With this card, if I have for example 10 state switches, and 2 of them are true, let’s say the first and the last, I have like 8 extra spaces/rows…
Normally the second buttons should be right under the first button… But now every card that is hidden ( no state) seems.its creating somekind of whitespaces…
Hard to explain what I mean
example screenshot:
state-switch
I’ve got the exact same issue with conditionally non-displayed cards, albeit horizontally (stacked):
are you sure your cards were there correctly before? I feared it to be related to the horizontal-stack card.
Eg entities cards with conditional cards as entities don’t suffer this behavior.
yeah, with condinional cards, there was no space/gap between cards … now its filling up with spaces, they all shift some pixels to below
the more cards are invisible between 2 visible cards, the more the second one shift to beow
i see this PR, allthought it didnt fix my issue
