did you check lovelace-state-switch/test at master Ā· thomasloven/lovelace-state-switch Ā· GitHub?
I didnt, but Thomas did put-up some examples there
Is it possible to have the card preform two transitions?
I have a custom button card with tap_action to navigation _path: ā#p1ā
based on my state switch the my card slides down to show my cards or entities. I was looking to have the card slip back up then down again showing another set of cards or entities when a different button is pressed.
HI Marius
Did you end up finding a solution for this without the button-card?? I have been trying for a few days now to convert window.location.pathname into either a variable or usable template. Tried also using custom:config-template-card but just cant find a way of making the pathname usable in later code. I could use DeviceID in BrowserMod but I want the code a little more dynamic without manually needing to assign Device names etc.
My use case is that I have navigation buttons that I only want available when using a tablet and not on a PC.
no I havent, it simply cant be done in jinja, because path is frontend available only.
using stated-switch on a bigger view level like:
- type: custom:state-switch
entity: mediaquery
states:
"(pointer: coarse)":
!include /config/dashboard/includes/include_plattegrond_swipe_3.yaml
all:
!include /config/dashboard/includes/include_plattegrond_grid_4.yaml
which includes a grid config for desktop or a swiper config for mobile (pointer: coarse), I can help but notice a huge delay upon each loading of the card.
If I use either of these configs individually, there is still some lag (it is a rather large view, including a lot of picture-glance cards for all of my rooms) but it is way more responsive.
Would there be a better way of deciding which card config to use based on either mobile or non mobile?
Hi all, Iām looking for a way to install version 1.9.3, is there a way to do that?
I need that version for minimalist adaptieve ui.
I have a button that I only want to see when an entity is 1ā¦
YAML:
- type: conditional
conditions:
- entity: binary_sensor.bureau_bewegingsmelder_occupancy
state: 'on'
card:
- type: custom:mushroom-chips-card
chips:
- type: template
The button is not seen, but when the entity is 1 I get āno card type configuredā. what is wrong with the code ?
You put the single card there as a list item. Remove the -
in front of ātypeā
Thanks for helping me but I donāt understand
instead of the above, use
card:
chips:
- type: template
no -
in front of the type:
as Thomas says, using the -
makes that a list, and the card expects a single card, not a list of cards
I still got the same error
here is the full code on the actionā¦
YAML:
- type: conditional
conditions:
state: 'on'
card:
chips:
- type: template
content_info: none
use_light_color: false
card_mod: null
tap_action:
!include alarm.yaml
icon: |2-
{% set state=states('binary_sensor.bureau_bewegingsmelder_occupancy') %}
{% if state=='on' %}
mdi:bell-outline
{% elif state=='off' %}
show_icon: false
{% endif %}
icon_color: |2-
red
grey
{% endif %}
style: |
ha-card {
{% if states('binary_sensor.bureau_bewegingsmelder_occupancy') == 'on' %}
animation: blink 0.4s linear infinite;
@keyframes blink {
50% {opacity: 0;}
{%- else -%}
box-shadow: 0px 0px;
{%- endif %}
ha-card {
alignment: center
if this is your actual yaml, then you should at least fix the spacing. Maybe its a c&p fluke, but
- type: conditional
conditions:
state: 'on'
card:
should be:
- type: conditional
conditions:
state: 'on'
card:
type:
# and next your correct card config
check the example in the docs:
type: conditional
conditions:
- entity: light.bed_light
state: "on"
- entity: switch.decorative_lights
state_not: "off"
card:
type: entities
entities:
- device_tracker.demo_paulus
- cover.kitchen_window
- group.kitchen
- lock.kitchen_door
- light.bed_light
you should try the conditional card with a simple entity first. so you know the conditional works ok.
also, try the card itself without conditional, soy know that works.
If both are fine, you can joinā¦
- type: conditional
conditions:
state: 'on'
card:
- type: 'custom:button-card'
entities:
- sensor.p1_meter_5c2faf04a1f2_active_power
this is now my conditional code. It still says there is no card configured
yes but button card does not support entities:
ā¦ only entity:
that is why I said to take a card you know to work , and then add it t the conditional
also, you still have that dash in front of the type:
2 crucial mistakesā¦ Please read carefully what people advise you to do
ok, found it. thanks
Apologies to ask something that may have been asked before. Is it possible to define a state in which no card is shown if that is the right state? I can use a conditional card to achieve the same thing but much prefer the transition effect that state switch provides.
I tried with a blank card but it still pads out more than I want.
@jaswalters I am trying to do something like you did here for my screens using shutter-card.
Would it be possible to share your code for this card?
Kind regards, Bert
I try to use the custom:state-switch card but run into an problemā¦
I try to replicate this example. paragraph entity_id.
This is the code I mad of the example (using the UI):
type: entities
title: Test input_select.home_mode
entities:
- entity: input_select.home_mode
states:
Home:
type: vertical-stack
cards:
- type: entities
title: Lights
entities:
- light.sonoff_8s20
- light.sonoff_3s20
- light.sonoff_4s20
- type: picture-glance
camera_image: camera.oprit_profile000_mainstream
entities: []
Away:
type: alarm-panel
entity: alarm_control_panel.alarmo
Guests:
type: glance
title: Lights
entities:
- light.sonoff_8s20
- light.sonoff_3s20
- light.sonoff_4s20
But I get an error message about the duplicate mapping of a cardā¦:
The difference is the the example starts with
cards:
But when I put the original code (including cards:) in the editor i get:
No type provided.
How can I configure this in the UI?
I dont know if i can ask a update here but i will try.
I love this card but is missed something like going to default after x sec.
So iās it possible to returm to default page after x sec when you push a button
Example i push button 3 and get page 3 but then after 10 sec itās return to the default page.
Thx
Just a hasty guess: this could be (probably) achieved by some automation:
ā pushing a button starts an automation;
ā this automation sets some value to some helper;
ā the state-switch-card then switches to some card - dependently on this helperās value;
ā then after some time interval the value is reset - an the state-switch-card is reset too.
