It has been a while. Think first I stopped Z2M docker-container, then HA. I removed all messages in Mosquitto MQTT-server related to buggy/faulty devices. I removed devices in Z2M, I removed devices and entities in HA .storage folder (core.device_registry and core.entity_registry). Then I searched for all ID’s related to buggy/faulty devices in home-assistant_v2.db. Start Z2M, reassign friendly_name, start Homeassistant. Done. Something like that.
Tried everything for a several days, all (exist) devices working perfect, no new devices can be paired at all.
Nothing helped, until I decided to REFLASH my dongle.
Everything started to work perfect (no need to repair exist devices)
Half the day spend desperately trying to get zigbee2mqtt w CC2531 working. Just before giving up on it connected the CC2531 via an USB extension cable. e voila it worked immediately. Before was jsut not able to get pair any other zigbee with it.
Does anyone have a working solution to have devices connect to the closes coordinator? I’ve added 2 new devices (cr_curtains & lr_curtains). These 2 devices were paired close to the repeater. However, it decides to connect to the coordinator which is out of range most of the time. How can I tell it to connect to the repeater? Also shioin_room used to be connected to the coordinator and it is very close to the coordinator, but it moved to the repeater recently.
