i turned off the vm on which haos is running and i can control the blinds by the manual switch. I was sure that it is like that but still wanted to check it to be sure.
yeah, i figured that was likely true.
in that case, Stop closing blinds if the door is open - #8 by armedad
might be the best we can do
Just out of curiosity, what brand are you using?
There aren’t many on the german market, like Rademacher or Somfy. Maybe there is already an integration available, that would make it easier.
Ok. So this will stop closing when someone is triggering it while the door is open. At least the 50% solution. With this automatic closing because of the stupid wheater sensor i have to live…
Thank you very much for your time and your help!!!
The shutters are from warema, the “stupid” weather station is an eltako multisensor ms which is connected to an eltako msr12-uc sensorrelais.
The only available integration I found so far is an warema cube for homee.
