Strange behaviour of jinja2 code
The following code gives me a list of datetimes when my automations have been triggered:
states.automation|map(attribute="attributes")|map(attribute="last_triggered")|list
But if I append “|sort”, it throws an error. ‘mappingproxy object’ has no attribute ‘last_triggered’
Why is this?
You probably have one or more automations whose state is unavailable (they don’t have a last_triggered attribute).
Try this:
{{ states.automation
   | selectattr('state', 'ne', 'unavailable')
   | map(attribute='attributes.last_triggered')
   | sort }}
You can make it more robust by including this before the map filter:
   | selectattr('attributes.last_triggered', 'ne', None)
Oh, thank you, the solution was so easy!
But why does it complain that there is no attribute “last_triggered”? If the list is already build and I append a sort, it should only sort the list.
It’s a ‘mappingproxy object’
What Taras fixed, but omitted in his explanation is that last_triggered is an attribute, but you’re treating it like a property on the state object (which is a mappingproxy object).
You had (incorrect):
Taras had (correct)
You can read up on state objects here:
Here’s what happens if I eliminate the second line of the template and it encounters the unavailable automations on my test system:
Thank you.
Maybe you can change
So whenever you use this function:
state_attr(entity_id, ‘attribute’)
into
state_attr(entity_id, ‘<attributename>’)
in this article.
