Hi
Yesterday I installed the latest HA update 2022.3.0, and since that installation the ha_strava integration doesn’t load. I didn"t change anything else than just the update install.
I tried several restart ==> Same
In the Log I have this:
Is one of you have any idea how to fix it ?
I switched to https://github.com/madmic1314/ha_strava and that works fine. I needed to remove the old ha_strava integration completely, add a custom repo in HACS (use that URL) and set up with my strava credentials again. Hope that helps.
Does anyone using this integration know how fast a completed activity gets reported into Home Assistant? I’d like to trigger automation as soon as a workout gets completed.
I’m trying to integrate and assemble a tutorial for the Brazilian home assistant community, but it’s reporting this error.
Can you help me?
error
This integration does not support configuration through the UI. If you follow this link from the Home Assistant website, be sure to check for the latest version of Home Assistant.
per his github page https://github.com/madmic1314/ha_strava is now abandoned and has been broken for me or over a month i think. does anyone have a working strava integration please
hi - i have just come across an issue i think. when i try to use the slider to adjust the number of concurrent activities i get “unknown error occured”
I’ve installed this and with some fiddling got it to work.
Love it!
I see the title of the activities has the date at the beginning. How could I create a sensor to show the weekly distance ran?
I guess the sensors (sensor.strava_0_0 shows up as DD/MM time) would first need to be converted to a date (DD/MM/YYYY) then some kind of calc to add the distances if it’s within the start and end date of that week.
This is totally beyond my knowledge so any pointers would be helpful.
