I have 2 Unifi cameras streaming, fine, but not getting sound. Does anyone have sound working?
Sorry to mislead you. it is not working the way i thought it was working. Anyway, what I did was the below.
place any jpg image (place holder) in www folder
create a camera config and point this as image_url (and actual synology stream as stream_url)
at this point you cameras will show up with the place holder image. if you click on it it will open the actual stream.
then i created an automation (state change) using camera.snapshot to create new images (with the same name as the placeholder image, so that it will get overwritten)
alias: AUTO-CAMERA-SNAPSHOTS
platform: state
entity_id: camera.entrance_cam, camera.frontroom_cam, camera.lounge_cam, camera.backyard_cam
service: camera.snapshot
data_template:
entity_id: ā{{trigger.from_state.entity_id}}ā
filename: ā/config/www/images/{{trigger.to_state.entity_id}}.jpgā -
it works but, it looks like the camera.snapshot is creating snapshots using the placeholder image (not the actual stream). so the new images created also looking exactly same as the placeholder. BUMMER
Has anyone configured an axis camera to work with the stream component?
Hehe, thatās normal, thatās why there is a snapshot url, to create snapshotsā¦ They are not coming from streamsource
Anyone got the DSC-932L d-link camera to work with the stream component?
There is a fix coming planned for 0.91.1 that will make Axis cameras work. Hold out for that.
-Jan
Iāve been trying with DCS-935L using RTSP with H.264 and Iāve had no luck. The address Iāve tried is rtsp://username:password@ip-number:554/play1.sdp and is working fine in VLC.
Ok, thanks, please give me a heads up if you figure it out
For all the Foscam owners out there. This is working for me.
Foscam C1 and Foscam FI9800P
- platform: generic
stream_source: rtsp://USERNAME:PASSWORD@IPADDRESS:554/videoMain
still_image_url: http://IPADDRESS:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USERNAME&pwd=PASSWORD
username: USERNAME
password: PASSWORD
verify_ssl: false
and also smooth? i also believe platform foscam itself is now also supported for stream: so not only generic
https://github.com/home-assistant/home-assistant/pull/22568 (91.0)
tried it?
I tried the foscam platform but could not get the stream to work.
The generic is smooth-ish. Has some hickups now and then but overall itās okay.
Iām struggling to get this to work on my SV3C camera
- platform: generic
still_image_url: āhttp://192.168.0.41:55109/image/gardenā
stream_source: āhttp://192.168.0.41:55109/h264/garden/temp.m3u8ā
username: !secret garden_cam_user
password: !secret garden_cam_password
The URLs work fine on the browser, but HA wont see the still image or the video feedPreformatted text
Camera 1 = DS-2CD2185FWD-IS, H265+, authentification : digest
Camera 2 = DS-2CD2142FWD-I, H264+, authentification : digest
Code :
- platform: generic
still_image_url: http://192.168.1.12:80/ISAPI/Streaming/channels/100/picture
stream_source: rtsp://admin:[email protected]:554/Streaming/Channels/102/
username: !secret hikvision_garage_username
password: !secret hikvision_garage_password
authentication: digest
- platform: generic
still_image_url: http://192.168.1.13:80/ISAPI/Streaming/channels/100/picture
username: !secret hikvision_garden_username
password: !secret hikvision_garden_password
Small update my reolink camera setup with the sub feed and as a generic camera still suffers from the black feed on first launch and proper stream on second launch out of the box in 0.91.0.
HOWEVER
If I check the preload stream option it works quickly and correctly every time, but with the obvious overhead on the HASS serverā¦ I still think there is something wrong with the way HASS initially loads the stream and setting all my cameras this way would probably overload my HASS server. At least I can use this on my front door cam to see it nearly instantly.
Just posting for refrence, maybe will help others troubleshooting. I have a hikvision 1080p camera, the stream component just doesnt work well. It plays a couple seconds, then gets a spinning circle for a second, then continues. It does not skip forward, so the stream quickly gets further and further delayed. On VLC the stream plays fine.
So on 91.1 I get the following errors when playing the stream
non-existing PPS 0 referenced
then
decode_slice_header error
then
no frame!
Pretty standard rstp
rtsp://username:[email protected]:554/ISAPI/Streaming/channels/101
This doorbell plays at 12fps. VLC does not show framerate for this stream,
but my other camera which plays perfectly as a stream does show framerate
I have tried setting framerate in the camera config, but it did not make a difference.
thanks but mine are still not working on stream, h265+ 4mp poe cams my h264+ works fine
The buffering is due to requesting resources faster than they are available. Preload stream will help with this.
The overhead isnāt really that high. Have you checked resource consumption on your machine?
Hmm, Iām casting this to my TV, how do I preload the stream. Iāve never been able to get any of my streams to work on my computer, which is fine for the moment.
Edit: I checked the preload stream, no difference.
This doorbell camera is wi-fi and the others on my network are POE, but even so, VLC still plays the stream well. I suspect the rstp stream is not 100% compliant, or its the audio, or something
I tried using a sub stream as well, I also took out the audio in the sub stream on the camera settings, still not working
I did notice that these errors showed in the log upon restarting
2019-04-05 14:46:43 ERROR (stream_worker) [libav.h264] non-existing PPS 0 referenced
2019-04-05 14:46:43 ERROR (stream_worker) [libav.h264] decode_slice_header error
2019-04-05 14:46:43 ERROR (stream_worker) [libav.h264] no frame!
2019-04-05 14:46:44 ERROR (stream_worker) [libav.h264] error while decoding MB 32 35, bytestream -40
When I removed the camera stream settings in HA these errors did not appear, so Iām confident these errors are from the doorbell camera stream
