do you use esphome? I can share mine for that if interested
Esphome config below; added to HA via the esphome integration (just need the esp32-cam IP)
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: "xxxxxxxx"
password: "xxxxxxxxx"
ap:
ssid: "xxxxxxxxxxxxx"
password: "xxxxxxxxxxxxxxxxx"
logger:
api:
password: "xxxxxxxxxxxxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxx"
- platform: wifi_signal
update_interval: 300s
- platform: uptime
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
vertical_flip: false
horizontal_mirror: false
resolution: 640x480
switch:
- platform: gpio
pin: GPIO4
name: "Feeder Flash Light"
I believe so. I add it with the integration so a platform isn’t actually selected but it acts just like a generic IP
I’ve spent the day trying to get my ESP32-CAM working by following the RandomNerdTutorial with no luck. I can stream to Google Chrome just fine, but when I try the Picture Card specifying camera IP address, I get nothing. For those who say it works, I’d love to hear from you. I don’t think ESPHome should be necessary, though I have tried that also unsuccessfully. I’d really like to integrated directly into HA without ESPHome. Can anyone point me in the right direction? ESP32-CAM is an awesome little $10 camera and I’d like to use more.
I did get ESP32-CAM to work on HA using ESPHome. Since my HA is running HTTPS, I assume there is no direct method to display any HTTP URL like an HTTP camera in HA HTTPS. So now I am looking for an HTTPS version of CameraWebServer example. Anybody know of one.
You can also try running tasmota. I converted one of my esp32 cams running esphome and it runs really well. Will probably do the others too. You can access the camera stream directly. Tasmota webcam server for the ESP32-cam - CGomesu
So why should you choose tasmota over esphome ? Do you have a little comparison?
