Yes, I’m doing all that.
I’ve just discovered the Full Home Assistant Log which contains many entries regarding the tapo_p100_control. Here it is in it’s entirety:
2021-11-05 08:47:27 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo_p100_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-11-05 08:47:27 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-11-05 08:47:27 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-11-05 08:47:34 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2021-11-05 08:47:34 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2021-11-05 08:47:36 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Canon TS8100 series’ for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2021-11-05 08:47:36 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘RM4C MINI’ for broadlink integration not ready yet: [Errno -4000] Network timeout; Retrying in background
2021-11-05 08:47:36 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘RM4 MINI’ for broadlink integration not ready yet: [Errno -4000] Network timeout; Retrying in background
2021-11-05 08:47:39 ERROR (SyncWorker_2) [custom_components.tapo_p100_control.switch] Could not connect to plug. Possibly invalid credentials
2021-11-05 08:47:41 ERROR (MainThread) [homeassistant.components.switch] Error while setting up tapo_p100_control platform for switch
File “/usr/local/lib/python3.9/site-packages/PyP100/PyP100.py”, line 155, in login
self.token = ast.literal_eval(decryptedResponse)[“result”][“token”]
KeyError: ‘result’
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 249, in _async_setup_platform
await asyncio.shield(task)
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 52, in run
File “/config/custom_components/tapo_p100_control/switch.py”, line 44, in setup_platform
add_entities([P100Plug(p100)])
File “/config/custom_components/tapo_p100_control/switch.py”, line 53, in init
self.update()
File “/config/custom_components/tapo_p100_control/switch.py”, line 84, in update
self._p100.login()
File “/usr/local/lib/python3.9/site-packages/PyP100/PyP100.py”, line 159, in login
raise Exception(f"Error Code: {errorCode}, {errorMessage}")
Exception: Error Code: -1501, Invalid Request or Credentials
2021-11-05 08:52:05 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.0.10 (192.168.0.10). (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.69 Safari/537.36)
I wouldn’t know where to start with this lot.
