Studio Code Editor gone crazy, using 80% CPU
I could not locate any peculiar symlinks etc, though given I am not a Linux expert I am not sure I would spot them.
Adding /root/config to the config_path entry did not yield a change for me either.
Memory consumption grows over time, and eventually the whole system becomes slow and unstable. As a temporary declaration of defeat, I added a restart automation based on addon memory consumption.
Given I am developing more and more UI in YAML and custom JINJA templates, I do need a solid solution. So at this stage I am seeking alternatives that can help maintain a similar level of productivity to what VSCode provides (when it’s up and running). The simple file editor does not cut it for me, any other options folks here have considered or may be looking into?
Use samba share and put VSCode on a separate system. I have the vscode addon, however I only turn it on when I’m remoting into the system from outside my house. When inside my house, I always use a different computer to run vscode on and the addon stays off. In general, if you aren’t using vscode, you should leave it off.
Thanks! I deleted the symlink to homeassistant and config, and also downgraded, cpu is back to normal.
ls -FA | sed -ne 's/@//p'
config
homeassistant
➜  /config git:(master) ✗ rm config
homeassistant
➜  /config git:(master) ✗ rm homeassistant
before, I had an automation to just stop the addon every30m.
alias: Stop VS Code every 30 minutes
description: ""
triggers:
  - trigger: time_pattern
    minutes: /30
conditions: []
actions:
  - data:
      addon: a0d7b954_vscode
    action: hassio.addon_stop
Where is the Visual Studio config file located?
Or is it a setting in VS?
To change the config file path for studio code server:
Goto settings-> add-ons-> studio code server
select configuration, set config path to /root/config
Thanks for the pointer, this is definitely the way to go!
Thanks everyone for the advice on why it’s using so much CPU. Since I still occasionally need access to the root folder, this will likely happen again at some point. So, based on the earlier suggestion to use automation, I created a more subtle restart mechanism for the addon.
Note: To use this automation, you first need to enable the CPU sensor of the addon.
Go to Settings → Devices & Services → Integrations → Home Assistant Supervisor → Studio Code Server → Disabled Entities and enable the relevant CPU usage sensor.
Here’s the automation:
alias: HA Addon Restart VSCode when it's CPU hog
description: ""
triggers:
  - type: value
    device_id: 7ec982dcb7155d140f4edbfac79a31aa
    entity_id: 5287512712bfaf99ac797747dc673a49
    domain: sensor
    above: 70
    for:
      hours: 0
      minutes: 15
      seconds: 0
conditions: []
actions:
  - service: notify.owner_phone
      message: VSCode is using too much CPU, restarting it in 2 minutes
      title: CPU Hog Detected
  - delay:
      minutes: 2
  - service: hassio.addon_restart
mode: single
That did not quite work for me but this did
This is crazy that this is still a thing. I thought it was Frigate making my HAOS melt but when installed Glances Add-on…nope… VSCode. I’ll make the working folder non-root as someone else discovered and also have an automation automatically turn off VSCode if left open for longer than 12 hours.
from what i understand its the log files that makes vscode editor go bananas.
