I assume you mean ‘turn off’ after a delay?
Your first action turns it on.
If so, use two automations:
Turn on
alias: VVB Av etter en time
description: ''
- platform: time
at: input_datetime.billigtime1
- platform: time
at: input_datetime.billigtime2
- platform: time
at: input_datetime.billigtime3
- platform: time
at: input_datetime.billigtime4
- platform: time
at: input_datetime.billigtime5
- platform: time
at: input_datetime.billigtime6
- platform: time
at: input_datetime.billigtime7
- platform: time
at: input_datetime.billigtime8
- platform: time
at: input_datetime.billigtime9
- platform: time
at: input_datetime.billigtime10
- platform: time
at: input_datetime.billigtime11
- platform: time
at: input_datetime.billigtime12
condition: []
- service: switch.turn_on
entity_id: switch.varmtvannstank
- service: notify.mobile_app_thomas_mobil
title: 'VVB PÅ Billig '
message: '{{now()}}'
Turn off:
alias: Turn off after 59 minutes
- platform: state
to: 'on'
for:
minutes: 59
- service: switch.turn_off
title: VVB AV 59min
This trigger off for time will be reset and start counting again if automations are reloaded or when Home Assistant restarts.
If the time is super critical you could start a timer in the “turn on” automation and use the timer finishing as the trigger for your off automation. The timer will not be affected by automation reloads and there is a method to restore active timers after a restart, see: https://community.home-assistant.io/t/restore-active-paused-timers-after-a-restart/274439
