Okay, now I think I get it. Its in July at 145° not in your living room because of the elevation.
Yes that’s right. I could not (and still can’t) figure out how to calculate the elevation and find it easier to do it this way (which probably is not). When I find some spare time I will try to calculate elevation and azimuth as koying says.
You don’t have to “calculate”. Just check the values of the azimuth and elevation attributes
Calculating is quite difficult because, e.g.:
- azimuth is based on “true north” (i.e. the north pole) and a compass will give you the “magnetic north”, which are not the same
- The sun is not a point in the sky, it’s a circle, 2D speaking
Elevation of the window is the “easiest”.
It’s:
- distance from the reference point to you window = X
- height of the bottom (or top) of the window = Y
- elevation = atan(y/x)
I know, but somehow it didn’t take so I thought I give it another shot. Seems like it doesn’t help though
This is difficult for me to grasp. When I should check the value of the azimuth?
in the below example.
At October 2021 I know that the sun will be inside the living room when azimuth will be at 140.56
In May the azimuth should be at 172.88
I don’t understand how to fill this in your automation
What you say doesn’t make any sense
Add or subtract 4h to both calculations and you’ll get completely different azimuths.
Just look into HA the values of the azimuth
and elevation
attribute of the sun.sun
entity when the sun becomes bothersome any day
but this is my problem.
In October the sun becomes bothersome at azimuth 140 and elevation 30
and in May at 173 and 69 accordingly.
based on the values of HA and of the above charts.
Probably I don’t understand something but cannot figure out what
But how do you know? Did you actually checked it?
The “charts” only tell you what the azimuth and elevation of the sun are at a given time (time is different on both charts, btw), i.e. tell you exactly the same as HA for now()
Maybe I can give this a try…
let’s assume that your window is facing due (true) south. That means that the plane of the window will be from 90 degrees to 270 degrees (from inside the house looking south 90 degrees will be to your left).
That means that any time the sun’s azimuth is between 90 and 270 degrees and the elevation is above 0 and below 90 degrees (above the horizon) the sun WILL BE shining into your window.
You may not notice it at the extremes because it will be shining on the far west wall in the morning (sun azimuth 90 degrees) and shining on the far east wall in the evening (sun azimuth at 270 degrees).
as the day progresses from morning till night the sun will move up in the sky and to the west until it gets to it’s highest point in the arc (which will always be <=90 degrees) and then continue moving to the west but it will be going down in elevation.
During this time if you are in your room in front of the window looking out you will see the sun light (NOT the sun but the sun LIGHT) trace a path from your west wall down across the floor and then continue moving to the east until it reaches your east wall. If you trace the center point of the sunlight shining inside your house thru the window you will trace an arc across your room from the top of one wall to the next top of the next wall across the floor in the middle.
if you never want any sun in your room then the limits of the azimuth will be between 90 degrees and 270 degrees and elevation will be between 0 and 90 degrees.
Most people aren’t that concerned about the extremes tho. It’s UP TO YOU to decide at what point based on the suns azimuth and elevation the sun is bothersome to you. Those values will be somewhere between 90 and 180 degrees for azimuth and 0 to 90 degrees elevation. But nobody can tell you what those numbers are. you have to figure them out for yourself.
BUT, those azimuth and elevation numbers won’t change throughout the year. The only thing that changes is the time that those number coordinates are reached. There may be time of the year that the sun can never reach some of those coordinates at all depending on where you live.
the point is that it’s not the TIME that the sun is at those points in the sky. it’s just the points that matter.
you just have to pick the minimum and maximum azimuth and elevation points where you don’t want the sun shining into your room and set those values as the limits of the numeric_states in the code above.
You can ignore the time entirely since it’s the set of coordinates that we care about. not what time the sun gets to those coordinates.
EDIT: OOPS, Sorry. I meant that west was supposed to be 270 not 180 (180 is due south). Corrected.
He seems incapable of grasping that… a whole bunch of people telling him that exact thing but he doesn’t get it because he’s obsessed with time not position…
Maybe you can elaborate a bit what we are talking about, a window, a terrace or what the sun is shinning on.
It is strange, that you say you have sun at 140° in October (elevation 33°) and no sun at 140° in May (corresponding elevation = 64°), but you will have sun in May at an azimuth of 172° (with a 4° higher elevation)
That’s why i took the pains to try to explain it.
Hopefully it’s understandable.
It doesn’t matter what the aperture is that the sun is shining thru. the concept is the same.
the size and shape of the aperture only determines the limits of the azimuth and elevation at which the sun is “bothersome”. Which, again, is subjective.
I think so too, but what he claims is somehow strange. I thought maybe there is a special form of window or an obstacle. Or he misunderstood “azimuth”
I somewhat doubt he took measurements the 19th october 2021
Yes, I have check it.
I am talking for a particular window facing the south. The above numbers of azimuth are the exact values when the sunlight gets in my house and on my furniture’s in October and May accordingly.
for example right now the my cover closed just right when the sun touched my floor and the furniture
@ finity thanks for that explanation I will try to understand it
the values are the same with October 2020. In general the values are almost the same for same day of every year
Azimuth is not enough. The elevation on 21th June might be above your window, so not bothersome, and below your window on 21st December so not bothersome, either, for the same azimuth.
EDIT: updated graph
below are my calculations with an excel formula
the data of 31/10/2020 + 21/12/2020 are the exact values from HA azimuth sensor
the rest are calculations from the excel file
the values are correct because as soon as light comes in the floor the covers are closing.
31/10/2020 | 142,81 |
21/12/2020 | 125 |
22/12/2020 | 125,32 |
23/12/2020 | 125,64 |
24/12/2020 | 125,96 |
25/12/2020 | 126,28 |
26/12/2020 | 126,6 |
27/12/2020 | 126,92 |
28/12/2020 | 127,24 |
29/12/2020 | 127,56 |
30/12/2020 | 127,88 |
31/12/2020 | 128,2 |
1/1/2021 | 128,52 |
2/1/2021 | 128,84 |
3/1/2021 | 129,16 |
4/1/2021 | 129,48 |
5/1/2021 | 129,8 |
6/1/2021 | 130,12 |
7/1/2021 | 130,44 |
8/1/2021 | 130,76 |
9/1/2021 | 131,08 |
10/1/2021 | 131,4 |
11/1/2021 | 131,72 |
12/1/2021 | 132,04 |
13/1/2021 | 132,36 |
14/1/2021 | 132,68 |
15/1/2021 | 133 |
16/1/2021 | 133,32 |
17/1/2021 | 133,64 |
18/1/2021 | 133,96 |
19/1/2021 | 134,28 |
20/1/2021 | 134,6 |
21/1/2021 | 134,92 |
22/1/2021 | 135,24 |
23/1/2021 | 135,56 |
24/1/2021 | 135,88 |
25/1/2021 | 136,2 |
26/1/2021 | 136,52 |
27/1/2021 | 136,84 |
28/1/2021 | 137,16 |
29/1/2021 | 137,48 |
30/1/2021 | 137,8 |
31/1/2021 | 138,12 |
1/2/2021 | 138,44 |
2/2/2021 | 138,76 |
3/2/2021 | 139,08 |
4/2/2021 | 139,4 |
5/2/2021 | 139,72 |
6/2/2021 | 140,04 |
7/2/2021 | 140,36 |
8/2/2021 | 140,68 |
9/2/2021 | 141 |
10/2/2021 | 141,32 |
11/2/2021 | 141,64 |
12/2/2021 | 141,96 |
13/2/2021 | 142,28 |
14/2/2021 | 142,6 |
15/2/2021 | 142,92 |
16/2/2021 | 143,24 |
17/2/2021 | 143,56 |
18/2/2021 | 143,88 |
19/2/2021 | 144,2 |
20/2/2021 | 144,52 |
21/2/2021 | 144,84 |
22/2/2021 | 145,16 |
23/2/2021 | 145,48 |
24/2/2021 | 145,8 |
25/2/2021 | 146,12 |
26/2/2021 | 146,44 |
27/2/2021 | 146,76 |
28/2/2021 | 147,08 |
1/3/2021 | 147,4 |
2/3/2021 | 147,72 |
3/3/2021 | 148,04 |
4/3/2021 | 148,36 |
5/3/2021 | 148,68 |
6/3/2021 | 149 |
7/3/2021 | 149,32 |
8/3/2021 | 149,64 |
9/3/2021 | 149,96 |
10/3/2021 | 150,28 |
11/3/2021 | 150,6 |
12/3/2021 | 150,92 |
13/3/2021 | 151,24 |
14/3/2021 | 151,56 |
15/3/2021 | 151,88 |
16/3/2021 | 152,2 |
17/3/2021 | 152,52 |
18/3/2021 | 152,84 |
19/3/2021 | 153,16 |
20/3/2021 | 153,48 |
21/3/2021 | 153,8 |
22/3/2021 | 154,12 |
23/3/2021 | 154,44 |
24/3/2021 | 154,76 |
25/3/2021 | 155,08 |
26/3/2021 | 155,4 |
27/3/2021 | 155,72 |
28/3/2021 | 156,04 |
29/3/2021 | 156,36 |
30/3/2021 | 156,68 |
31/3/2021 | 157 |
1/4/2021 | 157,32 |
2/4/2021 | 157,64 |
3/4/2021 | 157,96 |
4/4/2021 | 158,28 |
5/4/2021 | 158,6 |
6/4/2021 | 158,92 |
7/4/2021 | 159,24 |
8/4/2021 | 159,56 |
9/4/2021 | 159,88 |
10/4/2021 | 160,2 |
11/4/2021 | 160,52 |
12/4/2021 | 160,84 |
13/4/2021 | 161,16 |
14/4/2021 | 161,48 |
15/4/2021 | 161,8 |
16/4/2021 | 162,12 |
17/4/2021 | 162,44 |
18/4/2021 | 162,76 |
19/4/2021 | 163,08 |
20/4/2021 | 163,4 |
21/4/2021 | 163,72 |
22/4/2021 | 164,04 |
23/4/2021 | 164,36 |
24/4/2021 | 164,68 |
25/4/2021 | 165 |
26/4/2021 | 165,32 |
27/4/2021 | 165,64 |
28/4/2021 | 165,96 |
29/4/2021 | 166,28 |
30/4/2021 | 166,6 |
1/5/2021 | 166,92 |
2/5/2021 | 167,24 |
3/5/2021 | 167,56 |
4/5/2021 | 167,88 |
5/5/2021 | 168,2 |
6/5/2021 | 168,52 |
7/5/2021 | 168,84 |
8/5/2021 | 169,16 |
9/5/2021 | 169,48 |
10/5/2021 | 169,8 |
11/5/2021 | 170,12 |
12/5/2021 | 170,44 |
13/5/2021 | 170,76 |
14/5/2021 | 171,08 |
15/5/2021 | 171,4 |
16/5/2021 | 171,72 |
17/5/2021 | 172,04 |
18/5/2021 | 172,36 |
19/5/2021 | 172,68 |
20/5/2021 | 173 |
21/5/2021 | 173,32 |
22/5/2021 | 173,64 |
23/5/2021 | 173,96 |
24/5/2021 | 174,28 |
25/5/2021 | 174,6 |
26/5/2021 | 174,92 |
27/5/2021 | 175,24 |
28/5/2021 | 175,56 |
29/5/2021 | 175,88 |
30/5/2021 | 176,2 |
31/5/2021 | 176,52 |
1/6/2021 | 176,84 |
2/6/2021 | 177,16 |
3/6/2021 | 177,48 |
4/6/2021 | 177,8 |
5/6/2021 | 178,12 |
6/6/2021 | 178,44 |
7/6/2021 | 178,76 |
8/6/2021 | 179,08 |
9/6/2021 | 179,4 |
10/6/2021 | 179,72 |
11/6/2021 | 180,04 |
12/6/2021 | 180,36 |
13/6/2021 | 180,68 |
14/6/2021 | 181 |
15/6/2021 | 181,32 |
16/6/2021 | 181,64 |
17/6/2021 | 181,96 |
18/6/2021 | 182,28 |
19/6/2021 | 182,6 |
20/6/2021 | 182,92 |
21/6/2021 | 183,24 |
22/6/2021 | 182,92 |
23/6/2021 | 182,6 |
24/6/2021 | 182,28 |
25/6/2021 | 181,96 |
26/6/2021 | 181,64 |
27/6/2021 | 181,32 |
28/6/2021 | 181 |
29/6/2021 | 180,68 |
30/6/2021 | 180,36 |
1/7/2021 | 180,04 |
2/7/2021 | 179,72 |
3/7/2021 | 179,4 |
4/7/2021 | 179,08 |
5/7/2021 | 178,76 |
6/7/2021 | 178,44 |
7/7/2021 | 178,12 |
8/7/2021 | 177,8 |
9/7/2021 | 177,48 |
10/7/2021 | 177,16 |
11/7/2021 | 176,84 |
12/7/2021 | 176,52 |
13/7/2021 | 176,2 |
14/7/2021 | 175,88 |
15/7/2021 | 175,56 |
16/7/2021 | 175,24 |
17/7/2021 | 174,92 |
18/7/2021 | 174,6 |
19/7/2021 | 174,28 |
20/7/2021 | 173,96 |
21/7/2021 | 173,64 |
22/7/2021 | 173,32 |
23/7/2021 | 173 |
24/7/2021 | 172,68 |
25/7/2021 | 172,36 |
26/7/2021 | 172,04 |
27/7/2021 | 171,72 |
28/7/2021 | 171,4 |
29/7/2021 | 171,08 |
30/7/2021 | 170,76 |
31/7/2021 | 170,44 |
1/8/2021 | 170,12 |
2/8/2021 | 169,8 |
3/8/2021 | 169,48 |
4/8/2021 | 169,16 |
5/8/2021 | 168,84 |
6/8/2021 | 168,52 |
7/8/2021 | 168,2 |
8/8/2021 | 167,88 |
9/8/2021 | 167,56 |
10/8/2021 | 167,24 |
11/8/2021 | 166,92 |
12/8/2021 | 166,6 |
13/8/2021 | 166,28 |
14/8/2021 | 165,96 |
15/8/2021 | 165,64 |
16/8/2021 | 165,32 |
17/8/2021 | 165 |
18/8/2021 | 164,68 |
19/8/2021 | 164,36 |
20/8/2021 | 164,04 |
21/8/2021 | 163,72 |
22/8/2021 | 163,4 |
23/8/2021 | 163,08 |
24/8/2021 | 162,76 |
25/8/2021 | 162,44 |
26/8/2021 | 162,12 |
27/8/2021 | 161,8 |
28/8/2021 | 161,48 |
29/8/2021 | 161,16 |
30/8/2021 | 160,84 |
31/8/2021 | 160,52 |
1/9/2021 | 160,2 |
2/9/2021 | 159,88 |
3/9/2021 | 159,56 |
4/9/2021 | 159,24 |
5/9/2021 | 158,92 |
6/9/2021 | 158,6 |
7/9/2021 | 158,28 |
8/9/2021 | 157,96 |
9/9/2021 | 157,64 |
10/9/2021 | 157,32 |
11/9/2021 | 157 |
12/9/2021 | 156,68 |
13/9/2021 | 156,36 |
14/9/2021 | 156,04 |
15/9/2021 | 155,72 |
16/9/2021 | 155,4 |
17/9/2021 | 155,08 |
18/9/2021 | 154,76 |
19/9/2021 | 154,44 |
20/9/2021 | 154,12 |
21/9/2021 | 153,8 |
22/9/2021 | 153,48 |
23/9/2021 | 153,16 |
24/9/2021 | 152,84 |
25/9/2021 | 152,52 |
26/9/2021 | 152,2 |
27/9/2021 | 151,88 |
28/9/2021 | 151,56 |
29/9/2021 | 151,24 |
30/9/2021 | 150,92 |
1/10/2021 | 150,6 |
2/10/2021 | 150,28 |
3/10/2021 | 149,96 |
4/10/2021 | 149,64 |
5/10/2021 | 149,32 |
6/10/2021 | 149 |
7/10/2021 | 148,68 |
8/10/2021 | 148,36 |
9/10/2021 | 148,04 |
10/10/2021 | 147,72 |
11/10/2021 | 147,4 |
12/10/2021 | 147,08 |
13/10/2021 | 146,76 |
14/10/2021 | 146,44 |
15/10/2021 | 146,12 |
16/10/2021 | 145,8 |
17/10/2021 | 145,48 |
18/10/2021 | 145,16 |
19/10/2021 | 144,84 |
20/10/2021 | 144,52 |
21/10/2021 | 144,2 |
22/10/2021 | 143,88 |
23/10/2021 | 143,56 |
24/10/2021 | 143,24 |
