I don’t know. Can you read? You have been given a solution many times in this thread but you are ignoring it.
If ha does a DNS lookup, one of your EXPORT s is missing or wrong.
sorry, i read thru this entire thread and using portainer is not a solution, it is a lazy workaround that requires installing additional software that may or may not be wanted.
the solution is to restart the hass container with docker itself. if that is not working or is inaccessible on the host then that’s an unresolved issue. this is a classic cart before the horse scenario and installing portainer is just buying another horse to pull the cart and the other horse behind it.
Agreed - I have HA Supervised and had to remove portainer to keep it as “supported”
