Supervisor update
Need help (Newby)
I installed HA on an android box, the first installation went well and I got an error with the cgroup that’s running v2. I tried fixing it but now I receive an error when I’m trying to install HA again. I am new to Linux and home assistant.
Here are the details.
[info] Switching to cgroup v1
/var/lib/dpkg/info/homeassistant-supervised.postinst: line 150: update-grub: command not found**
dpkg: error processing package homeassistant-supervised (–install):**
installed homeassistant-supervised package post-installation script subprocess returned error exit status 127
Errors were encountered while processing:
What exactly is this 'android box’ and what exactly is your base operating system?
I highly recommend you reconsider the route you’re going. Supervised is for experts, the docs even mention this. I suggest you look into hassos before attempting supervised.
I got it working at the end. It took a lot of reading and testing but resolved the problem.
The system I bought was pre-installed with supervised edition.
