there seems to be something wrong … can you please double check you really have running pyfritzhome 0.3.1 and also have the latest custom_component?!
in your last error message
the logged line number is valid for 0.2.4!?
I am having problems installing pyfritzhome using pip. I get this message trying to use “pip3 install pyfritzhome”:
/usr/local/lib/python3.4/dist-packages/requests/__init__.py:80: RequestsDependencyWarning: urllib3 (1.9.1) or chardet (2.3.0) doesn't match a supported version!
With regard to pip3 freeze, the latest pyfritzhome version should be installed:
[email protected]:~# sudo pip3 freeze
aiocoap==0.3
aiohttp==2.2.5
astral==1.4
async-timeout==2.0.0
certifi==2017.7.27.1
chardet==3.0.4
Cython==0.27.1
homeassistant==0.56.2
idna==2.6
Jinja2==2.9.6
MarkupSafe==1.0
multidict==3.3.0
mysqlclient==1.3.12
pyfritzhome==0.3.1
pytradfri==3.0.4
pytz==2017.2
PyYAML==3.12
requests==2.18.4
tinyDTLS==0.0.0
typing==3.6.2
urllib3==1.22
voluptuous==0.10.5
yarl==0.13.0
I also double checked the fritz home custom component files. They are the latest from your github page, which were updated 3 hours ago by you.
did you try to check your installed version of urllib3 and chardet?
try pip show urllib3
and pip show chardet
Can you please double check the REQUIREMENTS = ['pyfritzhome==0.3.1']
variable of the custom component? and also the version in your /root/.homeassistant/deps/lib/python3.6/site-packages/pyfritzhome/version.py
file?
Thx for your feedback and you hard work @hthiery.
Seems the Requirements Variable in the custom components is the correct one:
But if I look under /root/.homeassistant/deps/lib/python3.6/site-packages/pyfritzhome/version.py it shows me 0.2.4 as Version:
I had to install it in the virtualenv and now it works. This is awesome, ComeDECT support was the only thing I missed with Homeassistant so it is a really great addition. I hope it gets merged into master soon.
I just deleted the pyfritzhome folder under /root/.homeassistant/deps/lib/python3.6/site-packages/
manually.
After a restart, it works as expected and I can now set my temperature via the HA webinterface
I found this post after my github entry https://github.com/hthiery/homeassistant/issues/1 .
I have a similar problem with my fritzbox 6490 and OS 6.51 (newer isn’t possible at this time -> provider).
% pip3 show pyfritzhome
Version: 0.3.3
Error message in HA and also fritzhome cli tool:
2017-11-08 11:42:06 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform fritzhome
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 170, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/home/dominion/.homeassistant/custom_components/climate/fritzhome.py", line 31, in setup_platform
device_list = fritz.get_devices()
File "/home/dominion/.homeassistant/deps/lib/python3.6/site-packages/pyfritzhome/fritzhome.py", line 133, in get_devices
device = FritzhomeDevice(self, node=element)
File "/home/dominion/.homeassistant/deps/lib/python3.6/site-packages/pyfritzhome/fritzhome.py", line 239, in __init__
self._update_from_node(node)
File "/home/dominion/.homeassistant/deps/lib/python3.6/site-packages/pyfritzhome/fritzhome.py", line 272, in _update_from_node
self.device_lock = bool(get_node_value(n, 'devicelock'))
File "/home/dominion/.homeassistant/deps/lib/python3.6/site-packages/pyfritzhome/fritzhome.py", line 28, in get_node_value
return get_text(node.getElementsByTagName(name)[0].childNodes)
IndexError: list index out of range
greetz,
Dominion
Hi, @hthiery,
With the latest version of the fritzhome custom component from github (Nov. 3), that should fix a problem when device is not present I’am facing the following error:
2017-11-07 23:57:24 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 180, in _step
result = coro.send(None)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 398, in async_process_entity
new_entity, self, update_before_add=update_before_add
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 246, in async_add_entity
yield from entity.async_update_ha_state()
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 211, in async_update_ha_state
if not self.available:
File "/root/.homeassistant/custom_components/climate/fritzhome.py", line 59, in available
return self._device.present
AttributeError: 'FritzhomeDevice' object has no attribute 'present'
2017-11-07 23:57:25 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
My installed pyfritzhome Version is 0.3.3 and HA is on Version 0.57.2
Hi @hthiery,
I wan’t to just give you feedback, that my error was again because of an old pyfritzhome version under “/root/.homeassistant/deps/lib/python3.6/site-packages/”
There was version 3.1 while 3.3 is needed for your latest custom components.
After deleting the 3.1 folder under /root/.homeassistant/deps/lib/python3.6/site-packages/ it works again.
Thank you very much for your help
Hi @CM000n,
I think there is a problem with your home assistant installation. I installed it in an virtualenv and homeassistant manages the package dependencies. I followed the installation description here: https://home-assistant.io/docs/installation/virtualenv/.
Maybe you should take a look on that to avoid this kind of problems in the future.
Heiko
I updated to Home Assistant 0.58 and Python 3.5 and now my Fritzdect modules don’t show up anymore in Home Assistant. In the logs I am getting this message:
2017-11-19 00:55:34 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.climate.fritzhome. Make sure all dependencies are installed
File "/opt/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py", line 142, in get_component
module = importlib.import_module(path)
File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 986, in _gcd_import
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 673, in exec_module
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/home/homeassistant/.homeassistant/custom_components/climate/fritzhome.py", line 11, in <module>
from homeassistant.components.climate import (
ImportError: cannot import name 'PRECISION_HALVES'
2017-11-19 00:55:34 ERROR (MainThread) [homeassistant.loader] Unable to find component climate.fritzhome
2017-11-19 00:55:37 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.climate.fritzhome. Make sure all dependencies are installed
2017-11-19 00:55:37 ERROR (MainThread) [homeassistant.loader] Unable to find component climate.fritzhome
I installed the latest pyfritzhome into my virtualenv successfully without errors:
Collecting pyfritzhome
Requirement already satisfied: requests in /opt/homeassistant/lib/python3.5/site-packages (from pyfritzhome)
Requirement already satisfied: idna<2.7,>=2.5 in /opt/homeassistant/lib/python3.5/site-packages (from requests->pyfritzhome)
Requirement already satisfied: certifi>=2017.4.17 in /opt/homeassistant/lib/python3.5/site-packages (from requests->pyfritzhome)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in /opt/homeassistant/lib/python3.5/site-packages (from requests->pyfritzhome)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /opt/homeassistant/lib/python3.5/site-packages (from requests->pyfritzhome)
Installing collected packages: pyfritzhome
Successfully installed pyfritzhome-0.3.4
Okay, I commented out/removed both PRECISION_HALVES sections, and the Comet DECT show up again.
Changed sections:
ClimateDevice, STATE_ECO
and
# @property
# def precision(self):
# """Return precision 0.5."""
# return PRECISION_HALVES
Indeed the version on github isnt’t working ;-( I currently prepare the component for bring it upstream.
Now the version in master branch should work again.
Thanks, hope it gets into the official repository soon.
Wow, look how much work has already been invested in the implementation of the new Fritzhome components:
It looks like the component will be released soon.
Thank you so much @hthiery and all the others.
Hey CM000n, could you be so kind and share your code (how you implemented this) with me?
I’m using lovelace.ui and still to fresh to get it to work correctly
Deutsch geht auch
Hi @Dominik_Heiss,
I think in the official section of the forum we should stay with the English. But if you want, you can send me a PM in German.
I just use the -meanwhile - official Fritzbox component from @hthiery : https://www.home-assistant.io/components/fritzbox/
Then I have some template sensors in my sensors.yaml
, for single values from the Fritzbox switches and thermostats. for me t looks like this for example:
# TEMPLATE SENSORS #
sensors:
sonos_wohnzimmer_state:
value_template: '{{ states("media_player.wohnzimmer") }}'
friendly_name: 'Status'
sonos_schlafzim_state:
value_template: '{{ states("media_player.sonos_schlafzim") }}'
sonos_bad_state:
value_template: '{{ states("media_player.sonos_bad") }}'
chromecast_wohnzimmer_state:
value_template: '{{ states("media_player.chromecast_wohnzimmer") }}'
tv_wohnzimmer_state:
value_template: '{{ states("binary_sensor.device_tracker_philipstv") }}'
stromverbrauch_spuehlmaschine:
value_template: '{{ states.switch.steckdose_spulmaschine.attributes["current_power_w"] | replace(" W", "") | float }}'
unit_of_measurement: 'W'
friendly_name: 'Stromverbrauch Spülmaschine'
stromverbrauch_waschmaschine:
value_template: '{{ states.switch.steckdose_waschmaschine.attributes["current_power_w"] | replace(" W", "") | float }}'
friendly_name: 'Stromverbrauch Waschmaschine'
stromverbrauch_trockner:
value_template: '{{ states.switch.steckdose_trockner.attributes["current_power_w"] | replace(" W", "") | float }}'
friendly_name: 'Stromverbrauch Trockner'
stromverbrauch_wohnzimmer_ecke:
value_template: '{{ states.switch.steckdose_wohnzimmer_ecke.attributes["current_power_w"] | replace(" W", "") | float }}'
friendly_name: 'Stromverbrauch Wohnzimmer Ecke'
stromverbrauch_buero:
value_template: '{{ states.switch.steckdose_buro.attributes["current_power_w"] | replace(" W", "") | float }}'
friendly_name: 'Stromverbrauch Büro'
gesamtverbrauch_spuehlmaschine:
value_template: '{{ states.switch.steckdose_spulmaschine.attributes["total_consumption"] | replace(" kWh", "") | float }}'
unit_of_measurement: 'kWh'
friendly_name: 'Gesamtvebrauch Spülmaschine'
gesamtverbrauch_waschmaschine:
value_template: '{{ states.switch.steckdose_waschmaschine.attributes["total_consumption"] | replace(" kWh", "") | float }}'
friendly_name: 'Gesamtverbrauch Waschmaschine'
gesamtverbrauch_trockner:
value_template: '{{ states.switch.steckdose_trockner.attributes["total_consumption"] | replace(" kWh", "") | float }}'
friendly_name: 'Gesamtvebrauch Trockner'
gesamtverbrauch_wohnzimmer_ecke:
value_template: '{{ states.switch.steckdose_wohnzimmer_ecke.attributes["total_consumption"] | replace(" kWh", "") | float }}'
friendly_name: 'Gesamtvebrauch Wohnzimmer Ecke'
gesamtverbrauch_buero:
value_template: '{{ states.switch.steckdose_buro.attributes["total_consumption"] | replace(" kWh", "") | float }}'
friendly_name: 'Gesamtvebrauch Büro'
temperatur_wohness:
value_template: '{{ states.switch.steckdose_spulmaschine.attributes["temperature"] | replace(" C", "") | float }}'
unit_of_measurement: '°C'
friendly_name: 'Temperatur Wohn./Ess.'
temperatur_keller:
value_template: '{{ states.switch.steckdose_waschmaschine.attributes["temperature"] | replace(" C", "") | float }}'
friendly_name: 'Temperatur Keller'
temperatur_wohnzimmer_ecke:
value_template: '{{ states.switch.steckdose_wohnzimmer_ecke.attributes["temperature"] | replace(" C", "") | float }}'
friendly_name: 'Temperatur Wohnzimmer Ecke'
temperatur_buero:
value_template: '{{ states.switch.steckdose_buro.attributes["temperature"] | replace(" C", "") | float }}'
friendly_name: 'Temperatur Büro'
status_spuelmaschine:
friendly_name: 'Spülmaschine'
value_template: >-
{% if states('sensor.stromverbrauch_spuehlmaschine')|float <= 0 %}
Aus
{% elif states('sensor.stromverbrauch_spuehlmaschine')|float < 100 %}
Spült
{% elif states('sensor.stromverbrauch_spuehlmaschine')|float >= 100 %}
Trocknet
{% else %}
PRÜFEN!
{% endif %}
status_waschmaschine:
friendly_name: 'Waschmaschine'
value_template: >-
{% if states('sensor.stromverbrauch_waschmaschine')|float <= 0 %}
Aus
{% elif states('sensor.stromverbrauch_waschmaschine')|float <= 3.9 %}
Fertig
{% elif states('sensor.stromverbrauch_waschmaschine')|float > 3.9 %}
Wäscht
{% else %}
PRÜFEN!
{% endif %}
status_trockner:
friendly_name: 'Trockner'
value_template: >-
{% if states('sensor.stromverbrauch_trockner')|float <= 0 %}
Aus
{% elif states('sensor.stromverbrauch_trockner')|float <= 7 %}
Fertig
{% elif states('sensor.stromverbrauch_trockner')|float > 7 %}
Trocknet
{% else %}
PRÜFEN!
{% endif %}
fritzbox_uptime:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["uptime"] | replace("s", "") }}'
unit_of_measurement: 's'
friendly_name: 'Fritzbox Uptime'
fritzbox_bytes_sent:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["bytes_sent"] | replace("B", "") }}'
unit_of_measurement: 'B'
friendly_name: 'Fritzbox Bytes sent'
fritzbox_bytes_received:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["bytes_received"] | replace("B", "") }}'
friendly_name: 'Fritzbox Bytes received'
fritzbox_transmission_rate_up:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["transmission_rate_up"] | replace("B/s", "") }}'
unit_of_measurement: 'B/s'
friendly_name: 'Fritzbox Current Upstream Speed'
fritzbox_transmission_rate_down:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["transmission_rate_down"] | replace("B/s", "") }}'
friendly_name: 'Fritzbox Current Downstream Speed'
fritzbox_max_byte_rate_up:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["max_byte_rate_up"] | replace("B/s", "") }}'
friendly_name: 'Fritzbox Maximum Upstream-Rate'
fritzbox_max_byte_rate_down:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["max_byte_rate_down"] | replace("B/s", "") }}'
friendly_name: 'Fritzbox Maximum Downstream-Rate'
fritzbox_is_connected:
friendly_name: 'Fritzbox Connection Status'
value_template: >-
{% if is_state('sensor.fritzbox_is_connected2', 'True') %}
1
{% else %}
0
{% endif %}
fritzbox_is_linked:
friendly_name: 'Fritzbox Link Status'
value_template: >-
{% if is_state('sensor.fritzbox_is_linked2', 'True') %}
1
{% else %}
0
{% endif %}
fritzbox_is_connected2:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["is_connected"] }}'
fritzbox_is_linked2:
value_template: '{{ states.sensor.fritz_netmonitor.attributes["is_linked"] }}'
batterie_heizung_bad:
value_template: '{{ states.climate.heizungbad.attributes["battery_level"] | replace(" %", "") | float }}'
unit_of_measurement: '%'
device_class: battery
friendly_name: 'Batterie Heizung Bad'
batterie_heizung_buero:
value_template: '{{ states.climate.heizungburo.attributes["battery_level"] | replace(" %", "") | float }}'
friendly_name: 'Batterie Heizung Büro'
temperatur_climate_bad:
value_template: '{{ states.climate.heizungbad.attributes["current_temperature"] | replace(" C", "") | float }}'
friendly_name: 'Temperatur Bad'
temperatur_climate_buero:
value_template: '{{ states.climate.heizungburo.attributes["current_temperature"] | replace(" C", "") | float }}'
And then it is, for the example from above, just a simple group in groups.yaml:
# SWITCHES #
Steckdosen:
control: hidden
entities:
- switch.steckdose_spulmaschine
- sensor.stromverbrauch_spuehlmaschine
- sensor.gesamtverbrauch_spuehlmaschine
- switch.steckdose_waschmaschine
- sensor.stromverbrauch_waschmaschine
- sensor.gesamtverbrauch_waschmaschine
- switch.steckdose_trockner
- sensor.stromverbrauch_trockner
- sensor.gesamtverbrauch_trockner
- switch.steckdose_buro
- sensor.stromverbrauch_buero
- sensor.gesamtverbrauch_buero
- switch.steckdose_wohnzimmer_ecke
- sensor.stromverbrauch_wohnzimmer_ecke
- sensor.gesamtverbrauch_wohnzimmer_ecke
Hope this helps you a little
Greetings from BaWü
