I seem to continually get update errors when I use this platform. However, it seems that all sensors are still updating frequently despite the errors. For example:
2019-07-30 09:34:59 ERROR (MainThread) [homeassistant.components.sensor] environment_canada: Error on device update!
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 160, in _new_conn (self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 57, in create_connection for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo for res in _socket.getaddrinfo(host, port, family, type, proto, flags): socket.gaierror: [Errno -3] Try again During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 603, in urlopen chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 355, in _make_request conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.7/http/client.py", line 1244, in request self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1290, in _send_request self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1239, in endheaders self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output self.send(msg) File "/usr/local/lib/python3.7/http/client.py", line 966, in send self.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 183, in connect conn = self._new_conn() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn self, "Failed to establish a new connection: %s" % e) urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7fa1cfc0ae50>: Failed to establish a new connection: [Errno -3] Try again
Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 641, in urlopen _stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 399, in increment raise MaxRetryError(_pool, url, error or ResponseError(cause)) urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='dd.weatheroffice.ec.gc.ca', port=80): Max retries exceeded with url: /citypage_weather/xml/ON/s0000326_e.xml (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa1cfc0ae50>: Failed to establish a new connection: [Errno -3] Try again'))
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 380, in async_device_update await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs)
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 224, in wrapper result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/environment_canada/sensor.py", line 145, in update self.ec_data.update() File "/usr/local/lib/python3.7/site-packages/env_canada/env_canada.py", line 72, in update timeout=10)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get return request('get', url, params=params, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send raise ConnectionError(e, request=request) requests.exceptions.ConnectionError: HTTPConnectionPool(host='dd.weatheroffice.ec.gc.ca', port=80): Max retries exceeded with url: /citypage_weather/xml/ON/s0000326_e.xml (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa1cfc0ae50>: Failed to establish a new connection: [Errno -3] Try again'))
