Used this one here: https://github.com/mitchellrj/eufy_robovac
Is there another?
Not sure why only the status won’t work and all else does, someone else above is having the same issue.
Maybe firmware issue?
The local key and id are correct else I wouldn’t be able to control anything.
Also @VarenDerpsAround, which model do you have and are you also running HA on raspberry pi?
Seems to be the access_token issue. Did a factory reset, pulled a new token and have managed to get the status to work through several HA reboots.
@mitchellrj Do you think it would be possible to add support for the quick clean (30 mins) and edge clean functionality? I find myself going to the Eufy app for those options since I cannot call them from HA.
I have an issue created in your github to track this and I can assist with any testing if required
i have a 15c i would like to get working. I hacked away at it on and off all day, and i think im going to throw in the towel. if anyone has any pointers that would be great. thank you to everyone in the home assistant community for the work that you do
i used notepad++, but as i have been playing around with different ways to find the localkey, i found out you can actually use the TuyaSmart app to connect the RoboVacs, so i was going to see if i can sniff it from that.
