The fact that this API choose unfriendly parameter can be frustrating but once its set up you’r good.
I dont know if it’s an issue but when I set the schedule for a bus station the station name doesn’t display on top of the red line. It seems according to your readme that It works on RER ?
Also I would love to help you with the css but I’m so bad and I have terrible taste, bu I think the time to display could be improved.
Well again and again great work and thank you for your contribution.
Wow, great, thanks for your feedback ! I’m indeed glad this ends up being useful for somebody else Most of the code is outrageously ripped from the boilerplate card github, so I wrote way less than is in there (and keep in mind the js file is compiled from typescript with its dependencies). But since I have very little knowledge of frontend stuff (and, actually, I’m far from an experienced dev), it still took me quite a lot of time to get acquainted with most of the tech involved here
I might look into making it better in the future, and I’ll certainly try to keep it running if anything breaks, but I think unless people ask here for things I consider good ideas, you do have a pretty much finished product in your dashboard
On my side it is “kind of working” : I’m unable to filter the direction (AR) at my Transilien station so it is a bit messy and not as useful as possible
I actually tried using the Rest APIs some time ago but the auth flow was not really usable. It looks like they have changed it for the better, however I can now see that the API doesn’t return “next stops” for RER lines A and B (at the very least), which makes it useless for quite a number of users, me included. So until this is solved, I’ll keep things as they are
Thanks for the warm welcome your reply. Here is an example :
I will be idle on developing my own entity (currently playing with Edge TPU, Frigates and passive cooler for rpi4 ). I will find more time to work on this in a couple of months
Hi Lesensei, trying to add it on HA dashboard. Managed to add it to HACS via repository.
a bit unclear on github readme documentation. I am unable to find the “carte…” or “Idfm” card on HA dashboard. but it is well showing as added repository in HACS.
I tried multiple cache clearning and restart of Home assistant OS on RPi4. Any help / guideline ?
For your information, if you have created your PRIM account after the 13th of March 2024, your API call quota is reduced by default to 1 000 of requests per day (it was previously 1 000 000 /day) on /marketplace/stop-monitoring.
It is explained here : it’s temporary as they don’t want to be flooded during the 2024 olympic games.
The result for me was empty cards on Home assistant dashboard starting at 4:10 AM … so it was quite useless for me!
You can :
check your quota consumption online on prim website
ask for a quota upgrade if you write an mail to [email protected].
They have applied my quota update request in a single open working day for me
The integration suddenly stopped working on my end a couple weeks ago. Even with a new token, I cannot fetch any station.
At least one other person seems to have the same problem.
Anyone else out there or what am doing wrong?
