Support for (Xiaomi) Dream F9 Mop Vacuum
which firmware version did you have when you flashed valetudo?
Any chances to get this working for teh Dream D9?
Thanks!
hi all , can anyone share the file dreame.vacuum.p2008_en.tar.gz . it expired. Thanks paolo
Have you before flashing updated the Dreame with the Xiaomi App?
This thread maybe of interest -
Hi Guys,
I’m trying to get my Dreame F9 inegrated on Home Assistant. but it’s not working.
I’ve followed this steps:
  1. How to get Xiaomi Token: Xiaomi-cloud-tokens-extractor
I’m new to Homeassistant so:
  1. Install HACS
    Version 1.9.0 released 9 hours ago
    The manual installation doesn’t work’s for me.
  2. Install xiaomi_vacuum via HACS
    also the manual installation doesn’t work for me.
  3. Install vacuum-card via HACS
  4. find dreamevacuum.py under “/custom_components/xiaomi_vacuum/miio/” and replace it with the file here .
  5. Add following code (see Step 1) to the configfile configuration.yaml:
#Dreame F9 Vaccum Robot
vacuum:
  - platform: xiaomi_vacuum #no need to change this
    host: <IP>
    token: "<Token>"
  1. Restart Homeassistant
    Configuration > General > Server Management > Restart
  2. Add the Vaccuum Card
    Home Assistant Overview page, click the three dots at the top right of the screen and select ‘Edit Dashboard’. Then click the blue ‘+ Add Card’ and scroll down to “custom: Vaccum Card”
But I don’t see the dreame F9 in the devices, it doesn’t list in the xiaomi miio inegration and when I try to add the card (Custom: Vacuum Card) to the dashboard, it either says the entity is empty or that vacuum is not available.
Anyone has this working and can provide some step-by-step guide?
Did you get it to run yet?
Same here…have you managed to sort this?
This integration is working very well. https://github.com/Tasshack/dreame-vacuum
I am using it with Dreame D9 max
I just installed Dreame F9 to HA.
It helped for me not to do point 5 from the list above.
In first I replaced file ‘dreamevacuum.py’. I had errors in the logs. After I reverted the file to previous version and It worked fine.
Goodnight all
Is it still functional today for the Dreame F9?
I’m on HA:
Home Assistant 2023.5.4
Supervisor 2023.04.1
Operating System 10.2
If this method is no longer functional, is there a new one?
Thank you for your answers
F9 Is added to the supported devices list.
