I tried the new trigger_variables feature introduced in 2021.3.0. I converted my original example to this:
- alias: test
trigger_variables:
inputs: >
{{ expand('group.input_booleans')
| selectattr('state', 'eq', 'on')
| map(attribute='name') | list }}
platform: template
value_template: "{{ inputs | count > 0 }}"
service: persistent_notification.create
title: 'Test'
message: "{{ inputs | join(', ') }}"
Unfortunately, it was rejected for the following reason:
Error rendering trigger variables: TemplateError: str: Use of ‘expand’ is not supported in limited templates
I removed expand and replaced it with a list of state objects:
{{ [ states.input_boolean.switch_1, states.input_boolean.switch_2 ]
However, that was also rejected:
Error rendering trigger variables: UndefinedError: ‘function object’ has no attribute ‘input_boolean’
tl;dr
The new trigger_variables feature is promising but, in its current state, has limited functionality; this Feature Request remains open.
