@w1ll1am23 can you help at all
Unfortunately I donāt have any way to test this out. I am in the process of moving/selling my place so I took down all my HA stuff and cameras.
Regardless of whether Surveillance Station is being used or not, to my understanding, entering http://10.0.1.32:8123/api/webhook/carpark_camera_motion into a browser address bar should deliver a āsuccessā message, as it used to, rather than a ā405: Method Not Allowedā message.
Unfortunately, I do not yet have the skills to work out why this has changed in HA.
So the auth system has changed in HA do you have the computer you are hitting that endpoint from set in allowed network auth providers? I would think if that was the issue you would get a 401 not a 405 but still could be something
Thanks for the reply. How would I check that?
Iāve been trying to hit it (Mac Mini running HA) from my Macbook but need it to work from my Synology NAS.
Check this out https://www.home-assistant.io/docs/authentication/providers/#configuring-auth-providers try adding the ip of your computer and the Synology to the trusted networks and see if you still get the same error.
Thank you @w1ll1am23, but it looks like those docs are out of date. I get an āintegratiion: auth_providers not foundā config error, and auth_providers isnāt in the Integrations list.
Auth providers should be configured under the homeassistat entry in your config.
Yes, thatās what I did, and it creates the config error as above. I find the docs often take a while to catch up with changes.
I am on 0.94.3 (I donāt think auth changed in 0.95?) and this is my config for my synology trusted network setup.
homeassistant:
auth_providers:
- type: homeassistant <-- this is needed for the username/password stuff to still work
- type: trusted_networks
trusted_networks:
- 192.168.X.X <-- This is the IP of my synology box
Thank you.
homeassistant:
auth_providers:
trusted_networks:
- 10.0.1.190
It passes config now but still the same error with the webhook: 405: Method Not Allowed
There must be an answer to this and clearly something has changed with the HA release. Iām on 0.95.4.
Something strange that I donāt understand is going on with the webhooks.
Initially, I set up webhooks to use with Surveilance Station action rule like this:
https://10.0.1.32:8123/api/webhook/south_terrace_camera
As per my previous posts, the webook calls from SS are now resulting in a ā405: Method Not Allowedā message rather than a āsuccessā message.
Looking at this further it seems that HA has created some cloud webooks for me!
The code that I believe caused this is like this:
- alias: South Terrace Camera Detection
initial_state: 'on'
- platform: webhook
webhook_id: south_terrace_camera
condition:
- condition: state
entity_id: input_boolean.south_terrace_camera_active
state: 'on'
- service: tts.google_say
entity_id: media_player.kitchen_speaker
message: "Motion detected by South Terrace camera"
- service: notify.mobile_app_ash_x
message: "South Terrace camera motion detected"
How could this have happened?
Each of the webhooks has a generated link:
https://hooks.nabu.casa/gAAAAABdI???????????????????????????????????????????????????????????dItQ0VvG7LOC83VnfUm38=
Now, this would be fine, except that I want to keep everything in my own network rather than use the cloud service, and, the webook still returns the same 405: Method Not Allowed
Anyone have any idea whatās going on?
Iāve tested this and creating the following automationā¦
- alias: Test Camera Detection
initial_state: 'on'
- platform: webhook
webhook_id: test_camera_hook
condition:
- condition: state
state: 'on'
message: "Motion detected by Webhook"
message: "Webhook motion detected"
ā¦as a test, resulted in the following after reloading automations!
Is it now the case that webhooks are solely for cloud use?
Previously, cloud webhooks had to be created through the front end. It now seems the āthe hookā is now generated just by adding a webhook triggered automation.
I have made some progress!
I can now trigger an automation using http://10.0.1.32:8123/api/webhook/carpark_camera_motion
sent as a POST request with no authorisation, using Postman app.
So, it now appears that the SS action rule no longer calls a POST request when the Action Device is set to External Device. Itāll be either GET or PUT I guess but I donāt know how to figure out which.
Using terminal,
curl -X POST https://hooks.nabu.casa/gAAAAABdIakPoSs2??????????????????????????Gwk=
works fine, as does
curl -X POST http://10.0.1.32:8123/api/webhook/carpark_camera_motion
To those with more knowledge than me, is there any way to use External Device Url to trigger an HA automation from SS camera detection now?
What SS version are you using? Iām using Version: 8.2.4-5847 but I see there is an update available to Version: 8.2.5-5850. Iāve just reactivated my webhooks on motion to test for you and itās working even though I get 405 messages too when dropping that URL in FF.
Question: Why are you sending your SS action to an external address? Iām assuming theyāre both on the same LAN?
Here is my automation:
automation:
- alias: 'Webhook endpoint to entry motion' ## http://ip-address-of-HA:8123/api/webhook/motion_entrance ##
hide_entity: true
- platform: webhook
webhook_id: motion_entrance ## this is the only place you create the webhook ID ##
- service: camera.snapshot
entity_id: camera.proxy_entry
filename: '/config/www/images/entry_cropped.jpg'
- service: script.turn_on
entity_id: script.trigger_ss_entrance_boolean ## I use a script here to turn the input boolean off after 5s ##
- service: notify.hass_synochat
message: "Entry motion webhook fired at {{ states.sensor.time.state }}" ## appends the current time to the message ##
file_url: http://ip-address-of-HA:8123/local/images/entry_cropped.jpg
And the script:
script:
trigger_ss_entrance_boolean:
alias: Trigger input boolean for motion from API
sequence:
entity_id: input_boolean.motion_entrance
- delay: 00:00:05
- service: input_boolean.turn_off
I was just trying the external address as part of the fault finding. Iām trying to use internal address like http://10.0.1.32:8123/api/webhook/carpark_camera_motion
Iām using version 8.2.4-5847.
Iāve just contacted Synology Support as Iām able to get some consistency if the Surveillance Station Client is running and active on a Mac!
I left my Macbook running the Surveillance Station client in the foreground all day today and the alerts were afultless, but it shouldnāt be this way. Surely it should just run on the Synology Nas.
Really helpful automation, thank you.
How are you defining the camera entity?
Does the config/www/images/entry_cropped.jpg get overwritten each time or is a new file created?
What is this notification service you are using here: notify.hass_synochat?
Thanks for the help.
The camera is a proxy of one of my cameras to reduce the image size so I donāt fill up my chat platform and itās quicker to display on mobile.
- platform: proxy
entity_id: camera.front_porch
max_image_width: 640
image_refresh_rate: 2.0
The images get overwritten every time but that doesnāt matter as Iām recording on Synology anyway and the history is available in the chat platform too. The notification platform is Synology chat which works extremely well. Just remember to turn off battery optimization for that app otherwise you wonāt get notifications in real time.
Did a video on how to configure that with HA here https://www.youtube.com/watch?v=Ze73EoNxOAU
guys interesting thread, but i am also unable to fire a webhook from SS
as some screenshots above, where you create the action, i dont have āexternal deviceā i can choose only webhook
so i enter my nabucasa url there
but tried with post/get , nothing works, always test failed
if i test from SSH and the CURL - X POST https://xxx , then it worksā¦
any idea?
Hi @pergola.fabio did you manage to make it work? I have a foscam FI9901EP and I canāt get a motion_detection sensor on hassio, neither with surveillance_station nor with the switch with CGI. Were you able to do something?
yes, got it to work, it was an SSL issue in my case
but at the moment, i dont use it anymore , i am now using DSM integration
