For example:
FrontDoor / IP Camera 1
Main Stream: rtsp://admin:[email protected]:554/Streaming/Channels/101
Sub Stream: rtsp://admin:[email protected]:554/Streaming/Channels/102
I had the same problem with Swann NVR8-7400, until an hour ago.
I then read this article NVR-7400 Help · Issue #250 · thirtythreeforty/neolink · GitHub
I now have a Reolink RLN8-410 system
It took 3 minutes. You will need to use password 12345 to pick up the cameras.
The Reolink integration then effortless imports the cameras to Home Assistant.
I’m very impressed. If you use DDNS on SwannView app, then it’s an easy change…otherwise you can download the Reolink app for your phone.
Good Luck
Hey @Spiz67 did you manage to get this working at all? I have DVR8-4600T with no RTSP options just like you. Been trying all sorts of stuff for days now and I’m basically out of ideas.
I can see my DVR streams on Reolink mobile app and SwannView (desktop) but I can’t for the life of me get any links to work in VLC let alone Home Assistant.
Wise forum people, please guide me. If I don’t have an RTSP enabled DVR am I out of luck? Can’t seem to get anywhere using HTTP links.
Edit: Also make sure the user account you are using doesn’t have any special characters (such as ‘@’ , ‘.’, or ‘:’) that may interfere with connection.
