I’m taking from a MQTT_DUMP file used via developer tools.
If I press pause/stop three times with no other commands before or after I get the following. Value 5 does not always appear. Maybe Esp32 is retrieving info after a command?!?
10 second dump file…
switchbotMQTT/Lounge_esp32/curtain/lounge_curtain_rhs_esp32/status,{"status":"connected"}
switchbotMQTT/Lounge_esp32/curtain/lounge_curtain_rhs_esp32/status,{"status":"commandSent"}
switchbotMQTT/Lounge_esp32/curtain/lounge_curtain_rhs_esp32/status,{"status":"success","value":5}
I’ll release a v3.1 tonight which will wait a bit for a response. I’m expecting the response immediately so that could causing issues
if you can figure out if value=5 actually means success for curtain that will help
ya current code will output notifyCB in the serial log. I’m gonna make a few minor changes and release a v3.1 tonight
I’ve figured out why I was getting this error when uploading via usb.
Sketch uses 1124713 bytes (85%) of program storage space. Maximum is 1310720 bytes.
Global variables use 51168 bytes (15%) of dynamic memory, leaving 276512 bytes for local variables. Maximum is 327680 bytes.
java.lang.NullPointerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingProgrammer(SerialUploader.java:295)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:90)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.lang.Thread.run(Thread.java:748)
I was using
Upload using Programmer
instead of
Upload
How long does it scan for when this is initiated
static int rescanTime = 600;
Is it using this to determine how long to scan for?
static int initialScan = 60;
I’ve captured when it failed.
Failed 1:
Control MQTT Received...
Received something on switchbotmqtt/esp32/control
cr_curtain_lt
Processing Control MQTT...
Device: cr_curtain_lt
Device value: 81
Try to connect. Try a reconnect first...
Connected
Reconnected client
Connected to: 5c:c6:fd:94:84:bc
RSSI: -114
Sending command...
subscribed to notify
lld_pdu_get_tx_flush_nb HCI packet count mismatch (2, 3)
Success! Command sent/received to/from SwitchBot
Done sendCommand...
Failed 2:
cr_curtain_lt
Device value: 86
Connected
Reconnected client
RSSI: -103
Sending command...
Done sendCommand...
rescanTime = every x seconds it will do a rescan automatically (if autoRescan = true)
initialScan = when the initial scan happens and rescan is performed it will scan for X seconds OR until it finds all BLE devices. initialScan can be a super high number like 1000, it will stop when it finds all devices. you can put this a high number if you know all devices will be found. if one device cant be found it will scan the whole 1000 seconds
ok I have an idea for v3.1
not sure how you are getting rssi of -114 in the log though. thats weird. -99 should technically be the limit since -100 means no signal from my understanding
No idea. The esp32 and the curtain is literally right next to each other.
if the rssi in HA shows up fine I am not concerned, maybe just be a logging issue. I haven’t seen a value greater (less than technically) then rssi -85 in my testing
HA is showing -77 the highest.
I am starting to play with the bot and noticing the on/off switch icon always revert back to the off state.
I have tried adding ‘assumed_state’ to customize.yaml file, but doesn’t work. Anyone knows who to fix?
switch.floor_heat_switch:
icon: mdi:power
assumed_state: false
The success value shows a 5. I thought it suppose to be a 1
status = {"status":"success","value":5}
Answer:
I am just assuming the curtain response values are the same as bots where 1 or 5 = success, 3 = busy, everything else means failed
setting the hold seconds on bots is useful for people that need to use the same bot for different hold times.
Example: turning something on requires holding for 10 seconds, turning that same thing off requires holding for 0 seconds.
I have a device that does just that. I need to hold press for 3 seconds to turn off. A short press to turn on. I tried to follow your example in the V3 release note, but I am not understanding.
you have 2 options to set hold time
a )
publish a value from 0-100 for bot to (just lile position for curtain
<ESPMQTTTopic>/bot/<name>/set
b) publish a message like {"id":"switchbotone", "hold":5}
to
<ESPMQTTTopic>/setHold
when hold time is set, the hold time will be retrieved right after
now that hold time is set, you can call a press
command and it will hold for the new time you set
you have to set the hold time before the press.
You can set hold time right before the press action, or at anytime before. the bot remembers its hold time and so does the esp32
I should have a fix for this in v3.1. That works nice when the bot is in press mode, but ya in switch mode the state flips back temporarily until it receives a state update from the esp32
it will currently switch to the proper state once the commandSent is received and for good measure also when the individual device scan is performed after a set/control
v3.1 released
If previously using curtain you will need to delete the device and rediscover in HA after an ESP32 reboot in order to use new curtain position topic
bots had the mode attributes added
Ok. So this is what I have tried and it isn’t working. In the mobile app, I have set the press-hold time back to zero
Need to have V4.0 +. I created a template script.
holdpress_bot:
sequence:
- service: mqtt.publish
topic: 'switchbotmqtt/esp32/holdPress'
payload : "{\"id\":\"{{ bot }}\", \"hold\":\"{{ press }}\"}"
I am calling this script via automation. Not sure if the delay is needed, but I have tried with and without delay.
- alias: '24hr fan toggle on-off'
- platform: time
at: '05:25:00'
- platform: time
at: '23:00:00'
condition:
- condition: template # Someone is Home
value_template: "{{ is_state('input_select.home_mode', 'Home') }}"
- service: >-
{% if is_state( 'sensor.time', '05:25' ) %}
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
entity_id: switch.24hr_fan
- alias: '24hr fan toggle speed'
- platform: state
entity_id: sensor.period_of_the_day
to: 'nightlight'
- platform: time
at: '05:30:00'
condition:
- condition: template # Someone is home
- service: script.holdpress_bot
bot: '24hr_fan'
press: 0
- service: switch.turn_on
entity_id: switch.24hr_fan_switch
Both automation are zero second presses. I am assuming it is from the app I have set to zero.
In MQTT, I can see the setHold and it seems to be taken the hold numbers correctly.
To create a customer switch with hold press. Change to suite to your settings.
switch.yaml
switches:
floor_heater:
friendly_name: 'Floor Heater'
value_template: "{{ states('input_boolean.floor_heat') }}"
turn_on:
bot: 'floor_heat' # taken from your esp32 bot name
press: 0 # how long you want the press to hold
entity_id: input_boolean.floor_heat
turn_off:
press: 3 # how long you want the press to hold
- service: input_boolean.turn_off
icon_template: >-
{% if is_state('input_boolean.floor_heat', 'on') %}
mdi:check-circle
{% else %}
mdi:check-circle-outline
{% endif %}
input_boolean.yaml
floor_heat:
icon: mdi:radiator
you can try with <ESPMQTTTopic>/bot/<name>/set
payload "3"
or 3
for a hold
you should not need a delay since the esp32 will handle it
I just noticed <ESPMQTTTopic>/setHold
does not do a requestSettings after. It just sets the value on the bot. I’ll update it so it does
