System won't start after update 2024.5.0
I have zigbee2mqtt running as well an suspect it being the culprit.
zigbee2mqtt at current 1.37.1-1: HA hangs after start and is unusable.
With zigbee2mqtt disabled, all works smoothly and fast.
Same here. Tried with Z2M v1.36.0-1 and v1.37.0-1.
Now who should responsible for a fix? Z2M or HA? I don’t know if I should post a issue on Z2M’s GitHub.
What’s your MQTT broker?
I have all of those components at those versions in my prod install currently and it runs like a screaming banshee. (way fast)
Mines Mosquito 6.4.0
Mosquito 6.4.0 here too.
Running on a RaspberryPi 3.
The pi3 only has 1 Gb memory. With the Zigbee2MQTT add-on running, it probably runs out of memory. You can try to increase the swap size.
Still, it was working beautifully until the Home Assistant Operating System 2024.5.0 update
Update: apparently, disconnecting the coordinator, rebooting and plugging it back in solves the problem.
Read it in an issue in HAOS github, just tested, and worked.
Update #2: Rebooting the system with the coordinator plugged in causes the problem to return.
Thank you for your solution, it worked for me as well.
The only other solution I had found was to stop the Zigbee2MQTT addon (which is not practical with my connected devices).
I’m still having major issues with HASS crashing since 2024.5. Safe mode seems to be stable, but of course I can’t run normally in safe mode. It has been hit or miss when I disable/enable a few integrations at a time. I can’t seem to narrow it down to a single issue. I even suspected it may be my PC. So I moved to another PC and have the same issues. I also updated the VirtualBox thinking that may be the issue… Still no luck. I finally have it running somewhat stable but now integrations are not loading properly such as Tank Utility… Has anyone confirmed this is a HASS issue that needs and will be fixed? I’m loosing hair quickly!
Did you try 2024.5+: Tracking down instability issues caused by integrations ?
I’m getting in over my head… I don’t know what any of this really means:
Logger: homeassistant
Source: /usr/src/homeassistant/homeassistant/runner.py:147
First occurred: 1:50:10 AM (10 occurrences)
Last logged: 1:51:30 AM
Error doing job: Error on transport creation for incoming connection
File “/usr/local/lib/python3.12/asyncio/selector_events.py”, line 235, in _accept_connection2
await waiter
File “/usr/local/lib/python3.12/asyncio/sslproto.py”, line 578, in _on_handshake_complete
raise handshake_exc
ConnectionResetError
Logger: asyncio
Source: runner.py:190
First occurred: 1:54:26 AM (3 occurrences)
Last logged: 1:54:26 AM
Executing <Task pending name=‘Task-18578’ coro=<RequestHandler._handle_request() running at /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:452> wait_for=<Future pending cb=[Task.task_wakeup()] created at /usr/local/lib/python3.12/asyncio/base_events.py:448> cb=[Task.task_wakeup()] created at /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:527> took 0.152 seconds
Executing <Task pending name=‘Task-18579’ coro=<WebSocketHandler._writer() running at /usr/src/homeassistant/homeassistant/components/websocket_api/http.py:169> wait_for=<Future pending cb=[_chain_future..call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()] created at /usr/local/lib/python3.12/asyncio/base_events.py:448> created at /usr/src/homeassistant/homeassistant/util/async.py:40> took 0.140 seconds
Executing <Task pending name=‘Task-18579’ coro=<WebSocketHandler._writer() running at /usr/src/homeassistant/homeassistant/components/websocket_api/http.py:169> wait_for=<Future pending cb=[_chain_future..call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()] created at /usr/local/lib/python3.12/asyncio/base_events.py:448> created at /usr/src/homeassistant/homeassistant/util/async.py:40> took 0.106 seconds
The strangest part is that after enabling the profiler: Set asyncio debug, I haven’t crashed at all! Am I correct to assume that the debugging is slowing it down enough that it no longer crashes? Whatever was done in 2024.5 to speed things up may need another look.
First occurred: 1:50:10 AM (4513 occurrences)
Last logged: 1:21:37 PM
await waiter
raise handshake_exc
Has anyone tried updating to 2024.6.0 I really hope this is fixed in this version, but I am scared to try it.
EDIT: I was able to successfully update to 2024.6.0 with no issues, I decided to just go for it.
Damn, upgraded to 2024.5 and my RPI bootloops. I have to fresh install as I don’t have a RPI5 HDMI adaptor. What a PITA.
How much testing was done before release?
I have the same issue: I tried several times to update the core but after that system didn't boot up, so I had to unplug the power to make it start, with the system not updated.
So I tried to disconnect the coordinator and update the system again and work flawlessly.
Is there a way to solve that problem?
