Anything I need to do on the systemair? I see that it’s set as «user locked». Does this stop communication?
I can’t see anything on my VSR that says “user locked”.
Read the manual to find out how to activate modbus?
This is my modbus settings
My manual doesn’t mention modbus
Jippi! Found it - now it seems to working fine Thank you!!
There is/was a separate modbus manual for the VSR units. At least it was that for me when I installed mine.
Or else you can call Systemair technical support and ask how to activate it?
They are good and very helpful.
How did you fix it?
I found the menu when I realiced there was a second page to the setup page
Changed the slave and baudrate and then it worked like a charm
Does anyone have a script for setting the temperature?
I tried setting up this example from above, but when checking the config it just kept working forever and not saying if it was ok or not.
modbus:
- name: hub1
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
climates:
- name: Ventilasjon
slave: 1
data_type: uint
data_count: 1
scale: 0.1
offset: 0
precision: 1
max_temp: 30
min_temp: 15
temp_step: 1
target_temp_register: 2000
current_temp_register: 12102
I found this on Facebook earlier. I haven’t tested it out yet, just saved it for later use.
Have a look at this:
###### MODBUS GREJ FRÅN FACEBOOK
#configuration.yaml
#Systemair VSR300
modbus:
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
input_number:
ftx_fan_speed:
min: 0
max: 3
step: 1
unit_of_measurement: step
icon: mdi:fan
ftx_temperature:
min: 0
max: 5
step: 1
icon: mdi:thermometer
sensor: !include sensors.yaml
#sensors.yaml
- platform: modbus
registers:
- name: ftx_fan_speed
slave: 1
register: 100
scale: 1
offset: 0
- name: ftx_temperature_set
slave: 1
register: 206
- name: ftx_supply_air
unit_of_measurement: °C
slave: 1
register: 213
scale: 0.1
precision: 1
- name: ftx_extract_air
slave: 1
register: 214
scale: 0.1
precision: 1
- name: ftx_outdoor_air
slave: 1
register: 217
scale: 0.1
precision: 1
- name: ftx_filter_age
unit_of_measurement: days
slave: 1
register: 601
#Lägg in i automations.yaml
- alias: Set fan speed for FTX
platform: state
entity_id: input_number.ftx_fan_speed
service: modbus.write_register
unit: 1
address: 100
data_template:
value: '{{ states.input_number.ftx_fan_speed.state|int }}'
- alias: Update FTX fan speed slider value
platform: state
entity_id: sensor.ftx_fan_speed
service: input_number.set_value
data_template:
value: '{{ states.sensor.ftx_fan_speed.state }}'
- alias: Set temperature for FTX
platform: state
entity_id: input_number.ftx_temperature
unit: 1
address: 206
data_template:
value: '{{ states.input_number.ftx_temperature.state|int }}'
- alias: Update FTX temperature slider value
platform: state
entity_id: sensor.ftx_temperature_set
data_template:
value: '{{ states.sensor.ftx_temperature_set.state }}'
# Exempel på entities card
entities:
- entity: sensor.ftx_supply_air
- entity: sensor.ftx_extract_air
- entity: sensor.ftx_outdoor_air
- entity: sensor.ftx_filter_age
- entity: input_number.ftx_fan_speed
- entity: input_number.ftx_temperature
show_header_toggle: false
theme: Backend-selected
title: FTX
type: entities
Ahh! That made it a bit cleaner I fidled around a bit more today and ended up making a drop down selector for temperature and one automation for each single temperature selection. Something like this would cut down on number of automations
unit: 1
address: 2000
data_template:
value: '{{ states.input_select.temp_vtr|int }}'
Let me know when you are done, so I can copy your config
I would like to have a full blown integration for Systemair, or at least for ventilation units in general. Like the Climate integration.
I have this input_select:
I then made a sensor that multiplies the input_select state by 10
sensors:
temp_sendt_vtr:
value_template: '{{ ((states.input_select.sett_vtr_temp.state | float * 10)) | round(0) }}'
friendly_name: 'Temp sendt til vtr'
And then made this automation:
- id: '1635445362223'
alias: Sett vtr temp
description: ''
- platform: state
entity_id: input_select.sett_vtr_temp
for:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
condition: []
- service: modbus.write_register
address: 2000
unit: 1
hub: hub1
data_template:
value: '{{ states.sensor.temp_sendt_vtr.state }}'
mode: single
Why such a fuss for the temps? Easy as that
modbus:
# - name: hub1
type: serial
method: rtu
port: /dev/ttyUSB0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
climates:
- name: vent_VSR500
address: 12102
slave: 1
data_type: uint
data_count: 1
scale: 0.1
offset: 0
precision: 1
max_temp: 30
min_temp: 15
temp_step: 1
sensors: !include VSR/NEW_VSR_500.yaml
Thank you Finally a version of the climate code I could get to work. Others have eather failed in check or had state «unavailable»
Post no2 in this thread by @Tempo_Trevis
All credits to him. Read through the first 30-50 messages. He had a lot to offer
For the modbus manual by systemair you have to take the address and -1. So if it states 501 address you put 500 in HA config. At least the case for me
Your right - great work!
I couldn’t get his climate code to work - but now I can’t remember if maybe I used 2001 and not 2000 as you point out
After a “lifetime” is the repository for the Systemair Save ventilation units ready (hopefully ):
This is beautiful. Ill give it a shot when I get some free time. If you add “buy me a coffee” on git we can say thank you for all the hard work
Repo just done, the same day I find out my Systemair can be connected to HA (Prob).
I see systemair also has an app.
For starters I would just see how much use of it I have. (Not including gadget and fun factor)
Anyone tried it as well?
I need an IAM_ID to connect the app, which I cant seem to find.
I can also connect to WLAN on the panel itself, but it does not find any networks. My guess is that I need some sort of ethernet module installed to the ventialtion?
In order to use the Systemair app or Modbus TCP, you need to have the IAM gateway, the IAM_ID is located on the back of the IAM gateway. An alternative is modbus RTU, which is available from the A(+)/B(-) terminals on the terminal card, but then you also need serial → ethernet converter or USB, whichever that suits your installation).
