Tado stopped working after latest HA Core update
Update: I’ve abandoned my instance running in virtualbox. I’m now running on an Intel-NUC. All OK now! Solved also other stability issues I had.
I’m running my Home Assistant in a VM using Proxmox on an Intel NUC. Other than the latency when changing temperature in Tado app showing up in HA, I’m very happy with my setup.
Hello ;
I created a new VM where I just added my tado still not working correctly not sure if it is only me or something is happening is there any way to try to get the logs from the system ?
How did you add the Tado integration? By config.yaml file or GUI?
Hi, I have the same problem, I have to keep version 2021.1.5 to keep tado working.
I did setup tado through configuration.yaml, should I remove the integration and add it again with UI?
thanks.
Setting up through config.yaml is not supported anymore I believe. I’ve done it through UI, try this.
I also did it through the user interface and Tado works well.
For me the “Set preset mode” does not work at all… and it only updates when i reload the integration,
